Dune player
Welcome back newloran2, nice to "see" you again with us.
@newloran2
hows it going with the new version?
im excited... ;)
Any chance of adding access to "extra" content to Emplexer (like trailers, DVD extras, local extras)?
Thank's
@newloran2
im excited... ;)
I'm continually working on the next version, but i don't have much time to work on emplexer now.
To the next release i'm working on a little better skin (with multiple views support) and the nfs/smb support.
My intention is make the next release a valid replacement to v1.
Yes, this is my todo, i will try to add this in the next release.
Very excited for the next release, thanks.
Excited too! Can't wait! :) Anyone know if it's possible to autostart emplexer when dune boots?
Add to favorites then go into the favorites folder and use the popup menu button and choose "Launch on Power-on".
Great! Anyone knows if Dune Base 3D can handle PGS subtitles inside MKV without trouble? Also special ones lite custom font i for example Avatar?
Hi all!
Dear newloran2!
I installed 0.2 on my Dune HD Base 3.0 with last stable firmware 150227_0032_b9. There was a message 'plugin installed' but when I run it nothing happens. Could you please explain what has to be checked?
And one more question. How to install v2.0? I can read in the instruction
create in the root directory "/" on this disc, a directory called dune_plugins.
download the  2.0branch
extract this file to the directory you created earlier.
the directory resulting from the extraction should be called emplexer2.
With this disk will have the following structure / dune_plugins/emplexer2.
but what it is 'this disk'? I tried to put it on USB stick as '/dune_plugins/emplexer2', tried to make a system memory and put the folder '/dune_plugins/emplexer2' but it doesn't help. Could you explain a litle bit more detailed how to install v2 if it's possible with my Dune HD Base 3.0 with 150227_0032_b9.
I'm having issues with both version 1 and version 2.
Version 1 gives me the following error when I try and launch Emplexer:
"houve um problema ao acessar essa area, try again (401)"
In the log file I can see this:
[1301] [t744095744] [2015-04-04 12:58:16.402564] php engine: HTTP fetching
[1301] [t744095744] [2015-04-04 12:58:16.407764] php engine: http_code = 401
[1301] [t744095744] [2015-04-04 12:58:16.408040] php engine: HTTP request failed (401)
in a web browser I get "401 unauthorised"
I am running the latest PLEX server (v 0.9.11.16) which I believe has introduced some authentication requirements for clients.
Version 2 (the latest download) gives me the following error
System error Unhandled PHP plugin error. Call the PHP plugin vendor
Both the log files are in the following location
i fixed the issues - the same problem was impacting both versions:
Basically the new version of the server has changed how local clients need to authenticate to plex - without a valid token then by default the server will reject you.
It looks like they have changed the way this works several times and this last iteration is somewhat confusing - for me anyway.
What I did to solve it
Remove yourself from the new HOME sharing service - if you set this up like I did to try it out it fundamentally changes the security of the server. THe only way I could find to disable this was to remove everyone from your HOME group and remove the PIN form the organiser.
Next in the PLEX web change Settings->Server->Network (ensure you have clicked "show advanced")
Change: List of networks that are allowed without auth.
How come there is a black stripe on the bottom of some artowork Anyone got the original emplexer (v1) working with 2015 Dune firmwares?
I have a Dune HD Base 3D that I’d like to try Emplexer on. I just updated the firmware to the newest version. As of now what is the best version of Emplexer to use? I read that local storage is needed. Will an SD card work or do I need to put s hard drive in. If an SD card will work how big does it need to be. Thanks in advance for helping.
I installed the Dune Emplexer Zip file as outline on GitHub.  When I try to launch it it says unable to launch.  I installed it a couple times over and it gives me that message repeatedly.  Can someone tell me what I'm doing wrong
Have you configured everything everything? IP, Port etc. to your PMS?
I couldn't get to the configuring stage.  It just wouldn't launch.
I used this link to download it https://github.com/newloran2/emplexer/blob/master/dune_plugin_emplexer.zip.  Did I use the right file
The configuration is not in the app, it’s in the apps config.
It’s described somewhere in this thread already so look in earlier posts.
Also, make sure that all your media have pictures in PMS.
The configuration is not in the app, it's in the apps config.
It's described somewhere in this thread already so look in earlier posts.
Thank you.  I must have missed those instructions.  I thought the configuration was done within the app.  I'll find that and give it a try
Is emplexer dying a slow death? Still no news about any updates.
I hope not. I use v1 almost every day and it works great. If PLEX gets a major update which requires emplexer to change I think we will be in “trouble”.
I hope newloaran2 find time and motivation to work on emplexer again but life often gets in the way of this kind of “hobby” project.
