Hi jumper
My dune use wifi to access to plex media server on my synology nas.
I will test v1_061 tonight.
Hi jumper
@boby31 Do you have telnet access to you dune?
Hey jumper
(i have no telnet access to my dune)
Perfect with dpc_v1_061.tv shows are ok
All is working
Thanks again
good job jumper <3
Ok. but I’m afraid dpc on your dune couldn’t register itself on Plex as player.It’s not affect anything, but I’ll fix it in next update.
Hello all
I want to ask. Is it need create libraries like onDesk, recently added?
Hi jmper .why not if its not difficult but its not primordial for me
jmper, for me it’s not necessary at all.
I tried jmper’s plugin this weekend. I get error Plex server address http://127.0.0.1:32400/web does not respond.
Tried to input your local network as trusted in Plex Server settings with 127.0.0.1 or 192.168.1.5 (plex server ip)
How can I configure the plugin shortcut perhaps with my actual plex server ip? I don’t see it on a config file. If I create a dune network shortcut it wants a folder name.
If this is a http shortcut is the plugin using Dune’s web client? If so should I create a url dune shortcut and launch http://127.0.0.1:32400/web ?
@phatboyc Hello!
IP 127.0.0.1 only for local host. In plugin you have to input your PLEX Server IP (192.168.1.5). As trusted network you have to input 192.168.1.0/24 (in your case)
Where can I input my plex server IP for your plugin on the Dune? I am not able to edit your plugin icon on the dune and did not find your config file.
p.s. To install your plugin I launched your zip file, which was on my NAS, from the dune. It installed your plugin icon on the dune. But when I rebooted the dune it was gone. Also I did not see the plugin files copied to my dune storage (usb stick). So what I did is manually copy your extracted zip files/folders to my dune storage.
This worked but I still need to refresh my dune for your plugin icon to show up once the dune turns on.
Found some info on page 49. Is this it? ![]()
On the Dune - Go to Set Up > Applications > DPC and press enter
Can your plugin play Plex Channels ?
@phatboyc said:
Can you plugin play Plex Channels ?
Not yet, but it’s in my plans
@jmper Thank you for your good work
@RonBvB Welcome!
@jmper said:
phatboyc Hello!
HI jmper, I am getting exited to use your useful plugin. With the above change I can now get one step further.
DPC Application setup , under “connection settings”, I already have the path given by PMS when I click on it, I configured
I see my plex folders. But when I click on Film lets say, then All Movies, nothing happens.
Even stranger if I get out then try to go to the DPC setup again I see the same All Movies screen instead of the actual setup. Maybe its because I have another application installed in my Dune storage called Yadis?
Here is my setup if it helps. My PMS is on my computer. My films are on my NAS, different IP. My dune currently connects to my NAS via NFS.
@phatboyc Could you send me your log file?
You need create folder “dune_plugin_logs” on first storage connected with your dune (like flash stick), start DPC, try to open any library and finally find file “dpc.log” inside new folder.
Will do thanks. My Dune is installed in my home theater with projector which I don’t use everyday to spare the bulb. So it will take a couple days before I can pull a log.
One thing I am wondering is my usb icon on my Dune lauches another app called Yadis which is installed on the usb. I think I need to copy the DPC zip file on it to install DPC properly.
It doesn’t matter how you will install plugin from usb or other drive. I think another app (Yadis) should not affect. Still wait log
The tv shows are not in the correct order fot the last ship and Castle how can fix this
How it is on your PLEX server?
