Hello,
It will probably be impossible but hey, I could always ask right?
I have a Synology DS918+ with Plex installed on it. I also have a lifetime Plex subscription. It is all working just fine.
Today I installed a virtual DSM machine on my Synology. After that, I installed Plex on that virtual machine. I checked the setting for the ‘use hardware acceleration’ in the settings menu.
But I see the CPU of the virtual machine going very high. It seems like Plex cannot access hardware acceleration. The CPU usage is very high.
Maybe this has more to do with my Synology device than Plex itself. But perhaps someone has a solution to make the hardware capacity for hardware transcoding available within my Synology DSM vm.
Thanks you very much again for your reply. I really appreciate it when people make effort to help others like this.
I do like Synology but I must say I haven’t had positive experience with Synology’s VMM either.
And I also think you are right about running natively on the NAS. From network/security perspective however, I would have liked it on the VM. My idea was to have a DSM VM in a different VLAN. I could then safely relatively safely forward a port (32400) to that virtual machine and wouldn’t have to expose the port to the host (the physical machine, ds918+ Synology NAS) directly to the internet.
Hm, interesting, especially what you’re mentioning about not abstracting the host. I wouldn’t want to go offtopic but if you have more information about this then I would appreciate it by PM.
