Dueling "Suspects"
SNARK ON. :slight_smile:
ATTENTION: There are 2 shows that appear to be detected as a single show because the word “the” in the title seems to be unused to differentiate between the shows. I ‘suspect’ that this has happened before. (see what I did there).
I was unable to find the newer show until I looked at the similarly names show and selected “SPLIT APART.”
Server Version#: 1.28.2.6151
Player Version#: ANY
[The Suspect (2022)]
Series #410905
[Suspect (2022)]
Series #420308
Plex Documentation → Your Media
→ Naming & Organizing Your TV Show Files
→ Naming & Organizing Your Movie Files
Add TMDB/TVDB ID tags to the folder names (and TMDB/IMDB ID tags to movie folder/file names). Plex will pick up the ID tags and list them separately.
/TV Shows
.../The Suspect (2022) {tvdb-410905}
....../Season 01
........./The Suspect (2022) s01e01.mkv
.../Suspect (2022) {tvdb-420308}
....../Season 01
........./Suspect (2022) s01e01.mkv
Thank you for sharing the solution. Much appreciated.
