I have a Dune 301, today i had knowledge about Emplexer and i tried to install it on Dune, i did it, but Dune shows this message: “Impossible to launch”… The Emplexer icon appears on the applications menú, but when I try to select it does not work, Could you help me please??
I’ve got installed it and that displayed the icon. Now the problem is that when i try to connect with the computer, just showing a message of error (401).
In the configuration I have left ports by default Plex and I have introduced the I.P.v4 of the computer… What is that I do wrong???
Try input your local network as trusted on PMS (for example if your PMS has ip 192.168.0.10 and mask 255.255.255.0 you can input 192.168.0.0/24)
In the Dune-Emplexer configuration i changed the PC IP and put the router IP, it does not work, but the error message has change, now appears this one :_ “The area you are trying to acces is taking too long to respond, try again (0)”
What can i do???
It’s not correct. In Emplexer you have to put IP of your Plex server.
This version have to work. If you get error 401 it means the IP is correct but issue in security settings. Try put your local network as trusted on your Plex Server
I set correctly the emplexer, putting the IP of computer, i tried with the two versions of Emplexer that i have found: “Dune_pluguin_emplexer” and “Dune:_pluguin_emplexer2”, i have opened the port 32400, even i tried with differents frimwares of Dune, and alway the result is the same:
you are using the old version which is plagued with these PHP errors and is really not in development anymore. Look for the links for DPC (current version 0.94) and install that.
So, I am having a weird issue: trying to access a few of my libraries (2 out of 5) causes DPC to stop working and puts me back to the sources tab on my Dune. I have tried adjusting the paths, but all libraries are the same, just some work and some don’t.
After restarting the Dune and first accessing a working library and then one that causes DPC to quit I found that DPC seems to be reading the contents of the libraries fine, but after that it throws up the following bit after the non-working library:
Hello, I have a DuneHD with the latest firmware. I have loaded dpc v1.094 and have not been able to make any changes to the setup but add the user/password. I have run different versions of dpc (.091-.094) but no change. I have also reset and reloaded the Dune software. I’m running a home plex server. Can anyone help? here is my log
[1278] [t744095744] [2008-01-01 00:03:14.178196] php engine: PL::plex_login [1278] [t744095744] [2008-01-01 00:03:14.843519] php engine: Array ( [error] => You appear to be having trouble signing in to an account. You may wish to try resetting your password at https://plex.tv/reset ) [1278] [t744095744] [2008-01-01 00:03:14.847353] php engine: [/persistfs/plugins/dpc/dpc_plex_utils.php:1901 ] [E_NOTICE] Undefined variable: subscription
So it seems that either you’ve entered your Plax UID and Password incorrectly, or your account is locked out? I assume your account is not locked since you can post here, but are you sure that (a) you have entered the correct credentials and / or (b) your Dune unit has correct access to the I-net so it can authenticate against the Plex.tv servers?
Hope I am not confusing the issue. I think Jmper will have a much better analysis than mine
