TV shows with same name
Server Version#: Version 4.90.1
In the UK, two different TV shows this year, one called “Suspect” (released 19 June), one called “The Suspect” (released 19 August).
Server doesn’t differentiate between the two, so effectively I can’t see The Suspect to play it.
Any ideas? TIA
Thanks for replying. However… gulp — how do I do that please? (You’re talking to a relative newbie in me…)
TIA
See FordGuy61’s post (#2) its a matter of file naming, and then Plex Dance them
Thanks for the suggestion, but no luck for me I’m afraid. I’ve ended up deleting the earlier “Suspect” just so I can see the newer “The Suspect”.
Its fairly easy /The Suspect (2022) {tvdb-410905}/Season 01/The Suspect (2022) s01e01.mkv as one file/folder group and /Suspect (2022) {tvdb-420308}/Season 01/Suspect (2022) s01e01.mkv as the other.
I think in OP’s case, a simple “split apart” would have done the trick.
