DVB-C channel scan fails
Server Version#: 1.31.2.6810
Player Version#: Version 4.100.1
I had a working setup WinTV-dualHD USB + NVIDIA shield + plex media server setup. I decided to change shield to PC (Windows 11 22H2). If I try to scan cable channels it fails in 0% and tuner logs looks like this:
Mar 23, 2023 16:09:05.886 [10416] INFO - [I] CTVSStreamSource::Term. Waiting for streaming thread to stop
Mar 23, 2023 16:09:05.886 [10816] INFO - [I] TuningSpace Name: ‘Antenna’ NetworkType: {00000000-0000-0000-0000-000000000000}
Mar 23, 2023 16:09:05.886 [10816] INFO - [I] TuningSpace Name: ‘ATSC’ NetworkType: {0DAD2FDD-5FD7-11D3-8F50-00C04F7971E2}
Mar 23, 2023 16:09:05.886 [10816] INFO - [I] TuningSpace Name: ‘ATSCCable’ NetworkType: {0DAD2FDD-5FD7-11D3-8F50-00C04F7971E2}
Mar 23, 2023 16:09:05.886 [10816] INFO - [I] TuningSpace Name: ‘AuxIn1’ NetworkType: {00000000-0000-0000-0000-000000000000}
Mar 23, 2023 16:09:05.886 [10816] INFO - [I] TuningSpace Name: ‘Cable’ NetworkType: {00000000-0000-0000-0000-000000000000}
Mar 23, 2023 16:09:05.886 [10816] INFO - [I] TuningSpace Name: ‘DD2 DVB-C’ NetworkType: {DC0C0FE7-0485-4266-B93F-68FBF80ED834}
Mar 23, 2023 16:09:05.886 [10816] INFO - [I] Enumeration found 6 tuning spaces
Mar 23, 2023 16:09:05.886 [10816] INFO - [I] Found TuningSpace
Mar 23, 2023 16:09:05.886 [10816] WARN - [E] cannot initialize the tuning space
Mar 23, 2023 16:09:05.886 [10816] WARN - [E] CTVSStreamSource::LoadAndInitDriver. Failed to start device path @device:pnp:\?\usb#vid_2040&pid_8265#0014315445#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{b50b8116-da24-4f97-80d1-00451702c5f7}, type 2, frontend 0
Mar 23, 2023 16:09:05.886 [6156] WARN - [E] CTVSChannelScanner::Tune. Failed to tune to a transponder
Mar 23, 2023 16:09:05.886 [6156] WARN - [E] dvb_channel_scanner_t::do_scan_attempt. Tune failed for 258000,V,6900,QAM256
Mar 23, 2023 16:09:05.886 [6156] INFO - [I] channel_scanner_t::scan_channels. Scanned 9 transponder out of 9. Channels found 0
Mar 23, 2023 16:09:05.886 [6156] INFO - [I] CTVSStreamSource::Term. Waiting for streaming thread to stop
Mar 23, 2023 16:09:05.937 [10416] INFO - [I] CTVSStreamSource::Term. Streaming is stopped
Mar 23, 2023 16:09:05.937 [6156] INFO - [I] CTVSStreamSource::Term. Streaming is stopped
Mar 23, 2023 16:09:05.937 [10416] INFO - [I] CTVSStreamSource::Term. Stream source is stopped
Mar 23, 2023 16:09:05.937 [6156] INFO - [I] CTVSStreamSource::Term. Stream source is stopped
Mar 23, 2023 16:09:05.937 [10416] INFO - [I] channel_scanner_t::scan_thread_function finished
Mar 23, 2023 16:09:05.937 [6156] INFO - [I] channel_scanner_t::scan_thread_function finished
Mar 23, 2023 16:09:08.108 [10776] INFO - [I] web_service_t::process_device_status
DVB-T scanning works fine. I have reinstalled plex server, no change. Also WinTV 10 works fine.
Any ideas how to troubleshoot or fix this?
Hi I can second this,
I have had same problem for a long time.
Gave up and kept Shield as a live tv server, and Win11 for everything else
