@jmper
Yes, i mapped the disc. everything worked fine.
But now when i try to play something on due through DPC interface, i get a message box: Does not exist connection for Z:/Movies/etc.
As for channels, anybody knows which ones do work on Dune already?
I have it in every version. I can’t remember it has ever worked. I mainly use DPC to select which movie to see. Then I browse using the Dune folders to that movie.
Yes, i did. Plex runs nice on my pc, getting all the films from the Dune. And i can play them from on my pc with no problem
I can as well browse them on Dune through DPC interface. But when i try to play them i get that “no connection” error.
If you have message “no connections” that means you didn’t set your connections on DPC setup. Try to do it.
Morning.
This is where i got lost now.
I the setup i had previously entered my plex login, the Plex server was found automatically (very nice)
and then:
In Connections tab its not quite clear what to do:
I clicked on connections [Settings], and got a dialog box
“Connections Setup”
Movies
[Z:\Movies] button
When i click on [Z:\Movies] i get another dialog box: “Z:\Movies” with the following fields to fill in:
Connection type: SMB/NFS/Storrage (i have it on SMB)
Server: no idea what to write here. I thought server was linked automatically before
Folder: well, the folder is Z:\Movies
Login: its not password protected
Password:
Password:
Please help me through this.
In the meantime, i go install newest version
Hello,
If your movies physically on disk inside your Dune
you need choose Connection type - Storage
and Folder - your movie folder on disk (I guess “Movies”)
Hi jmper, do you have any news about the “SELECT” capability in MOVIES section? The same function you’ve added in TV-SHOWS.
It’d be joyful selecting three, four or more movies and let them play in sequence. Obviously you can’t shuffle them otherwise you’ll end with pieces of different movies played randomly.
Bye.
Can’t you replicate the behavior of the dune interface? Browse->Enter folder to view content->Select titles (with SELECT button)->Press Play.
I know it’s easier with words than with your machine code :-))
Password:
Hello,
I’m stumped here too, my movies are on my Plex server of course, not on local storage on the Dune, do I have to go through every connection/library and manually enter the IP address or something? Can’t this just be configured automatically, like Emplexer does?
Hello, yes you need set-up each connections because DPC use real links for playing movies and other. Emplexer could play it without setting because it can use http connection, but it very slow
Ok, I found an old USB keyboard and put all the information in, luckily I already had all the media drives shared out on my network anyway. It was kind of painful to set up but only needs doing once I suppose. Now I’m having some further difficulties though.
Sometimes when I play a media file, the plugin just crashes and returns me to the main Dune menu (sources).
Sometimes when I browse my library I get two lists over the top of each other, for instance the list of episodes from the previous show I was browsing gets put over the top of the current one I’m browsing.
