Drops Audio Every so Often
Server and player are both the latest stable versions.
It seems to happen with higher quality versions of films but every so often, the audio cuts out. It’s less than half a second but annoying as you can hear it.
Everytime I think it’s calmed down, it blips again.
I’m streaming on a 2012 Samsung TV using the Plex app.
The HTPC is connected to the router, TV is connected to the router.
The HTPC audio out is digital, which is connected to some speakers. The TV also has a digital out, which is connected to the speakers.
When watching normal TV, the speaker audio is fine so this makes me think it’s a Plex streaming issue.
Is there something I can do to fix it?
