People,
Sorry about that broken release, i'm working on fixes and soon I'll update the b03.
No need to apologise but looking forward to the update.
People,
After install the new build the same php plugin error appears... :(
Hi newloran2,
many thanks, update went fine and emplexer registers as Player on iOS;-)
Is it yet possible to make GUI changes, maybe to start screen like the original PHT-Skin? This would be very, very nice! Keep up your awesome work!
BR
Peter
MikeDelta, you can please send-me your log?
Hi newloran2,
BR
Peter
Thanks newloran2 for answering:-)
Ok, please can you make the Plex filters working (On Deck, recently watched/ added, etc.)
BR
Peter
Yes, i will... what must i do to create the logs?
I can't see external subtitles, only those included in the MKV. I think this has to do with emplexer because when not using the plugin it works.
Attach one internal hdd or a usb stick to your dune, after that create a folder in the root of that stick/hdd named dune_plugin_logs.
Reboot your dune and try to access the emplexer again, all logs will be in dune_plugin_logs.
I´ve attached the logfile... thanks for your help! :)
MikeDelta, your PMS has password?
Try to disable it in Settings -> Show Advanced Settings -> myPlex -> Require authentication on local networks.
@newloran2:
Yes, i need this because of my children! Without a password it works... bad luck for me, is any chance that your plugin support this in the future?
@newloran2:
MikeDelta, myPlex integration is on my TODO and will come to emplexer at some point, but yours is a case that I never thought before.
I have some questions about:
1) if you have a media player on your tv you login to myPlex every time you go see your videos?
2) You logout after?
3) As you do for your password? The standard remote control does not use this bothers you?
4) Do you have (or every one) some suggestions to minimize the user/password input with a remote control?
Hi Newloran!
On my Dune TV303D i haven´t an option to Login to myPlex - i use DNLA to communicate with my DS413 and have full Access to all media content. I need the password option only for the Plex App on the iPADs of my children. I shared some media libraries for them and the only way to select which library they have the permission to use and others not in my local home network (i have some libraries with 18+ content) is to use the password option in the Plex Media Server. Both children have a plex account, login to this account in the iPad Plex App and have only access to the library i have shared.
Does anyone who has windows phone can tell me if it now recognizes emplexer as player?
I update manually (autoupdate don't work for me) and all works well. I can use my iPhone and also the WinPhone. In WinPhone I can see the emplexer as player and I can start the movies but I can't pause, stop or skip.
All,
I am having an issue with some coverart for movies - for 2 movies the cover art does not show up and it simply shows a screen grab from the movie, and for another movie I have changed the cover in the plex app, however the plugin is still showing the old artwork.
I have tried setting the "use cache" to No in settings however this make no difference - is there a way of manually forcing a re-read of the cover art?
Cheers
I'm bringing up this question once again, cause i've got the same issue. Is there any fix or workaround?
Cannot start the new b3 Build on my Dune TV303D - "Unhandled PHP Plugin err. Call the PHP plugin vendor"... :(
I have the same problem on my TV303D. Created dune_plugin_logs on my usb drive, but nothing happened. First Emplexer works ok.
P.S. Downloaded again from https://github.com/newloran2/emplexer/releases and now plugin working fine. Looks promising.
hello, i tried to install emplexer2, but with no success. Is there anywhere i can see how to install this? I have the initial version of employer (appr 8 months old binaries). In the readme file, i should create the dune_plugins folder in root on the dune HD 303D but i cannot see where to find the root folder ( have both sd card, usb stick and a hard disk installed).
Thanks for help
Best regards
Thomas
Thanks for help
Best regards
Thomas
Installs like the rest of the plugins. From usb flash drive. See my link.
eugene2878 it works like a charm! it works. thanks a lot.
