I’m having the 404-not found issues. Can you send me a link to a build that should be stable on the Synology 1010+ running DMS 5?
On the downloads page: 32 bit X86
Thank you. This version is loading the UI, however it does not want to connect to PMS on my device in the UI. I get the following message.
tiny is currently unavailable
Verify you have a network connection and that the server is online, or see our troubleshooting tips for further assistance.
The logs have errors showing Error -6 requesting XML and HTTP error requesting get, both have Plex API URL’s
Thoughts?
Error 6 = DNS lookup failure.
It means name resolution isn’t working (internet connection via the gateway isn’t right)
Show me the logs ZIP file please ?
I’ve moved us here. Continuing there would have been hijacking.
Found the problem. Jumbo frames weren’t consistent between the NAS and gateway. Thanks for the help!
Trumpy,
Yes I know the 1010 is a fossil, but it just keeps going.
