After Emplexer reinstall, using NFS, Blur Ray Rip to MKV played fine just once, after that no more MKV playback. BDMV folders play fine but when I try to play any MKV it takes me out of emplexer, the screen goes black and I am taken to the Dune Main Screen, If I try to play an MKV file again, same problem again and again.
I attached the new logs to see if they are of any help to you.
Thanks for your help
JAH
This problem only happens in Dune Playback mode, on vod Playback all is fine, any idea why?
Started having a minor issue with resuming today. It seems that I cannot get the popup that asks whether you want to resume from the last position, or start from the beginning, on a partially watched program. I have always had it set "ask' but I no longer get the dialog. No changes had been made to the settings when this started happening. I have since switched between 'ask' and 'resume' a few times to see if I can get it to stick, with no luck. Anyone else notice this happening?
I am having an issue with some coverart for movies - for 2 movies the cover art does not show up and it simply shows a screen grab from the movie, and for another movie I have changed the cover in the plex app, however the plugin is still showing the old artwork.
I have tried setting the "use cache" to No in settings however this make no difference - is there a way of manually forcing a re-read of the cover art?
Recently there was a problem with Emplexer. At opening of some sections there is an error "the area you are trying to access does not return any xml. (404)"
I use dune hd base 3d firmware 130515_2104_b6.
plex server 0.9.8.18.290-11b7fdd.
Connection Type smb or http, it does not influence a problem.
Whether probably to add possibility to disconnect this check or to make its more loyal?
(As I have understood check on obligatory presence photo in the film description works, but it not always turns out, for example the file of a film has not finished loading), and from for it there is inaccessible all section.
ps. On ios in the appendix plex. This problem is not present
When this happened to me it was because there where some movies that weren't scrapped, after I scrapped them the error disappeared.
Sorry for my long absence, I've been quite busy in the last months.
I took the end of the year and worked hard in emplexer 2.0, and made some progress.
At the moment some features present in the last version are missing, but for those with curiosity about how is getting can install the 2.0 branch https://github.com/newloran2/emplexer/tree/2.0.
For now only the playback via http is available ( for all sections), but soon nfs and smb are back.
The major change in this version was the addition of templates.
Now it is possible to completely (or almost) customize emplexer with the use of templates, later this week I'll make a tutorial of how to use them.
I tried to installversion 2.0but without success.In myDuneI haven't a HD installed but only a SD memory cardon which it isinstalled and runningthe old version.I createdthe folderdune_plugins/emplexer2 on the SD,I restarted thedunes and in the applicationsIdo not seeanynew application.Is it possible thatthe new versionon theSD memory carddoes not work?
Thank you.
P.S.:I proceededto the Italian translation.
Upgrade!!!
I installed a new HD and on the HD the installation is OK, but when I launch the emplexer 2.0 I have this error "Unhandled PHP plugin error. Call the PHP plugin vendor".
Completed the italian translation and posted on Transifex.
I've recompressed contents of the archive as dune_plugin_emplexer2.zip and it was succesfully installed by dune plugin installer. However, it doesn't work for me, and application setup doesn't work either.
I think we're better wait for more stable version :D
Meanwhile, i've made Russian translation, but for some reason i cannot do the translation on the Transifex (it says, that i must be member of some group or something), so i'll just attach translated file here.
First I would like to say thanks to all who are helping in the translation of texts and then I want to apologize for the last post, I forgot to remove some settings for my test environment.
To compensate I fixed some problems and finally added a versioning system + auto update.
In this version only the http playback mode is available, then I'll include the other features present in version 1.0 and some that are new in 2.0.
I'll do as soon as possible also a tutorial on skins in emplexer (I'm particularly proud about that part :)).
Wow! I registered on the forum just to say how great I think version 2 is. Sure, there are some things to fix, but it shows great promise. Keep up the good work!
