SD card or usb :)
Any particular / minimum size or speed?
SD card or usb :)
Perfect. Assume things like fast forward and rewind work? Also, resume?* 1GB will be fine.
* speed of the sd card or usb shouldn't be an issue.
Do I actually need to have an SD card or USB stick plugged in at all if it's connected to my network for the install?
There's limited places to buy the B1 in the UK. I can only see Ripcaster?
Hi there ...
I've used emplexer V1 until yesterday running fine.
After installing emplexer 2.0-B02 on my Dune 303D it says
"System error Unhandled PHP plugin error. Call the PHP plugin vendor."
Can someone help me to fix this problem?
Hi Newloran2,
I'm reading this thread with great interest!
I had a Dune Smart D1 a year ago but sold it. The reason why I sold it was I didn't liked the standard Dune interface. On the other hand I liked the Dune stability. Meanwhile I discovered Plex and start using it. Now I read this thread.., it's really awesome that I can use a Dune player in co-operation with Plex.Server From what I understand Emplexer can use hd audio like DTS-HD MA and True-HD. It plays al movies direct play. A question can Emplexer use internal PGS subtitles from a MKV? If so then i'm hurry to ebay to buy a Dune.
I really like to see myplex integrated with transcoding.., so I can buy a Dune for my sister and here kids so the family can remotely watch movies from my Server/NAS.
I will follow this thread closely! Lots of success with your create project and thank you!
you can use emploxer V1 or V2-B01. I think newloran2 is still working on fixing issues and some new features :rolleyes:
Deleted, as all sorted :)
I've just got emplexer installed on my 303d, but I'm unable to use either smb or nfs. I've tried both with and without Dune mode and it either returns empty playlist, or media not supported. HTTP works fine, but would rather use smb or nfs as it's faster and subtitles.
However, if I access the folders and files directly through Dune and network sharing and not emplexer, it plays back fine.
Any ideas?
PS. Even on http, loving this, especially TrueHD and HD-MA playback! Keep up the great work!
Hi Newloran2,
Hello MvL,
Emplexer support any file or subtitles that Dune support (Internal mkv PGS to ).
MyPlex are in my todo list to v2.
A lot of ideas for new features :) .
Any ideas?
WannabeMKII, send-me your emplexer.log and i'll help you to configure your nfs on v1 or wait a litle for the next v2 release :).
Sorry, couple of basic questions;WannabeMKII, send-me your emplexer.log and i'll help you to configure your nfs on v1 or wait a litle for the next v2 release :).
1. Where / how do I find the log file?
2. When is the next v2 release due?
Thanks.
Newloran2, Thank you for the reply.
I suppose Emplexer does also HD-audio cause the Dune also suport this..?
A good friend of my has a Dune. So i think i'm going to start testing Emplexer verion 1. I'm realy looking foward for version 2 of Emplexer!
You only need to have a internal hdd, or a usb storage attached to your Dune.After the first execution, the emplexer will create a directory named dune_plugin_logs in your hdd/usb storage, send me all the files that are in dune_plugin_logs/emplexer.If not goes wrong i will release the next version in the next week.
I managed to get the smb working, it had added a : rather than a / in the path and now works fine!
Looking forward to v2 next week and keep up the top work newloran2!
A litle question.
In which machine/platform you guys usually use your Plex Media Server?
Mac Mini and Mac OS X.
iMac late 2012. But using the NAS PMS software with my Synology DS412+
A litle question.
QNAP TS-870U-RP
Qnap ts 439 pro II+
BR
Peter
Synology DS1512
