I’ve installed the Plex app on my Xbox One and imported my digital library, and there’s a couple of niggling problems I’ve noticed.
I should first explain how my system is set up:
- Xbox visuals are connected to my HD projector via HDMI.
- Xbox audio is connected to 5.1 blu ray home theatre via toslink optical cable.
- Blu ray home theatre visuals are also connected to the HD projector via HDMI (I use a switch box to select the visual source)
This means if I’m watching a blu ray disc I get the blu ray player’s 5.1 sound, and then if I’m using the Xbox I turn on the blu ray player’s Optical input and I can play games using the 5.1 sound also. And I can use both on the projector.
My first problem I’ve noticed is the image quality of movies on Flex isn’t quite as good as they are when played on the blu ray player. I’m not talking about BDs, I mean the same .mkv video file appears sharper when played on the blu ray player than on the Plex app. It’s not a huge difference, but when projected on a screen ~80" it is noticeable.
The second problem I’ve found is the sound quality of certain audio types. Namely DTS and Dolby Digital Plus.
The volume levels become really unbalanced at certain points, for example when there’s a lot of instruments playing at once. It’s difficult to explain.
At first i thought it was due to the Optical cable not being as good as HDMI, but having tried another media player on Xbox it appears to be a Plex Issue.
I have an mkv file of the movie Spectre which has DTS 5.1 sound. When played on the Xbox Plex app, the music during the opening studio logos sounds fine, as it has a few bars of creeping subdued strings. But once the gun barrel part starts (when the trumpets blast out) the sound levels get really uneven, like the player can’t quite handle the volume levels. Almost like it’s clipping, and reducing the overall volume to compensate for the bigger sound.
If I load the exact same Spectre.mkv file on the Xbox VLC app, the music sounds absolutely fine.
Just to be sure, I downloaded a copy of Spectre with Dolby Digital sound, played it on Plex, and the sound was perfect.
I had a similar issue with an episode of Fargo which had Dolby Digital Plus sound. When played through Plex the levels went nuts. The same episode but with regular Dolby Digital sound was fine when played on Plex.
So from what I can gather, the Xbox Plex app doesn’t seem to be able to cope with DTS and DD+ sound too well (at least, not through an Optical cable anyway).
Can someone suggest if there’s any way of me getting around this issue? I really love the GUI of Plex, and desperately want to keep using it, but the sound issues I’m experiencing really puts me off. The only thing I can think of is to replace any DD+/DTS files I have with DD versions, but that would take months.
