Dune player
Great! I hope the next version would be more userfriendly :slight_smile:
The DPC client is actually very userfriendly. DPC setup can be a little bit better. If you’re interested I can make a manual. Also I can help with translation to Dutch and I can read some code (I’m not a professional programmer but can read and understand code). Let me know.
Thanks for propose. For manual not very actually because I’m working on new version, but translation would be interested. I’ll let you know.
Is it possible to change the icons in the startscreen of DPC?
So that’s the icons for for instance Movies, Series, Music
I have a library for every movie genre to keep the libraries rather small and quick because of my pi. So I have a library ā€˜Arthouse’, ā€˜Horror_Gore’, etc and would like to add my own picture for every library
Of course. Just create folder ā€œdpc_custom_iconsā€ on dune ā€œmainā€ drive and copy your icon files in png format to this folder.
After this it would be possible select your icons for each library in setup settings
Woow that’s so cool. I try it right away.
@jmper great work om app
I’m still getting problems to configure the settings
Tonight at home i will try to take some pictures and make the log file
cheers all
hi guys , hi jmper.
Great work have to say it again!
i am having problems and i am sure that is on connection settings
i change a lot to try to fix it and now i am asking for help :((
attached is the log file and pictures of everything
i use here a macbook as a plex server , time capsule as a nas and a dune base 3d as a player
i already use yadis and i can see the files directly on the dune , also i can play by DLNA using plex on dune
and can play using Yadis on dune
many thanks for all
I have tried to change a lot , one of them i use the network folder that i have on dune ( working )
and give this different result as show on pictures below
many thanks all
Hello!
if you want use SMB protocol in plugin connection don’t use ā€œsmb://ā€ prefix in ā€œfolderā€ field
Hi jmper, many thanks for your app
in first i use without smb:// at folder just Time Capsule HD/musicas , and did not work too
Regards
Just do it similar as you setup you dune network folder. It has to work
Hi jmper , thank for the quick answer
I change the setting to the same as dune network folder
then i go to the app
and got the same result
then a click to skip all and got
I try to change the folder to
and got the same result again
I`m attaching the log
many thanks
Ronald
Morning!
I guess problem in folder ā€œMusicasā€ name:
Note the space in the end
Hi jmper
Many thanks , ^:)^
you rocks dude =D>
Hi jmper
with Yadis I can play from my computer the files inside Dune.
with plex we can do it , start some file at Dune using other Device?
Not in this version
Hi jmper,
thanx again
it will be a nice improvement for next versions, if you could do it.
cheers
Love DPC so much and use it almost every day :wink:
@jmper said:
Hello, please try this one dl.dropboxusercontent.com/u/8488718/dune_plugin_dpc_v1.3a.zip
This link doesn’t seem to work anymore. Where can I get a copy of the latest files from please?
