Dune player
change the \ for / like that smb://user:pass@192.168.10.x/volume1/movies
if you that don't work send-me your emplexer log and i'll help you better.
Thanks newloran2 that worked and even now nfs works so I can show srt subtiles something which didnt worked on smb either.
:) I told to you, the Synology is a very good NAS (i'm very happy with my DS712+).
I'm confused, when you select nfs/smb the screen to configure nfs/smb path does not appear?
Unless you go for a 213j as I did and noticed that it's unsupported while its predecessor 212j is supported :(
i am using the latest release, but i have still problems using smb. Every time i enter the smb advanced configuration the settings inside the emplexer configuration menu there are the default values. As far as i understand the emplexer log http is used and not smb. The delay untill the movie starts to play is arround 30 untill 60 seconds
My server directory is: "E:\ServerFolders\Videos\Filme" so i use this "smb://mustermann:4711@192.168.0.1/Videos/Filme". My Server IP is the 192.168.0.1 and the network share is "Videos"
Arn't the vaule not saved because it is wrong?
Visi,
Sorry the last release intent to fix this issue but i'm commited the wrong package.
I'm commited one new package just now, download and test again.
Hi newloran2,
The latest emplexer does not launch
Hi newloran2,
Thanks for the alert 20mxm2.
Try again :).
Try again :).
It's now working but the emplexer Logo is blank
Holy crap, Try again :(.
Everything is now working but I had to clear the system storage first. then reinstall emplexer again. :)
I will send you the log file .
It works perfect now. Thx at newloran2!
Hi newloran2,
are there any news on emplexer 2.0? I will help in any way, but i can not code...;-(
Thanks for the great App.
BR
Peter
Hi newloran2,
BR
Peter
I think he must be very busy with work at the moment  :)
Hi newloran2,
thanks for you for Plex Dune Plug-in..
Let me inform you about my experiences.
I use it with a Dune HD TV-101 and a QNAP 239 Pro NAS.
The tested connection types are http and nfs. Both are ok for me.
The plug-in works great in Vod Playback Type.
But in Dune Playback mode movie playback doesn't work for me at all. I have the message: "Could not determine input format"
After this message it is not enough to switch on Vod Playback Type again and restart my Dune but before restart I need to unplug it from power. Dune Playback mode would be important for  handle subtitles. Or would it be possible in Vod Playback ?
Thanks again for your work.
Hi newloran2,
BR
Peter
Hi Peter,
I'm analyzing some alternatives to add new features in 2.0, that is why the delay of the release.
But look at a small spoiler of a feature I'm working on right now :).
New things will come :).
Hi newloran2,
Hello vesisa,
Plese, reproduce that error and send me your emplexer log.
To see the subtitles in Vod Playback go to setup -> Playback -> subtitles -> Enable subtitles by default for files.
Please, feel free to report any bug or request some functionality.
Hi newloran2
You tease lol
Hello vesisa,
Hello, newloran2, typically I have films with two internal subtitles and audio streams.(My native language and English) The setting "Enable subtitles by default for files" was ok, but unfortunately "Default subtitles preference for files" was external not internal.  It was the problem. But in Vod Playback it is not possible to switch between two subtitles in pop up menu and "Quick toggling of single subtitles" is not working, too. I prefer this functions for language learning. Is there a chance to solve these problems, please ?
Thanks again, for your work and help. I am sending you the enplorer.log soon.
Hi newloran2,
wow, great news! Please let us know, if we can help!
Great App, go on!
BR
Peter
Hi people look at this : ) .
[media]http://www.youtube.com/watch?v=mebdSiKHZrY&feature=youtu.be[/media]
can't wait!!!
more info please  :D
Amazing
