@MikeDelta
Main problem is symbol “=” in your connection. But anyway it’s a bug. I’ll fix it
@MikeDelta I just have made experiment with connection name like yours and it’s worked. So symbol “=” not guilty.Could you try setup your connections again?
Hello people,
After more than a year without work on emplexer (many things happened in that time) i come back to forum and see what i every like to see, more developers made a dune plugin.
jmper, i tested your dpc, i’m really like it, do you think in put it in the GitHub? With that more developers can help you, i included.
Some suggestions by my self:
Put more seen badges with the percentage not only halfseen and unseen, maybe something like 1_percent_seen, 2_percent_seen … 99_percent_seen.
try to use the dune update system, with that your plugins can send automatically to the dune units.
Implement an optional transcoded session with PMS (very polemic topic), with that the new codecs can be played in dune (like h265).
I like to contribute with code, if my help are welcome please tell me.
Done, without luck… same error! Think this build doesn´t work for me…
Hello jmper,
do you have any ideas about my playing problem? It always prompt a message box reporting “Playlist empty”, whatever I choose to play.
thx and bye
Hello @newloran2 ! glad to see you!
Thank you for opinion about my attempt (it’s my first experience in PHP)
Now I’m preparing next update with timeline but I think each percent detalization it’s too much. I’ll try discret 5 or 10 percent.
Also I think about autoupdate.
About h265 I think it’s very difficult task in this moment. Hope Dune create some update for this possibility.
I haven’t thought about git, but why not
And thanks for help proposal! I’ll ask if I would realy need
@MikeDelta said:
Strange. Can you try downgrade on version 1.03?
Hello jmper,
I’ve sent to you the logs (email address). My connections are all in SAMBA are there problems?
Bye and Thx
@StefanoP Try this:
- Save your settings
- uninstall DPC
- restart Dune
- Install last version DPC
- Load settings.
@MikeDelta
Don’t need, I catched the problem!
@jmper said:
StefanoP Try this:
- uninstall DPC
- restart Dune
- Load settings.
…suddenly same behaviour…“It says: PLAYLIST EMPTY”
Good News, hope it can be fixed… ![]()
@newloran2 said:
Hello people,After more than a year without work on emplexer (many things happened in that time) i come back to forum and see what i every like to see, more developers made a dune plugin.
does this mean, that emplexer is abandoned?
nop, i’ll only stop de emplexer project if my dunes die (even the development being so slow),
but if anyone develop a dune plugin i can try to help if my help is welcome.
Looking forward to your next release newloran2, if you planning on releasing one.
I still use your v1 as my main client since DPC doesn’t resume from other clients. A function I use a lot.
What I really miss in v1 is MyPlex so that PMS gets updated with what I’m playing (user ID) so that the trakt.tv plugin works better.
Hi! I’m out of home till monday
Hello All!
Not so easy make development in hot summer
Anyway, next update:
- fixed some bugs in connections setup ( @MikeDelta - you need re-set your connections settings).
- fixed bug in serials “info” screen.
New
- some code improvements
- added screen with movie info on the right side
- now plugin can register itself on local Plex server and send info about viewed time
- added timeline indicator in “Plex style”
Download: dropbox.com/s/88vmdmmircdkrcw/dune_plugin_dpc_cr1_05.zip?dl=0
Great work! Now trakt.tv sees what I’m watching.
Is resuming also supported now?
