DVR loses channel mapping?
Hi @sa2000 , my Linup was Called Giga-TV and my Postcode is 38122, Germany, please could you help me too?
I have experienced this, too, several times. All but three channel mappings disappeared all of a sudden and had to be re-mapped. No clue if this matters, but like the OP, I am also from Germany.
my lineup continues to be germany all because you don‘t have my provider. my family depends on it!! but the plex live tv and dvr is not good! there’re not all channels to be matched. it does not work right. failed recordings. pixalation, needed channels can‘t be matched. hd channels are sd or whatever. we can‘t order channels in the way we need. channel icons that we can‘t recognize.
plex live tv & dvr is almost like roon. painfull and s hi tty
The national lineups appear to be alpha sorted on channel names and that means that channel numbers will change - I have raised this with Gracenote and also raised an internal feature request for Plex Media Server for callsign matching option instead of channel numbers.
Have you provided details of your provider ? and links to the web pages that give their channels ?
This has been referred to Gracenote. Thank you
Trying to scan with “DVBC Germay /Kabel Komplett)” getting 440 Programs. RTL and Sat.1 are missing.
My Provider is “Vodafone, Kabel deutschland Braunschweig”.
The right channel assignment can be shown here: https://helpdesk.vodafonekabelforum.de/sendb/export.php?mode=pdf&aod=digital&netz=190 .
I Think in “DVBC Germay /Kabel Komplett)” D122 is missing.
For EPG mapping I took “Giga TV (397 channels)” and I found that two channels changed ther Numbers since 2.4.21:
|6|BR Ferns. Süd HD from 165 to164
|30|NDR FS NDS HD from 168 to165
here the channel-mapping for “Kabel Komplett” and Giga TV :
EPG: Giga TV (397 channels)
Nr. Programm Mapping 17.04.2021
1 SWR RP Hd 162
2 Das Erste HD 101
3 WDR HD Köln 163
4 RTL 103
5 Sat 1 104
6 BR Ferns. Süd HD 165 164
7 MDR Sachsen HD 166
8 Super RTL 601
9 RTL II 107
10 VOX 117
11 ntv 551
12 sport 1 401
13 BBC World News (eng) 563
14 TV Monde (fre) 832
15 NITRO 209
16 Toggo plus 605
17 CNN (eng) 566
18 euronews 554
19 hr-fernsehen HD 161
20 arte HD 120
21 sixx 210
22 Tele 5 202
23 Eurosport 402
24 ProSieben 105
25 kabel eins 108
26 WELT 553
27 rbb Berlin HD 167
28 ZDF HD 113
29 ZDF info HD 579
30 NDR FS NDS HD 168 165
31 DMAX 503
32 VOXup 205
33 PHOENIX HD 575
34 zdf_neo HD 206
35 KiKA HD 622
36 ServusTV HD 124
37 SAT 1 Gold 211
38 Disney Channel 203
39 RTLplus 208
40 3sat HD 121
41 ProSieben MAXX 212
42 health tv 509
43 One HD 246
44 ARD-alpha HD 518
45 tagesschau 24 HD 578
46 SR Fernsehen HD 160
47 N24 Doku 508
48 Welt der Wunder TV 505
Thanks for the details relating to your provider komro.net
I have raised a request with Gracenote for lineups for this provider
As you have discovered the national lineup for Germany is not usable because the channels are alpha sorted on channel name and the channel numbers change all the time and needing to be re-mapped. I have raised this with Gracenote
Channel 574 CGTN should now be visible within the Horizon TV (359 Channels) lineup and can be mapped. I have checked that it has a schedule.
Thank you sa2000, 574 CGTN mapping done.
I have had a response from Gracenote concerning komro.net. It appears that they have a threshold for picking up providers - depending on number of households covered and for this reason komro.net does not fit the crieria for inclusion
As mentioned earlier, I have raised a feature request for Plex Media Server to provide an option to match channels on callsign instead of channel numbers - that would then allow use of the national lineups which appear to be alpha sorted on channel titles and so channel number would not be fixed
Any update here? when can we safely use the Germany all channels listing?
It has been raised. I do not know when work would start on this development
I take it you have a provider that is not deemed large enough to be included in the Gracenote set of lineups?
es, very small local provider. SWU Telnet GmbH
