Feature: Move to Top
When managing playlists it would be nice to be able to move an item all the way to the top of the list instead of having to drag them individually.
Adding a bunch of songs/movies to the top of an existing large playlist takes forever because you have to drag each item to the top. Or if you’re using an app you have to click the up arrow over and over and over.
You are already using this feature in the conversion queue, it just makes sense to have it on playlists.
Where:
Plex-web: up-arrow on hover - when editing playlists, on hover of an item (song/movie/etc) you already have things appear (move handle, play button, the multi-selection dot and remove X). You could add it there and have an up arrow appear on hover, there seems to be plenty of room.
Plex-Apps: add to menu - just add it to the drop-down menu for items in the playlist, or maybe if you hold the UP arrow on a remote it moves it to the top.
Thanks in advance for considering this request
