Dune player
Hello All. I can’t login with my previous account in new forum, so I created temporary new.
@MikeDelta, @StefanoP Could you send me log files?
hello jmper, can you give me some instructions in order to send you the log files? Thx in advance.
Stefano
You need create folder dune_plugin_logs on first connected storage (like flash drive) and start plugin. After error spot plugin and found dpc.log in this folder. Send it to me
@lpr said:
Hello,
I don’t know why, but just I can connect to my Plex server with this plugin. I get a “Plex server address http://192.168.1.myip:32400 does not respond”. I have a Dune HD Smart D1.  Am I missing something? All my other clients can connect to my PMS. Thanks.
Hello @lpr
Try input your local network as trusted in Plex Server settings
support.plex.tv/hc/en-us/articles/200890058-Require-authentication-for-local-network-access
Hello jmper, do you have an email address or a folder where I can upload the file dpc.log?
Hi jmper, I tried it again, and it’s not working for me.
@lpr
Sound strange because I’ve tried and it’s works.
Just in case. Do you tried use something like 192.168.1.0/24, not like in example (127.0.0.1/255.255.255.255)?
@StefanoP
use my email jmp@land.ru
Hello again. I’m back with my old account
Hello jmper!
the generated log shows only the following:
“wait 1
wait 1
wait 2
wait 3
wait 4
wait 5
wait 6
wait 7
wait 8
wait 9
wait 10
exit
wait 1
wait 1
wait 2
wait 3
wait 4
wait 5
wait 6
wait 7
wait 8
wait 9
wait 10
exit”
I´ve checked all Server Settings, cannot see any mistake in the configuration…
Any idea?
Regards!
Mike
@MikeDelta
This is dpc_bash.log But I ask about dpc.log
@jmper:
After a second try, i´ve got the needed logfile and here is it! :slight_smile:
Regard!
Mike
@MikeDelta
Did it work on v1.03 with connections like this ‘/volume1/video/–=HD-Doku=–’?
@MikeDelta
Just in case. Try to switch on/off option “seen/unseen” option in setup
@jmper said:
MikeDelta
Yes, works perfect with this Version!
@jmper said:
MikeDelta
Just in case. Try to switch on/off option “seen/unseen” option in Setup
You mean the seen/unseen Option in “Design”? I don´t find any other Option like this…
Yes. This one.Just change it and try. than change in back
Done, but no success… same problem!
@MikeDelta
Ok. Could you send me log file again?
@jmper said:
MikeDelta
Here is it! :slight_smile:
