for now I'm using the 1.x to see my movies too, but if anything goes wrong very soon it will be possible to upgrade to 2.x version :).
Just ordered today a Dune Base HD 3D. I've installed PMS on a QNAP TS-870U-RP. Is there a link with some stupid-proof step-by-step instructions for installing newloran2 plugin?
Thanks,
Stefano
Thanks,
Stefano
Hello Stefano,
Try my github readme https://github.com/newloran2/emplexer
…very soon it will be possible to upgrade to 2.x version
Hi newloran2,
this would be awesome :rolleyes:
Many thanks for development on employer 2.0.
BR
Peter
Ok, now the version 2.0B01 works wonders. Looking forward to new updates.
Hello Flavio,
I'm italian and I've read that you've installed Plex on Synology with emplexer. I'll ordered a Dune Base HD 3D and I'll receive it, hopefully, at the begging of the next week. I've installed Plex Media Server on a QNAP and it's working wonderfully. I'll probably disturb you for some tips in installing emplexer.
Thank You and Bye,
Stefano
Ok Stefano.
Ciao.
Ok Stefano.
Ciao.
Ciao Flavio,
oggi volevo mettermi a scaricare il file zip dal link evidenziato da newloran2 ma non ho la più pallida idea di come fare. Non c'è un pulsante del tipo "Save As" o simile. Hai qualche dritta? (utilizzo Mavericks).
Ciao e grazie
Stefano
Dalla pagina che ti ha linkato newloran2 a destra c'è un link "Downolad ZIP" devi scaricare quello. Ciao.
Thank you Flavio I've downloaded the zip file and installed it. Everything works good. Grazie mille :-)
Congratulation to newloran2 for his work. Emplexer is rapid like upnp mode and good-looking in a pled-like manner.
I've a couple of question about movie navigation and file info. Is it possible to use skip buttons for moving to next/prev track like in upnp mode and pref/next buttons for fast-forward and fast-rewind? Is there a way to show up the info window that normally appears during playback pressing info button?
Recently there was a problem with Emplexer. At opening of some sections there is an error “the area you are trying to access does not return any xml. (404)”
Seems like once you have selected a filter it cannot be set back to "all". On my system everything was working but I get these errors when just trying to select the movies, ( The first filter is Unwatched ) and that returns no movies for me on web interface, selecting another filter shows me movies.
So .... How do I :
1. Get a filter called all
2. Cancel the filtering once it has been selected
( Even a reboot did not remove it from power off )
Very nice stuff, so sick and tired of trying to keep the dune up to date with something easy enough for the family to use. I put plex in beside my xbmc install just for this !
Correction, The unwatched filter works in the web browser but not in the dune plugin. But the problem does appear to be associated with that filter.
Yes, the skip, fast-forward and fast-rewind all works. The info windows is not working in version 2 but is working in version 1.
I've tried, skips aren't working. Fast FWD-RWD do a 10 sec. skip instead of 2X/4X/8X...
Subtitles, too aren't working. When I press Subtitles button on RC it doesn't appear the subtitles window.
Thank you for your kind answer newloran2, I'll give it a try as soon as possible. Bye
Stefano
It seems, that emplexer doesn't working under the latest FW 131224_0132_B8. Neither on Dune HD Connect nor Smart D1.
When I'm pressing Enter on the emplexer icon just nothing happens. When I've tried to reinstall and then press "Launch", i've get "Impossible to launch application" error.
Version 0.2, however, running and working, but in it's current state it's nearly unusable (((
Enter in emplexer options and re-enter NAS-ip-address, I've got the same issue and solved it.
I've managed to fix it by making this change in dune_plugin.xml:
from
emplexer_section_secreen
to
main
