It says “connecting…” and then the error.
Try reinstall plugin and restore settings
I deleted the app with all its files and reinstalled the latest version. It is working again.
Hi jmper
thanks ,i didn’t pay attention with the last version the list is right ![]()
Today i try to use my channels plex tv with dpc and i have some errors with applications.
with canal plus impossible to play with dpc.
i tried trailers with apple movie and hd trailers and impossible to play too on dpc.
I tried dailymotion application on Dpc and it’s working.
I don’t know with some channels apps don’t works on Dpc.
i pm you my log file ![]()
++boby
Hello, As I said not all channels are working. I’m planing use codecs for more channels. Are these channels working on web client?
Ah i didn’t see sorry
Yep these channels works on web client .
Ok. maybe codecs will help
Next update.
Fixed:
- playing monitoring and marking “seen” in case if series/movie file is not only latin symbols
- filter “onDesk” in series
- in case your PLEX server had changed IP address settings will reset after enter plugin setup
New:
Music library:
- now is possible mark several albums by press “select” button
- “shuffle” function (green button)
- playing tracks are also will appear in Plex server in “Now Playing” section
Series:
- buttons functions “play” and “enter” changed. Only selected episode will play by press “enter”. Selected episode and all next by press “play”
- now you can select several episodes for play by press button “select”
dl.dropboxusercontent.com/u/8488718/dune_plugin_dpc_v1_08.zip
As always, great job jmper!
Looking forward to test the new version tomorrow when I get back from my business trip.
My next plans:
- function sending “wake-on-lan”
- codecs for channels
- clarify situation with Plex Home Theater
- some optimisations
So I realized all my wishes and I hope all your. If not just let me know.
I think it’s time ask your support with translation dpc into your favorit languages.
This is “language” file:
dl.dropboxusercontent.com/u/8488718/dune_language_english.txt
After translation you can send it to me by PM or by email (jmp@land.ru)
Thank you!
Happy to see my magic packet is coming and On Deck is now fixed (I’ll try it tomorrow).
I didn’t want to say anything but here goes. When I saw that info screen it brought me back to 3270 emulator mode when I used to connect to a mainframe. So so awful. I realize its not jmper fault since he said its a DUNE limitation. But I didn’t think I would see this in 2015. ha ha ha
Honestly the only reason I am using a DUNE vs any other player with official plex client is I need the ZOOM function for my 2.35 aspect ration screen. So I am thankful for DPC still.
@phatboyc unfortunately it is. I’m strictly limited by Dune “design”. Of course it possible to use other technic to create plugins, for example “browser plugin” but it will works only on new dune models
Excelent Job jmper, MANY THANKS!!!
Great job jmper!
Found a bug. If I select Composite Plex as library icon, DPC can’t be started.
Thanks. I just have tried. It’s crashing if Composite Plex in Channels only. Will fix.
To be fair by default my info background was black. I noticed in DPC configuration I can select Art. Much better even if the Art is not cropped right.
When you say new Dune models, newer than my HD Base 3?
I mean newer than hdduo, hdmax and etc.
Can DPC detect the Dune model and only use a better info scree if able to? More importantly do you have a newer Dune model so you could enjoy your work?
It absolutely impossible use different techniques in one plugin
