Drag/drop scrolling on iOS
When trying to reorder a playlist on iOS, you cannot scroll while dragging/dropping. You have to drag/drop one screen at a time.
For longer playlists, this becomes really annoying, especially since there doesn’t seem to be any easy way to do it on web either.
Use case:
“Dad, please add this one random song to the top of my playlist above all 7000 Taylor Swift songs.”
“OK, the only option I have is to add it to the bottom of the playlist and then drag it to the top one screen at a time. I’ll let you know in about 3 years when I’m done.”
We’d like to add that at some point, but before then we’d likely add move to top/bottom actions, as those are fairly common things and even if drag-scrolling were supported, it’s way easier to use an action, I think.
I’ll certainly take what I can get. Would love full drag scrolling at some point for use cases that aren’t quite as simple, but an add to top action would be a great start. Thanks!
