You will stream the files directly.
OK. I tried to configure it to use NFS under the setup->emplexer menu. I used the IP of the synology and the 32400 port. But when I click on the movie poster, nothing happens. It won't play now.
Is there any other critical setting? For playback type, do I chose Dune Playback or Vod Playback? Also, it doesn't seem like the save button at the bottom of the emplexer setup screen is working because there is no indication that it saved the settings.
You shouldn’t use port 32400 in the path to the files/sections on your nas. 32400 is just for the Plex interface.
Ex. nfs://192.168.1.2:/videos/movies. If you have user and pass configured you have to add them in the path.
Save works but as you noticed nothing happens when you push it.
Good luck!
You shouldn't use port 32400 in the path to the files/sections on your nas. 32400 is just for the Plex interface.
Save works but as you noticed nothing happens when you push it. :)
Good luck!
We are talking about the emplexer setup on the Dune, right? It is asking for the Plex IP and Plex Port followed by the connection type. For connection type, I selected NFS. But I'm confused what I should enter for Plex IP and Plex Port. Are you saying I should enter the IP address and port of the NAS? But for IP use your example with IP:/volume1/movies...
Same Problem here; i tried everything to get playing via nfs. Nothing solve the Problem, i think it`s an issue of the newer Dune Models (3D). I can only streaming via http, but with native Dune Player. On Deck and Resume does not work either, maybe a problem of newer models too?!
But all in all best Plugin so far... :rolleyes:
BR
Peter
Emplexer installs without issues on my Dune HD Base 3D.Hi,
BR
Peter
Have you enabled NFS on your symbology?
Hi 20mxm2,
i use a Qnap NAS, but no chance to Stream via nfs. Whenever i configure nfs within emplexer, nothing happens, After trying to Play a movie…
BR
Peter
Hi 20mxm2,
i use a Qnap NAS, but no chance to Stream via nfs. Whenever i configure nfs within emplexer, nothing happens, After trying to Play a movie....
BR
Peter
Have you seen this video how to setup SMB & NFS
http://www.youtube.com/watch?v=kOkafwPzBXc
install Build Date 14 April, its the most stable, out of all the emplexer releases.
I always go back to Build date 14 April if i have issues.
OK, this worked. I was able to install and stream to my Dune.
Some issues:
Music library - I can drill down into an album but there's nothing there to play. Works fine on the PC where I have the PMS. Location is similar to movies and shows so that should not be a problem.
Channels - Other than iTunes, I see icons but no names. For example HD trailers, i just see a generic icon. I drill down and I see more icons, but don't know what they are since they're not named.
Some issues:
Unfortunately Build date 14 April does not work with music.
It's a bit drastic, but it worked for me when I had problems trying to install emplexer a few months back
1) Delete emplexer
2) Format your USB to create a new system storage
3) Full Factory reset
You can now try to install the latest emplexer :)
You have Plex IP and port setup right since you can connect to your Plex Server.
When you slect NFS as Connectio Type you have to configure the path to each section.
Defult they will look something like this but you have to edit them so that they point to your NAS and share.
Since my Plex server is running on my NAS, the IP addresses are the same, just a different port. So I looked at my Nfs advanced configuration, and the default setup was correct. It had the ip address of the NAS/Plex server followed by the mount, i.e.
172.16.12.103:/volume1/Movies
As you said, the ip address and port must be ok in the Plex setup because I can see the movie posters. But it still won't play anything when I click the poster as Peter911 stated. The playback was perfect when I just used the Dune player's built-in nfs setup, so I know nfs is configured properly on the NAS (synology).
I would attach some screenshots, but I can't figure out how to do that.
@20mxm2:
Same mistake here, all Settings are correct, but nothing happened...
Thanks for trying to help;-)
BR
Peter
Edit: nfs/ smb streaming works perfectly via normal Dune Interface!
@20mxm2:
Same mistake here, all Settings are correct, but nothing happened...Thanks for trying to help;-)
BR
PeterEdit: nfs/ smb streaming works perfectly via normal Dune Interface!
Change the V to lower case in volumes
I do have it as lower case V. The screenshot above is from ktd.
Should I chose Dune playback or Vod playback?
Also, can someone confirm they have this working with a Dune base 3D model? All I want to use Plex for is the movie posters so I can have a nicer interface than the dune provides. Without a pc, I can't use zappiti. What is everyone else doing who has a mac?
Hello people, and sorry to delayed responses.
Hi newloran2,
would it be possible to show the Dune/ Emplexer as a Client to start Movies via Plexapp from iPad or iPhone?
Thanks,
BR
Peter
Wait for news in the near future :).
I tried to install Emplexer from both network drive and attached USB, but I get error "failed to install application".
If possible please send-me the file that you try to install.
Hi-
Just installed emplexer on my Dune (Base 3D). I am able to see the movie art on the Dune, but was extremely dissapointed with the streaming via Plex. The streaming from my Synology diskstation was great using NFS. So I was wondering if I can use emplexer just for the interface, but have it stream the files from the NAS to the Dune directly instead of trying to transcode them via Plex?
THanks
The emplexer don't use transcoded session, only direct play are supported.
BR
Peter
Hi 20mxm2,
BR
Peter
@20mxm2:
BR
Peter911 and hoops129, try to use dune ip control to test nfs playback http://dune-hd.com/firmware/ip_control/dune_ip_control_overview.txt, this is a good way to identity what's happend.
if you like add-me on gtalk and i help better (send-me pm).
Some issues:
1) Delete emplexer
Please try the steps that mxm2 said, music library are supported in the last version and i will improve Channels area soon.
If you want, feel free to open an issue on github.
Dune playback are the default dune player, that player support all things dune supported, in the current version this player are experimental and has some bugs.
Vod Playback are the dune plugin player, has almost all the features of the default player, but some other important things are missing (like subtitle settings).
Before starting the development of emplexer I tried to use dunex, but had not have much success.After that I used for some time the yadis in a windows vm, worked very well, but the fact of having to start a vm and reprocess the collection every time something new appears bothered me a lot.
OK. I sent you a pm. Getting this to work would be great. How do I check the version of emplexer? Maybe I grabbed an old version?
Also, is there any configuration to do with the Plex servers to get a stutter free picture on clients? Currently, it's unusable. Could it be the Synology causing the problem since I'm hosting the Plex server from there?
Hi newloran2,
many thanks for posting:-) It would be very great to "hear" some news in the near future...
I will try to test what you have suggested, when i get home!
Thanks + BR
Peter
PS: Have you noticed the PlexApp for the PocornHour?
Stutter free pictures? Sorry i don't understand what you meant.
Hi newloran2,
Thanks + BR
PeterPS: Have you noticed the PlexApp for the PocornHour?
Good things are coming :).
Do you have one popcorn hour? i really like to analyse this package, maybe with small changes this client works on dune to.
