Dune player
I'm running Plex Media Server on ClearOS Proffesional. This is a Linux gateway/server distro. It's a Haswell Xeon E3-1275. My storage device is a Synology Rackstation.
WHS 2011 Haswell Pentium
Synology DS710+
QNAP TS-219P
Openmediavault - i3-2120, 4gb ram
v 0.9.9.0.308-7e8496a on a Synology DS1812+ running DSM 5.0
To all who collaborate with translations of emplexer.
Dear, I'm sorry, by an oversight on my part, I ended up upgrading translations_en.json with strings en_us, which caused the transifex simply remove all translations
Unfortunately I had not yet versioned translations and so I ended up not being able to recover them, I ask everyone to forgive me and if possible continue helping in the project.
From now on I will always versioning of all strings added to avoid problems like this.
Sorry again and thanks to everyone who helped and who want to continue helping.
I'm currently using a Dune 303D, but am unable to install v2 of emplexer, as when it starts after installation, I get a 'php error' on startup?
I've confirmed this with another Dune 303D user.
Any ideas, as keen to try the latest and greatest  :D
I emailed  newloran2 about the php error.  He uploaded his test code by mistake, it will be corrected tomorrow :)
Ah ha, perfect.
How do we know when the new version is available?
Ah ha, perfect.
He will announce the new version in this thread.
I think, if you're registered in Github then you'll get a mail?
Hi newloran2,
thanks. Let me know if i can help you out, but i can not code…
BR
Peter
He will announce the new version in this tread.
Perfect, I'll keep a look out :)
Hello people,
emplexer 2.0B03 finaly arrived, to download the package and see what's new: https://github.com/newloran2/emplexer/releases.
I need to remark some points here:
1) Translations: Thank's for any one who helped with that.
2) Register as player: Now works on iOS, Android and probably works on Windows Phone(i don't have one, please test and tell me if work on it).
3) Setup screen:
    a) Nfs setup:  Now are much more easy (i Think) to map PMS sections to your nfs exports.
    b) Language: Thank's again for every one who helped with that.
    c) Media server: The screen to setup your plex ip and port.
PS: i have some internal expressive changes since b02, i think i introduce some bugs, report-me if you find one.
PS2: SMB setup will come on next release.
New user to Dune. Only bought one to use this plugin and hopefully replace my HTPC in the main watching room.
Installed the new B3 version and connected to my PMS, can browse the collection but nothing plays?
I have the same problem
Same here. It seems, that the problem is in NFS exports. Emplexer tries to use local server paths, not the exports. For example, in my case, i have a server path /share/HDA_DATA/Qmultimedia, which is exported as /Qmultimedia, so should be accessed as nfs://192.168.0.250/Qmultimedia, but emplexer tries to access it as nfs://192.168.0.250/share/HDA_DATA/Qmultimedia.
Cannot start the new b3 Build on my Dune TV303D - "Unhandled PHP Plugin err. Call the PHP plugin vendor"... :(
People,
Sorry about that broken release, i'm working on fixes and soon I'll update the b03.
