Plex is confused by 'The Suspect (2022)' & 'Suspect (2022)'
I added episode 1 of the new ITV series The Suspect did a scan but it didn’t appear. I then discovered that Plex has confused The Suspect’ with ‘Suspect’ a TV series released earlier this year. www.thetvdb.com recognises that these are two different series.
The Suspect (2022) - TheTVDB.com
How to I make Plex see that ‘The Suspect (2022)’ is a different show to ‘Suspect (2022)’?
Thanks for the rapid reply but unfortunately I don’t understand what you mean. Clearly Plex is ignoring ‘The’ but I have no option to “SPLIT APART” I only know that Plex is confusing the two shows because when I go to Episode 1 of ‘Suspect (2022)’ I see that there are two versions one. If I look at ‘Get Info’ there are two files one has a duration of 23.29 (this is Suspect (2022)) while the other has a duration of 49.07 (this is The Suspect (2022)).
Apologies. I just found ‘Split Apart’ is at the Series level not at the Episode level. I have now successfully split them apart & can see the metadata for ‘The Suspect (2022)’. Thank you for the pointer.
Make use of the ID number in the show folder name. It is there for such cases.
Thanks, that looks like another good option if I encounter a similar issue in future.
