I’ve searched everywhere for this. Where are recordings save when using the DVR? On my computer drive? On an NAS?
Can I run Plex with just a computer and no NAS, and use the DVR?
Even this forum is confusing.
Thanks.
Thanks.
They are saved in whichever folder location you have set for the libraries you created. If reocrind a movie it will record to movie library if recording a Tv show it will save to tv library
When you create a library you tell Plex which folder(s) you store that content in.
Yes.
Thank you. Will a 1 terabyte SSD or is a HDD required?
Sure you can run it on a PC. I ran it on my laptop when I was first trying out Plex. It will just write the recordings to your hard drive.
