Dune player
ktd,
i will submit one patch to select default filter :)
Thank you so much!
I will give you another cold beer to enoy now when it's summer. :)
Hi newloran2,
any News about a First release of your emplexer 0.2?
Thanks for the greatest Plugin!
BR
Peter
Hi newloran2,
BR
Peter
Peter, i have no previsions, in the last months i had only a small time to spend with the emplexer, but i will have time again soon and i will work again in the project.
@newloran: sounds great, many thanks!
BR
Peter
ktd,
i will submit one patch to select default filter :).
Do you know when the patch will be ready?
if all goes as expected, in a few hours :).
Lovely! Please post here when the update is live so I don’t have to check github every 5 min. :slight_smile:
Hello people,
I finally have time to emplexer again :) for now i added a few things to current version (all this are present in the future 0.2 release).
Music support:
 particularly i'm not a music user on dune,any suggestion to make this feature better is very welcome.
To play one song, press enter on a music.
To play all musics from a folder/filter press play on a filter
Searches are supported :).
Resume playback popup:
 if you file are partialy viewd emplexer show a popup to resume or start from begining.
 The setup have an option to control this ( ask , resume without ask or start from begining without ask ).
Tkd: Default filters  :).
 On setup you able to configure "Default Filters" by section type.
Please, if possible test these new features and report to me any bug or suggest any improvement.
Hi newloran2
Great new update, emplexer gets better & better
Thanks for all your hard work
ktd: Default filters :).
Thank you so much! Default filters works great.
Resume popup is also very nice.
Hi newloran2,
many thanks for your work, cant wait until your 0.2 release…!
BR
Peter
great - thanks for the work on this great plugin!!!
Hi newloran2,
do you think it is possible to get all filters and resuming options working for Bluray folders in a short update?
many thanks + BR
Peter
hi newloran2,
tested new version of emplexer - resume does not always work correct....
when i start a new movie without resume - after watching some minutes - restart of movie - there is no resume option....
if resume is shown - movie starts correct at time of resume - but when i watch some minutes - restart the movie - it shows resume time from first start....
but i tested a second movie, where it starts correct at resume and then saves the correct resume time.
(playback with dune playback and nfs....)
best regards
torm3nt8r
hello,
need help - please.
i need the old version of emplexer before 15.06. - where can i download it? or can anyone send me the old version?
thanks
torm3nt8r
hello,
need help - please.
thanks
torm3nt8r
I have emplexer build date 14 April 2013
@20mxm2
thanks - i just found my old version on an sd card lying around…
First: Thx for your impressive work. Emplexer is great. I am happy that you change your mind and i can donate for more beers.
Second: I have a Dune HD D1 with the newest beta firmware. Under Applications i can start emplexer without any problems. If i add emplexer to the favorites i always get the error "can't sart application". I already uninstall emplexer, deleted the system cache and install again. The error is still the same. Any ideas?
Go to emplexer settings and make sure that “Add to main screen” is set to Yes.
hi newloran2,
best regards
torm3nt8r
I was having the same problem, I've now gone back to build date 14 june.
@ newloran can you please add version numbers to the next update.
