you mean the Bluray Support within emplexer?
BR
Peter
Yes :D
BR
Peter
Yes :D
Thanks for Info! Will test…
@20mxm2:
can not recognize any changes within the behaviour of emplexer about playing Bluray Content. Do you mean with full BR Support to get all filters now working for Bluray?
BR
Peter
@20mxm2:
BR
Peter
Hi peter911
I was only referring to the very first B6 because it would not play Blu-ray iso.
Hello,
I'm looking into buying Dune HD Base 3D and I wonder if PLEX will work on this device?
It seems like Dune is the way to go to get HD Audio passthrough from MKV. Does anyone have any experience with Dune HD Base 3D and MKV files?
Thanks in advance. :)
Base 3D and emplexer works fine. I would even say great.
Thank you very much ktd :)
Now I just need to do some research on HD Audio bitstreaming from MKV before I get this device.
Receiving my Dune Base 3D tomorrow :)
Nice! If you have the setup, can you please test HD audio bitstreaming and let me know if it worked? I had to return my Samsung BD E-8900N player because it could not do that. At a price tag of 4000 NOK (684 USD) I really expected it to be able to stream HD audio over network. I won't make the same mistake again. :)
The following link has some nice lossless testfiles:
http://www.demo-world.eu/trailers/high-definition-trailers.php
And sorry for going a bit offtopic. :)
Do you have a preferred title you would like me to test? :)
These two would be nice:
DTS HD-Master Audio Sound Check 7.1 (Lossless)
Dolby TrueHD Channel Check (Lossless)
And thank you very much :)
Hi
Can you please go back to the Trailer page and click on the part number for the link
Hi
Sure :)
Lots of parts for the 7.1 channel test so i found another DTS-HD MA file with just one part.
Dolby True HD has two parts
Just hit the trailer download button and the .rar files will download. You can only download one at a time.
Again, thank you very much. :)
Sure :)
I can confirm, All sound tests work :D
Excellent!
Can't beat plex and HD audio.
Thank you very much. :)
Excellent!
No problem!!! :D
The Dune Base 3D works great with emplexer, You will not be disappointed.
@newloran2 Is it possible for you to do a small patch so Unwatch is the default filter until v0.2 goes live?
I just replaced my bedroom ATV2 for a Dune 303D so now it would really be a big help if possible.
My Base 3D is mostly for movies and there I use yaDis but now I use emplexer 100% for Tv shows also.
@newloran2 - emplexer works very well on my dune d1 and dune lite - thanks (donated today for your hard work…)
my setup:
synology ds713+ - plex - dune-emplexer
emplexer setup smb-playback.
soon i will add a second folder for movies to plex.
question:
can emplexer handle 2 different smb locations for movies in combination with plex and emplexer (i don’t want to setup nfs on my ds713+ or use dlna on my dune players…)
best regards
torm3nt8r
ktd,
i will submit one patch to select default filter :).
@newloran2 - emplexer works very well on my dune d1 and dune lite - thanks (donated today for your hard work...)
my setup:
question:
can emplexer handle 2 different smb locations for movies in combination with plex and emplexer (i don't want to setup nfs on my ds713+ or use dlna on my dune players...)
best regards
torm3nt8r
