Dune player
Hi neloran2
With your next update can you please give emplexer version numbers? :slight_smile:
Bug 1
Can not play Blu-ray ISO in mode shown below
Bug 2
emplexer dose not give me the option shown below
You can use the same log file for Bug 1
When I choose on NFS I get:
The area you are trying to access is taking too long to respond, try again (0).
Over and over.
i was getting the same error, then I found out my plex server was not enabled :rolleyes:
Yep, but now i see that when you choose NFS it wants to make a connection to every single section you create on plex. For me that means editting 16 fields of NFS. So I decided to go back to my AppleTV for now as this is all way to much work to get something simple like this going, unfortunately :frowning: Hopefully one day newloran2 can fix it without the hassle to have to set every section in NFS (typing the paths on a dune remote is a bit to much ;))
BDMV does not work.
and also. I have a movie (MKV) with internal subtitles that cant be shut off.
here is the log
I hope newloran2 fixes your issue, so you can come back to emplexer :D
I will fix this :).
unfortunately there is no way to know automatically which server your files are, I can only do this automatically if the plex on the same machine.
For that really need human intervention, but I'll come up with a way to be able to edit the data externally :).
Do not know if you know, but a way to edit text easier at Dune is push the blue button on the remote in a text box, it makes the virtual keyboard is shown (far from ideal but it improves a bit).
beat_strandh,
as the internal mkv with subtitles that have happened before does not?
unfortunately these issues with subtitles settings are something that will stay until hdi release a firmware with a subtitle settings when the dune is in vodplayback, my hands are tied :(.
but if it is only one file that can not disable subtitle (in dune global configuration), send me what kind of subtitle that file uses.
if any one have issues with this version when play files that played before (mkv/avi/mp4/mov) plz report, i will download a bluray iso and m2ts to make better tests.
m2ts plays ok but has a few Bugs.
No movie info
Artwork disappears after playing m2ts file
Reappears after exiting movie folder
it didnt work to shut of the subtitles in earlier versions either. it can be shut of in "normal" dune.
Hi. I have not experimented with NFS support (my NAS can do it) as I am not clear what it does for me versus SMB (enable Blu-Ray ISO/BDMV support??). But maybe this can help you re the remote.
If you have an Android device (and iOS Apple device as well I assume, I see an app there but have only used Android) there is an official remote control app by the Dune company that supports using the Android keyboard on your phone/tablet that worked quite well when I set up emplexer :) Much easier than using the Dune remote for text entry!!
Try it out!
https://play.google.com/store/apps/details?id=dune.remoteControl&hl=en
https://itunes.apple.com/us/app/dune-hd-rc/id514907005?mt=8
Hello dev. Just curious if anything jumped out from my log file for you since I didn't see any similar reports here. I have not had a chance to try and "redo" my setup on the Dune and will hopefully have a chance to redo that this weekend with whatever the latest version is. But I second a comment about version numbers, with such rapid releases it will help us testing keep track :) Thanking you!
alexannoyed,
there is no visible diferences on emplexer when it use nfs or smb, in both cases the gains as the same (much more speed to start play back, iso support, video folder structures supported (like dvd)), just use whichever is easyest.
Nice suggestion I did not know these apps :).
alexannoyed,
Your log was very revealing, I found the problem, but still did not fix.
About version numbers, the 20mxm1 ask about that for a long time :), after this weekend I began to think that it is really necessary.
I'm working on a solution to this, is not goes wrong the next update will be versioned.
The best stable version, that works with my ripped Blu-rays(BDMV & ISO files) is the version created Saturday, 2 February 2013 08:01 :slight_smile:
Hi everyone!!!
while newloran2 smooths out the emplexer bugs, i want to pick someones brain :slight_smile:
I"m trying to give my Dune HD more of a plex theme to match emplexer.
I have changed the background to black, personally I like the icons, now I want to change the Blue to orange.
can anyone help?
20mxm1,
which theme you use? i like to beautify my dune (default themes is so ugly :)).
Hi newloran2
I used this skin, then changed the background. I can Email the modified Skin, if you want.
http://www.mediafire.com/?8d11oh7soba6i14
I am glad the logs were able to help and I hope you can resolve the issue! Please let me know if you need anything else like logs or my particular setup and such. Thanks again!
Plex pushed out a new version of PMS. I will probably upgrade this weekend and try it all over again to see what happens in the meantime.
It is too bad that the new more powerful Dune players coming soon can not do full Blu-ray menus from ISO/BDMV because of Cineva DRM nonsense. Otherwise I would upgrade but I dislike having features VANISH, features supposed to get better!!
Hello, people!
I’ve got a problem with emplexer installation onto Dune TV-101 with 4GB USB system storage installed. Message ā€œfailed to install applicationā€. Have you any ideas what is the cause?
I don’t know what happene, however now everything OK :slight_smile:
Hi newloran2
I see you have added an enhancement, ā€œimages download on background processā€, on Github. :slight_smile:
Will it load the Tv & movie art faster?
