Dune player
Hi newloran2,
do you think it is possible to get all filters and resuming options working for Bluray folders in a short update?
many thanks + BR
Peter
Peter,
All filters work with BR and DVDS ( or not?) only resume don't.
I need to do more investigations about resume on BR and isos, but i think this is not possible because the emplexer don't store play time on isos (BR/DVD) and for folders I do not know where play time information are located.
hi newloran2,
tested new version of emplexer - resume does not always work correct....
when i start a new movie without resume - after watching some minutes - restart of movie - there is no resume option....
if resume is shown - movie starts correct at time of resume - but when i watch some minutes - restart the movie - it shows resume time from first start....
but i tested a second movie, where it starts correct at resume and then saves the correct resume time.
(playback with dune playback and nfs....)
best regards
torm3nt8r
torm3nt8r,
Thanks for the warning, I will make a fix ASAP.
First: Thx for your impressive work. Emplexer is great. I am happy that you change your mind and i can donate for more beers.
Second: I have a Dune HD D1 with the newest beta firmware. Under Applications i can start emplexer without any problems. If i add emplexer to the favorites i always get the error "can't sart application". I already uninstall emplexer, deleted the system cache and install again. The error is still the same. Any ideas?
Visi,
Thank's for the Bears :).
About the bug, i have this issue to, i think this is a firmware bug.
For my case remove the favorite and add again solve the problem.
I was having the same problem, I've now gone back to build date 14 june.
@ newloran can you please add version numbers to the next update.
20mxm2, i'm working on a version system, i like to add more functionality than a simple number.
To any one that have problems and like to get the older versions, git hub have a list with all versions.
https://github.com/newloran2/emplexer/commits/master/dune_plugin_emplexer.zip
To download the package click on browser code  and View Raw.
Thanks all who report bugs, make suggestions, disseminate the plugin and pay me beers :).
Hi newloran2,
thanks for answering. No, the "On Deck" Filter does not work nor the resume option...
Maybe you could do some fixes in 0.2?
Great work + go on!
BR
Peter
Question, what is it when some sections give me this back: "the area you are trying to access does not return any xml (404)"
While others work fine, with 2 of them I get this error (Movies and Short Movies).
Using NFS Manually setting the path to the synology nas i use for plex.
@ newloran2
Thanks for the info update!!!   :)
Visi,
I alreadey tried that, but it doesn't solve the error. I always tried to create the shourtcout from the application section. If i create it from the Mainscreen it works perfect. (Thx @ ktd for the impulse  ;))
tcviper,
If you can simulate this issue and send-me you emplexer.log i try to solve.
I think this is related with the image cache, but i never can repoduce that issue.
Your welcome Visi. :wink:
That issue was bugging me like hell until I found the “fix” in emplexer settings.
newloran2: Sent in PM :)
very cool! any plans to add subtitles support? thanks :-)
It already supports subtitles ;)
Hi newloran2,
would it be possible to show the Dune/ Emplexer as a Client to start Movies via Plexapp from iPad or iPhone?
Thanks,
BR
Peter
I tried to install Emplexer from both network drive and attached USB, but I get error "failed to install application".
You need the .zip-file for installation and the Memory Storage.
BR
Peter
BR
Peter
Yes..I have that.  I'm supposed to select the zip file and hit enter.  Then I get an error.
the name of your installing file is:
dune_plungin_emplexer.zip?
BR
Peter
BR
Peter
That's correct.
install Build Date 14 April, its the most stable, out of all the emplexer releases.
I always go back to Build date 14 April if i have issues.
Hi-
Just installed emplexer on my Dune  (Base 3D). I am able to see the movie art on the Dune, but was extremely dissapointed with the streaming via Plex. The streaming from my Synology diskstation was great using NFS. So I was wondering if I can use emplexer just for the interface, but have it stream the files from the NAS to the Dune directly instead of trying to transcode them via Plex?
THanks
You can select NFS as streaming protocol in the emplexer settings.
But I'll be streaming via Plex instead of via Dune, right? I thought the advantage of the Dune was all of the formats it supports natively. I don't really want a transcoded stream via Plex. I just want the movie posters to appear on the Dune.
