DS1513+ transcoding problem
Server Version#: 1.14.0.5465 64bit
Player Version#: any
Hello. Some time ago all my transcoding seems to have broke on my Synology DS1513+. It was always slow on Synology NAS, but at least it worked. Right now some videos will not stream to Apple devices, and they cannot sync down either. For example, I’m trying to transcode a H.264 movie with no luck. Please advise what logs or screen shots are needed.
Many Thanks,
-Anatoly
I’m sorry if it wasn’t clear. I’m not expecting real-time transcoding. I’m OK with optimization and sync taking a while. They used to work - it was slow, but they worked. The movie files didn’t change. Now it’s just erroring out immediately. I just want to fix what used to work.
Thanks… That gives me a starting point to help you :slight_smile:
I would like to ask you to run this sequence.
  1. Verify, in Settings - Server - General, that DEBUG logging is enabled but VERBOSE logging is disabled
  2. If you change them, please restart PMS
  3. Now attempt to optimize the test file
  4. After it fails, wait 15 seconds for cleanup
  5. Create a ZIP of the logs ( Settings - Server - Troubleshooting - Download Logs)
  6. With this ZIP file, please also hover over the item → Get Info → View XML and copy paste that into your reply. (Use “Code” paragraph formatting to protect it if needed)
This will tell me what PMS saw, what it tried to do, and what happened.
ZIP file attached. I’m sorry, I couldn’t follow your instructions in step 6. Hover over the ZIP file or one of the log file within? Which XML file? If you provide a bit more guidance I’d be happy to provide.
Plex Media Server Logs_2018-11-13_07-58-28.zip (1.2 MB)
Is this right?
<MediaContainer size="1" allowSync="1" identifier="com.plexapp.plugins.library" librarySectionID="1" librarySectionTitle="Movies" librarySectionUUID="45511ee4-e748-4508-8eab-69c682064675" mediaTagPrefix="/system/bundle/media/flags/" mediaTagVersion="1541810772"><Video ratingKey="301" key="/library/metadata/301" guid="com.plexapp.agents.imdb://tt0903624?lang=en" librarySectionTitle="Movies" librarySectionID="1" librarySectionKey="/library/sections/1" studio="WingNut Films" type="movie" title="The Hobbit: An Unexpected Journey" titleSort="Hobbit 1" contentRating="PG-13" summary="Bilbo Baggins, a hobbit enjoying his quiet life, is swept into an epic quest by Gandalf the Grey and thirteen dwarves who seek to reclaim their mountain home from Smaug, the dragon." rating="6.8" viewCount="4" lastViewedAt="1488260091" year="2012" tagline="From the smallest beginnings come the greatest legends." thumb="/library/metadata/301/thumb/1542141233" art="/library/metadata/301/art/1542141233" duration="10177042" originallyAvailableAt="2012-12-14" addedAt="1362132698" updatedAt="1542141233" chapterSource="media"><Media videoResolution="1080" id="301" duration="10177042" bitrate="11069" width="1920" height="800" aspectRatio="2.35" audioChannels="6" audioCodec="dca" videoCodec="h264" container="mkv" videoFrameRate="24p" audioProfile="dts" videoProfile="high"><Part accessible="1" exists="1" id="302" key="/library/parts/302/1362132698/file.mkv" duration="10177042" file="/volume1/video/Movies/The Hobbit_ An Unexpected Journey (2012).mkv" size="14081076218" audioProfile="dts" container="mkv" deepAnalysisVersion="2" requiredBandwidths="23930,20695,17824,16107,14672,13598,12287,11666" videoProfile="high"><Stream id="1115" streamType="1" default="1" codec="h264" index="0" bitrate="9533" language="English" languageCode="eng" bitDepth="8" chromaLocation="left" chromaSubsampling="4:2:0" frameRate="23.976" hasScalingMatrix="0" height="800" level="41" profile="high" refFrames="5" requiredBandwidths="22420,19184,16315,14597,13163,12088,10778,10173" scanType="progressive" width="1920" displayTitle="1080p (H.264)"/><Stream id="1116" streamType="2" selected="1" default="1" codec="dca" index="1" channels="6" bitrate="1536" language="English" languageCode="eng" audioChannelLayout="5.1(side)" bitDepth="24" profile="dts" requiredBandwidths="1509,1509,1509,1509,1509,1509,1509,1509" samplingRate="48000" title="English" displayTitle="English (DTS 5.1)"/><Stream id="1117" streamType="3" codec="srt" index="2" language="English" languageCode="eng" requiredBandwidths="1,1,1,1,1,1,1,1" displayTitle="English (SRT)"/><Stream id="726" key="/library/streams/726" streamType="3" codec="idx" subIndex="3" language="Português" languageCode="por" format="vobsub" displayTitle="Português (VOBSUB External)"/><Stream id="59606" key="/library/streams/59606" streamType="3" codec="idx" subIndex="1" language="Français" languageCode="fre" format="vobsub" displayTitle="Français (VOBSUB External)"/><Stream id="59607" key="/library/streams/59607" streamType="3" selected="1" codec="idx" subIndex="0" language="English" languageCode="eng" format="vobsub" displayTitle="English (VOBSUB External)"/><Stream id="59608" key="/library/streams/59608" streamType="3" codec="idx" subIndex="2" language="Español" languageCode="spa" format="vobsub" displayTitle="Español (VOBSUB External)"/></Part></Media><Genre id="392" filter="genre=392" tag="Adventure" count="194"/><Genre id="1720" filter="genre=1720" tag="Fantasy" count="78"/><Genre id="168" filter="genre=168" tag="Action" count="273"/><Director id="24822" filter="director=24822" tag="Peter Jackson" count="6"/><Writer id="24823" filter="writer=24823" tag="Fran Walsh" count="6"/><Writer id="24824" filter="writer=24824" tag="Philippa Boyens" count="6"/><Writer id="24825" filter="writer=24825" tag="Peter Jackson" count="6"/><Writer id="24826" filter="writer=24826" tag="Guillermo del Toro" count="3"/><Producer id="6728" filter="producer=6728" tag="Carolynne Cunningham" count="3"/><Producer id="6729" filter="producer=6729" tag="Peter Jackson" count="6"/><Producer id="24846" filter="producer=24846" tag="Fran Walsh" count="3"/><Producer id="24847" filter="producer=24847" tag="Zane Weiner" count="3"/><Country id="6732" filter="country=6732" tag="New Zealand" count="9"/><Country id="23" filter="country=23" tag="USA" count="787"/><Role id="24827" filter="actor=24827" tag="Ian McKellen" count="8" role="Gandalf" thumb="http://image.tmdb.org/t/p/original/c51mP46oPgAgFf7bFWVHlScZynM.jpg"/><Role id="757" filter="actor=757" tag="Martin Freeman" count="7" role="Bilbo" thumb="http://image.tmdb.org/t/p/original/ashlWz2KDQTbo8NPUbVOwcB3zXJ.jpg"/><Role id="24828" filter="actor=24828" tag="Richard Armitage" count="4" role="Thorin" thumb="http://image.tmdb.org/t/p/original/nxA9EUBaipqb68ZbD5aGcjlT6zE.jpg"/><Role id="2934" filter="actor=2934" tag="Andy Serkis" count="10" role="Gollum" thumb="http://image.tmdb.org/t/p/original/nQRsxFveJaUIlZ4GYWDe9uJ6u2f.jpg"/><Role id="4621" filter="actor=4621" tag="Cate Blanchett" count="8" role="Galadriel" thumb="http://image.tmdb.org/t/p/original/wkWpYrtA1QCNv4B6L6fBTMRBiQ9.jpg"/><Role id="5969" filter="actor=5969" tag="Christopher Lee" count="8" role="Saruman" thumb="http://image.tmdb.org/t/p/original/3Pj0Zt1x9fwBrGGLe6DRGj8Ymmx.jpg"/><Role id="24829" filter="actor=24829" tag="Sylvester McCoy" count="3" role="Radagast" thumb="http://image.tmdb.org/t/p/original/hgM7jEkkwI0HHx3K44UE48gBbfa.jpg"/><Role id="771" filter="actor=771" tag="Ian Holm" count="5" role="Older Bilbo" thumb="http://image.tmdb.org/t/p/original/uq6Wx7PaLgaw969avH7tLHnSb0Q.jpg"/><Role id="22575" filter="actor=22575" tag="Elijah Wood" count="6" role="Frodo" thumb="http://image.tmdb.org/t/p/original/c4fB3WAS7jN78rihw2kB81v6sez.jpg"/><Role id="24830" filter="actor=24830" tag="Hugo Weaving" count="10" role="Elrond" thumb="http://image.tmdb.org/t/p/original/3DKJSeTucd7krnxXkwcir6PgT88.jpg"/><Role id="23099" filter="actor=23099" tag="Lee Pace" count="5" role="Thranduil" thumb="http://image.tmdb.org/t/p/original/93N1awB9SAUgXTejEFCXUDfi6hP.jpg"/><Role id="24831" filter="actor=24831" tag="Conan Stevens" count="2" role="Bolg" thumb="http://image.tmdb.org/t/p/original/8mlrCTSXDInF15w6CO4IYgbPKg7.jpg"/><Role id="24832" filter="actor=24832" tag="Bret McKenzie" count="2" role="Lindir" thumb="http://image.tmdb.org/t/p/original/tEP4b5bTpSxJUHOYItg5xrZh43F.jpg"/><Role id="24833" filter="actor=24833" tag="Aidan Turner" count="3" role="Kili" thumb="http://image.tmdb.org/t/p/original/lJFfJeCKRD1h9cvBK6Dla03B42J.jpg"/><Role id="24834" filter="actor=24834" tag="James Nesbitt" count="4" role="Bofur" thumb="http://image.tmdb.org/t/p/original/n9NorD6bQfFJlW4IcJ6WoGiAKcR.jpg"/><Role id="19229" filter="actor=19229" tag="Graham McTavish" count="4" role="Dwalin" thumb="http://image.tmdb.org/t/p/original/eqxR4TGXcY0vLLqR5RkfgVXBgrS.jpg"/><Role id="6716" filter="actor=6716" tag="Barry Humphries" count="2" role="Great Goblin" thumb="http://image.tmdb.org/t/p/original/bBXWmZtFbKy6Wzk1fHOCE8j6KfS.jpg"/><Role id="24835" filter="actor=24835" tag="Ken Stott" count="4" role="Balin" thumb="http://image.tmdb.org/t/p/original/aS2ZLIOYsmL8UQscHEOOFMERI4F.jpg"/><Role id="24836" filter="actor=24836" tag="Jeffrey Thomas" role="King Thror" thumb="http://image.tmdb.org/t/p/original/vLO7WJKnAxDV6IBH8fBAmsTnmzI.jpg"/><Role id="24837" filter="actor=24837" tag="Mark Hadlow" count="3" role="Dori" thumb="http://image.tmdb.org/t/p/original/qNBpe4BKgKrLF6yZrCtCjFMRFJv.jpg"/><Role id="24838" filter="actor=24838" tag="John Callen" count="3" role="Oin" thumb="http://image.tmdb.org/t/p/original/k6JoHrkyGMH0b13yZxtLKtW1npz.jpg"/><Role id="24839" filter="actor=24839" tag="William Kircher" count="3" role="Bifur/Tom Troll" thumb="http://image.tmdb.org/t/p/original/pgSkxH8LeJhNWKwG3D5690ZTLbs.jpg"/><Role id="24840" filter="actor=24840" tag="John Bell" count="4" role="Bain" thumb="http://image.tmdb.org/t/p/original/8mU0TgK5z15yXGDatbU9O51Ir5g.jpg"/><Role id="28" filter="actor=28" tag="Benedict Cumberbatch" count="12" role="Necromancer" thumb="http://image.tmdb.org/t/p/original/u4HDP1pGDV4gQZsBgYHKdgfICZz.jpg"/><Role id="24841" filter="actor=24841" tag="Dean O'Gorman" count="3" role="Fili" thumb="http://image.tmdb.org/t/p/original/lSXxMaASqm9TfnKaDNaxolEOW3A.jpg"/><Role id="24842" filter="actor=24842" tag="Manu Bennett" count="3" role="Azog" thumb="http://image.tmdb.org/t/p/original/r9P5l3CgpqpEr4ATbv8AMFqOiF.jpg"/><Role id="24843" filter="actor=24843" tag="Jed Brophy" count="4" role="Nori" thumb="http://image.tmdb.org/t/p/original/xfEiaREY2RJQosyGnGuGDcWONsX.jpg"/><Role id="24844" filter="actor=24844" tag="Adam Brown" count="4" role="Ori" thumb="http://image.tmdb.org/t/p/original/54iHvIA8ZTNfvKpb2ZxRY73A5MZ.jpg"/><Role id="24845" filter="actor=24845" tag="Stephen Hunter" count="3" role="Bombur" thumb="http://image.tmdb.org/t/p/original/xGKavu5mcGBOQMSawk9voZeEzN6.jpg"/><Field locked="1" name="titleSort"/><Extras size="0">
</Extras></Video></MediaContainer>
Thanks!
@anatolye
Would you please uninstall PMS 1.14.0 (package),
Reinstall PMS 1.13.9
Retest
PMS 1.14.0 is VERY new, and beta, it might have a bug which was not caught during testing.
I don’t mind, but the result will be the same. In fact, I’ve upgraded to 1.14.0 because I was having this problem on several of the earlier versions. Want me to downgrade and upload the logs and XML again?
Here’s one for you. PMS 1.13.4.5271
I know how this behaves on the Atom D2700 processor
From my G-drive
https://drive.google.com/open?id=1bHDRz0IBDDSRs3jEv6Kchwl5GUZq7pfN
Still failing to convert with 1.13.4 version. You want to see the logs and XML?
The files are fine, and they stream perfectly to my RasPlex player, because RasPlex can accept the native stream without transcoding. The problem only manifests itself if I try to stream (or sync) them to an Apple device (i.e. Apple TV, iPad, or iPhone), because these cannot accept the native stream format and require Plex to transcode/convert the format.
I know I can use another host to convert the video and add another version to Plex. I am just trying to make work what was working just fine for years. I’ll post logs and XML in just a minute.
Respectfully, I understand, and both used to work. Synology NAS used to be able to transcode this file in real time (for streaming) and to re-encode (for sync). Now neither works. Either something changed with the software, or something on my side. So I’d like your help in figuring out what. :slight_smile:
Here are the logs:
Plex Media Server Logs_2018-11-15_17-35-36.zip (956.3 KB)
Here’s the XML:
<MediaContainer size="1" allowSync="1" identifier="com.plexapp.plugins.library" librarySectionID="1" librarySectionTitle="Movies" librarySectionUUID="45511ee4-e748-4508-8eab-69c682064675" mediaTagPrefix="/system/bundle/media/flags/" mediaTagVersion="1531970186"><Video ratingKey="301" key="/library/metadata/301" guid="com.plexapp.agents.imdb://tt0903624?lang=en" librarySectionTitle="Movies" librarySectionID="1" librarySectionKey="/library/sections/1" studio="WingNut Films" type="movie" title="The Hobbit: An Unexpected Journey" titleSort="Hobbit 1" contentRating="PG-13" summary="Bilbo Baggins, a hobbit enjoying his quiet life, is swept into an epic quest by Gandalf the Grey and thirteen dwarves who seek to reclaim their mountain home from Smaug, the dragon." rating="6.8" viewCount="4" lastViewedAt="1488260091" year="2012" tagline="From the smallest beginnings come the greatest legends." thumb="/library/metadata/301/thumb/1542141233" art="/library/metadata/301/art/1542141233" duration="10177042" originallyAvailableAt="2012-12-14" addedAt="1362132698" updatedAt="1542141233" chapterSource="media"><Media videoResolution="1080" id="301" duration="10177042" bitrate="11069" width="1920" height="800" aspectRatio="2.35" audioChannels="6" audioCodec="dca" videoCodec="h264" container="mkv" videoFrameRate="24p" audioProfile="dts" videoProfile="high"><Part accessible="1" exists="1" id="302" key="/library/parts/302/1362132698/file.mkv" duration="10177042" file="/volume1/video/Movies/The Hobbit_ An Unexpected Journey (2012).mkv" size="14081076218" audioProfile="dts" container="mkv" deepAnalysisVersion="2" requiredBandwidths="23930,20695,17824,16107,14672,13598,12287,11666" videoProfile="high"><Stream id="1115" streamType="1" default="1" codec="h264" index="0" bitrate="9533" language="English" languageCode="eng" bitDepth="8" chromaLocation="left" chromaSubsampling="4:2:0" frameRate="23.976" hasScalingMatrix="0" height="800" level="41" profile="high" refFrames="5" requiredBandwidths="22420,19184,16315,14597,13163,12088,10778,10173" scanType="progressive" width="1920" displayTitle="English (H.264 High)"/><Stream id="1116" streamType="2" selected="1" default="1" codec="dca" index="1" channels="6" bitrate="1536" language="English" languageCode="eng" audioChannelLayout="5.1(side)" bitDepth="24" profile="dts" requiredBandwidths="1509,1509,1509,1509,1509,1509,1509,1509" samplingRate="48000" title="English" displayTitle="English (DTS 5.1(side))"/><Stream id="1117" streamType="3" codec="srt" index="2" language="English" languageCode="eng" requiredBandwidths="1,1,1,1,1,1,1,1" displayTitle="English (SRT)"/><Stream id="726" key="/library/streams/726" streamType="3" codec="idx" subIndex="3" language="Português" languageCode="por" format="vobsub" displayTitle="Português (VOBSUB)"/><Stream id="59606" key="/library/streams/59606" streamType="3" codec="idx" subIndex="1" language="Français" languageCode="fre" format="vobsub" displayTitle="Français (VOBSUB)"/><Stream id="59607" key="/library/streams/59607" streamType="3" selected="1" codec="idx" subIndex="0" language="English" languageCode="eng" format="vobsub" displayTitle="English (VOBSUB)"/><Stream id="59608" key="/library/streams/59608" streamType="3" codec="idx" subIndex="2" language="Español" languageCode="spa" format="vobsub" displayTitle="Español (VOBSUB)"/></Part></Media><Genre id="392" filter="genre=392" tag="Adventure"/><Genre id="1720" filter="genre=1720" tag="Fantasy"/><Genre id="168" filter="genre=168" tag="Action"/><Director id="24822" filter="director=24822" tag="Peter Jackson"/><Writer id="24823" filter="writer=24823" tag="Fran Walsh"/><Writer id="24824" filter="writer=24824" tag="Philippa Boyens"/><Writer id="24825" filter="writer=24825" tag="Peter Jackson"/><Writer id="24826" filter="writer=24826" tag="Guillermo del Toro"/><Producer id="6728" filter="producer=6728" tag="Carolynne Cunningham"/><Producer id="6729" filter="producer=6729" tag="Peter Jackson"/><Producer id="24846" filter="producer=24846" tag="Fran Walsh"/><Producer id="24847" filter="producer=24847" tag="Zane Weiner"/><Country id="6732" filter="country=6732" tag="New Zealand"/><Country id="23" filter="country=23" tag="USA"/><Role id="24827" filter="actor=24827" tag="Ian McKellen" role="Gandalf" thumb="http://image.tmdb.org/t/p/original/c51mP46oPgAgFf7bFWVHlScZynM.jpg"/><Role id="757" filter="actor=757" tag="Martin Freeman" role="Bilbo" thumb="http://image.tmdb.org/t/p/original/ashlWz2KDQTbo8NPUbVOwcB3zXJ.jpg"/><Role id="24828" filter="actor=24828" tag="Richard Armitage" role="Thorin" thumb="http://image.tmdb.org/t/p/original/nxA9EUBaipqb68ZbD5aGcjlT6zE.jpg"/><Role id="2934" filter="actor=2934" tag="Andy Serkis" role="Gollum" thumb="http://image.tmdb.org/t/p/original/nQRsxFveJaUIlZ4GYWDe9uJ6u2f.jpg"/><Role id="4621" filter="actor=4621" tag="Cate Blanchett" role="Galadriel" thumb="http://image.tmdb.org/t/p/original/wkWpYrtA1QCNv4B6L6fBTMRBiQ9.jpg"/><Role id="5969" filter="actor=5969" tag="Christopher Lee" role="Saruman" thumb="http://image.tmdb.org/t/p/original/3Pj0Zt1x9fwBrGGLe6DRGj8Ymmx.jpg"/><Role id="24829" filter="actor=24829" tag="Sylvester McCoy" role="Radagast" thumb="http://image.tmdb.org/t/p/original/hgM7jEkkwI0HHx3K44UE48gBbfa.jpg"/><Role id="771" filter="actor=771" tag="Ian Holm" role="Older Bilbo" thumb="http://image.tmdb.org/t/p/original/uq6Wx7PaLgaw969avH7tLHnSb0Q.jpg"/><Role id="22575" filter="actor=22575" tag="Elijah Wood" role="Frodo"/><Role id="24830" filter="actor=24830" tag="Hugo Weaving" role="Elrond" thumb="http://image.tmdb.org/t/p/original/ysED1kp94bpnweNVaDoVQQ6iy8X.jpg"/><Role id="23099" filter="actor=23099" tag="Lee Pace" role="Thranduil" thumb="http://image.tmdb.org/t/p/original/93N1awB9SAUgXTejEFCXUDfi6hP.jpg"/><Role id="24831" filter="actor=24831" tag="Conan Stevens" role="Bolg" thumb="http://image.tmdb.org/t/p/original/8mlrCTSXDInF15w6CO4IYgbPKg7.jpg"/><Role id="24832" filter="actor=24832" tag="Bret McKenzie" role="Lindir" thumb="http://image.tmdb.org/t/p/original/tEP4b5bTpSxJUHOYItg5xrZh43F.jpg"/><Role id="24833" filter="actor=24833" tag="Aidan Turner" role="Kili" thumb="http://image.tmdb.org/t/p/original/lJFfJeCKRD1h9cvBK6Dla03B42J.jpg"/><Role id="24834" filter="actor=24834" tag="James Nesbitt" role="Bofur" thumb="http://image.tmdb.org/t/p/original/n9NorD6bQfFJlW4IcJ6WoGiAKcR.jpg"/><Role id="19229" filter="actor=19229" tag="Graham McTavish" role="Dwalin"/><Role id="6716" filter="actor=6716" tag="Barry Humphries" role="Great Goblin" thumb="http://image.tmdb.org/t/p/original/bBXWmZtFbKy6Wzk1fHOCE8j6KfS.jpg"/><Role id="24835" filter="actor=24835" tag="Ken Stott" role="Balin" thumb="http://image.tmdb.org/t/p/original/aS2ZLIOYsmL8UQscHEOOFMERI4F.jpg"/><Role id="24836" filter="actor=24836" tag="Jeffrey Thomas" role="King Thror" thumb="http://image.tmdb.org/t/p/original/vLO7WJKnAxDV6IBH8fBAmsTnmzI.jpg"/><Role id="24837" filter="actor=24837" tag="Mark Hadlow" role="Dori" thumb="http://image.tmdb.org/t/p/original/qNBpe4BKgKrLF6yZrCtCjFMRFJv.jpg"/><Role id="24838" filter="actor=24838" tag="John Callen" role="Oin" thumb="http://image.tmdb.org/t/p/original/k6JoHrkyGMH0b13yZxtLKtW1npz.jpg"/><Role id="24839" filter="actor=24839" tag="William Kircher" role="Bifur/Tom Troll" thumb="http://image.tmdb.org/t/p/original/pgSkxH8LeJhNWKwG3D5690ZTLbs.jpg"/><Role id="24840" filter="actor=24840" tag="John Bell" role="Bain" thumb="http://image.tmdb.org/t/p/original/8mU0TgK5z15yXGDatbU9O51Ir5g.jpg"/><Role id="28" filter="actor=28" tag="Benedict Cumberbatch" role="Necromancer" thumb="http://image.tmdb.org/t/p/original/2NQH6clGUjJmVSOjWiVD54gurKE.jpg"/><Role id="24841" filter="actor=24841" tag="Dean O'Gorman" role="Fili" thumb="http://image.tmdb.org/t/p/original/lSXxMaASqm9TfnKaDNaxolEOW3A.jpg"/><Role id="24842" filter="actor=24842" tag="Manu Bennett" role="Azog" thumb="http://image.tmdb.org/t/p/original/r9P5l3CgpqpEr4ATbv8AMFqOiF.jpg"/><Role id="24843" filter="actor=24843" tag="Jed Brophy" role="Nori" thumb="http://image.tmdb.org/t/p/original/xfEiaREY2RJQosyGnGuGDcWONsX.jpg"/><Role id="24844" filter="actor=24844" tag="Adam Brown" role="Ori" thumb="http://image.tmdb.org/t/p/original/54iHvIA8ZTNfvKpb2ZxRY73A5MZ.jpg"/><Role id="24845" filter="actor=24845" tag="Stephen Hunter" role="Bombur" thumb="http://image.tmdb.org/t/p/original/xGKavu5mcGBOQMSawk9voZeEzN6.jpg"/><Field locked="1" name="titleSort"/><Extras size="0">
Thanks again!
Again, respectfully, I know that I’ve been able to sync this movie onto my iPhone and iPad before. It took a long time to convert, but eventually it did finish, and the movie was synced to the device. It pegged the CPU on the NAS for a while, but it did complete. Are you saying this couldn’t have happened and I’m mistaken?
I’m pretty sure I’m not limiting any bandwidth on the server, and the client is irrelevant (as I understand), because I’m executing optimization request on the server side (which is failing). I’m not trying to stream this movie.
