sa2000
April 6, 2021, 12:00pm
21
I have opened a case with Gracenote to establish what their criteria is for making changes to the Germany (Extended) country lineup - Deutschland (erweitert)
I have made them aware of the impact the changes have and also mentioned lack of Vodafone lineups
sa2000
April 6, 2021, 12:07pm
22
If this is happening to other lineups as well (other than Deutschland (erweitert) ) - please let me have the details
country / post/zip code
lineup/guide name
examples of unexpected changes and when
Just to make sure we’re talking about the same “numbers”:
Those on the left remain unchanged until the provider would change their settings. And that hasn’t happened for a very long time here.
What’s changing are the number on the right, i.e. in the drop-downs.
sa2000
April 6, 2021, 12:27pm
24
Yes - these are the EPG lineup numbers.
Hi HaesleAdmin, maybe you are using the HDHomeRun Tuners. I am closing all not used channels from HDHomerun, so in fact while I need to add the new epg lineups I minimize all unwanted. Using delete and favorites I also see all new available channels. This speedups a bit knowing that the rest is painful enough.
Regards Tom
Hallo sa2000, my idea, here in this thread a few days ago. I think we have to get rid of this problem from two sides, first provider ok, but second a better logic in Plex to get this matches automatically… I guess the logic insides Plex is a “world wide used” and will not withstand changes. Plex should be 24/7 without any Problems of losing channel lineups.
The problem persists , one change at the beginning of the list will impact most off all other channels ;(
Idea
The solution would be quite simple. Every EPG Channel has a code e.g. ZDF aka ZDFGERH, if there is a method of trying to find the match is must be made not from the numbers or from the channelname in brackets, instead the alpha-code (ZDFGERH) must be taken. I think this alpha code will not change ever so it’s secure to use.
The best way would be a worksheet with two rows
1st row: what’s the name of the channel provided from HDHomerun (name not number)
2nd row: what is the alphacode of the epg provider
With this kind of sheet (once manual done) there should be no more trouble. I doesn’t take place very often that there are new channels or channels deleted, if so the admin has to manage this. The sheet should be generated and maintained from the admin via webgui.
sa2000
April 8, 2021, 8:16am
27
Regarding Vodafone Cable TV in Germany, I received a response from Gracenote that Vodafone cable in Germany is covered by Giga and Horizon lineups
Bayern - Giga TV
Berlin - Giga TV
Brandenburg - Giga TV
Bremen - Giga TV
Hamburg - Giga TV
Mecklenburg-Vorpommern - Giga TV
Niedersachsen - Giga TV
Rheinland-Pfalz - Giga TV
Saarland - Giga TV
Sachsen - Giga TV
Sachsen-Anhalt - Giga TV
Schleswig-Holstein - Giga TV
Thüringen - Giga TV
and for Vodafone’s takeover of Unitymedia, lineups have been renamed to:
Baden-Württemberg - Horizon TV
Hessen - Horizon TV
Nordrhein-Westfalen - Horizon TV
Please could you look into using these and let me know if there are issues - please also complete a DVR EPG Feedback form
Thanks a lot @sa2000 - this looks very good. I’m from Baden-Württemberg and switched to Horizon TV, all the channels now mapped automagically and that should now also be persistent. Great support!!!
how to switch to Hessen - Horizon TV? Topline is (see screenshot), Thanks Tom
You need to remove the current DVR instance and create it again from scratch. When going through the dialogs, in the very last step you can select the lineup. This defaults to “Deutschland” because of your input in previous dialogs and you have to switch that in the dropdown to “Horizon TV”
Hallo HaesleAdmin, Thanks for the info, so another time from the scratch ;( gosh…
Thanks! I will also test if recordings are working again.
Channel mappings for Giga TV in case anyone wants to CTRL+F the channels instead of manually looking through 1000 lines:
101 DASERST (Das Erste)
101 ANTBYRA (Antenne Bayern)
102 ZDFG (ZDF)
103 EGOFM (egoFM)
103 RTLBAYE (RTL Television)
104 BAYERN (Sat.1)
105 PRO7GRH (ProSieben)
105 ARABELLA (Radio Arabella)
106 RACHAMU (Radio Charivari München)
106 VOXGERH (VOX)
107 M945 (M94,5)
107 RTL2GRH (RTLZWEI)
108 KAB1H (kabel eins)
108 RADGALA (Radio Galaxy)
109 RAGONG (Radio Gong 96,3)
109 3SATGEH (3sat)
110 RHOFWLO (radio horeb / Feierwerk / Lora)
110 ARTEGRH (ARTE)
112 RCKANT (Rock Antenne)
112 ARDGRHD (Das Erste HD)
113 ZDFGERH (ZDF HD)
114 RTLHD (RTL HD)
115 SAT1BYH (Sat.1 Bayern HD)
116 PRO7HD (ProSieben HD)
117 VOXHD (VOX HD)
118 RTL2HD (RTLZWEI HD)
118 ARAKURA (Arabella Kult)
119 KABEL1H (kabel eins HD)
120 ARTDEUH (ARTE HD)
121 3SATHD (3sat HD)
123 SERVTVD (Servus TV)
124 SERVDHD (Servus TV HD)
124 RADIOB2 (radio B2)
134 MDRTHR (Mitteldeutscher Rundfunk)
135 NDRMEVR (Norddeutscher Rundfunk)
140 RBBBERL (Rundfunk Berlin-Brandenburg)
141 BRSUED (Bayerischer Rundfunk)
141 FM4RADE (FM4)
142 WDRKLN (Westdeutscher Rundfunk)
143 OE2RASA (Ö2 - Radio Salzburg)
144 HRHF (hr-fernsehen)
144 OE1RAD (Österreich 1)
145 HITOE3 (Hitradio OE3)
145 SWRSFRP (Südwestrundfunk)
147 SWRSR (SR Fernsehen)
150 KLARAD (Klassik Radio)
151 SPUTRAD (Sputnik)
151 MUNCHEN (München TV)
152 SUNSHLV (Sunshine Live)
153 ANTBBRA (Antenne Brandenburg)
154 BAYERN1 (BAYERN 1)
155 BAYERN3 (BAYERN 3)
156 ORF2WI (Österreichischer Rundfunk 2)
156 BAYERNP (Bayern plus)
157 BRHEIMA (BR Heimat)
158 DIEZEIT (Die neue Zeit TV)
158 BREMEN1 (Bremen Eins)
159 BREMEN4 (Bremen Vier)
160 PULSRAD (PULS)
160 SWRSRHD (SR Fernsehen HD)
161 DASDING (DASDING)
161 HRHFHD (hr-fernsehen HD)
162 SFRPHD (SWR Fernsehen RP HD)
162 1LIVERA (1LIVE)
163 WDRKHD (WDR Köln HD)
163 1LVDIRA (1LIVE diggi)
164 FRITZRA (Fritz)
164 BFSHD (Bayerisches Fernsehen Süd HD)
165 HR1RAD (hr1)
165 NDRHHHD (NDR Fernsehen HH HD)
166 HR3RAD (hr3)
166 MDRSCHD (MDR Sachsen HD)
167 RBBBEHD (RBB Berlin Fernsehen HD)
167 HR4RAD (hr4)
168 MDRJUMP (MDR JUMP)
169 MDR1SN (MDR 1 Sachsen)
170 MDR1ST (MDR1 Sachsen-Anhalt)
171 MDR1TH (MDR1 Thüringen)
172 NDRRAMV (NDR Radio MV)
173 NDR1WNO (NDR 1 Welle Nord)
174 NDR1NI (NDR 1 Niedersachsen)
175 NDR2RAD (NDR 2 Radio)
176 NDR903 (NDR 90,3)
177 NJOYRAD (N-JOY)
178 RBB888 (rbb 88.8)
179 RADEINS (radioeins)
181 SR1EUW (SR 1 Europawelle)
182 SR3SW (SR 3 Saarlandwelle)
183 SWR1BW (SWR1 BW)
183 MUNTVHD (München TV HD)
184 SWR1RP (SWR1 RP)
185 SWR3RAD (SWR3)
186 SWR4BW (SWR4 BW)
187 SWR4RP (SWR4 RP)
188 WDR2RAD (WDR 2)
189 WDR4RAD (WDR 4)
190 YOUFMRA (YOU FM)
191 RTLRAD (RTL Radio)
192 RADPALO (Radio Paloma)
193 JAMFMRA (JAM FM)
194 METROFM (METROPOL FM)
196 NDRPLUS (NDR Plus)
197 NDRBLUE (NDR Blue)
198 BRENXT (Bremen Next)
199 UDING (UnserDing)
201 CCDE (Comedy Central)
202 TELE5GR (Tele 5)
203 DISNG (Disney Channel)
204 ONEARD (one)
205 VOXUP (VOXup)
206 ZDFNGEH (ZDFneo)
207 ASTROTV (AstroTV)
208 RTLPLUS (RTL PLUS)
209 RTLNITR (Nitro)
210 SIXX (sixx)
211 SAT1GLD (Sat.1 Gold)
212 PSIEBMX (ProSieben MAXX)
213 TLCGER (TLC)
214 ANIXE (ANIXE+)
215 SIXXHD (sixx HD)
216 RTLNIHD (Nitro HD)
219 MTVGERH (MTV Deutschland)
221 BONGUST (Bon Gusto)
222 RTLLIVG (RTL Living)
223 TELE5HD (Tele 5 HD)
224 MTVGEHD (MTV HD)
225 CCDEHD (Comedy Central HD)
226 DISCHHD (Disney Channel HD)
227 SATGHD (Sat.1 Gold HD)
228 PROMXHD (ProSieben MAXX HD)
229 RTLPLUH (RTLplus HD)
230 SAT1EM (Sat.1 emotions)
231 TLCGHD (TLC HD)
232 HOGATVD (Home and Garden TV)
233 HOGAHD (Home & Garden HD)
237 RTLLVHD (RTL Living HD)
238 PRO7FHD (ProSieben Fun HD)
239 SAT1EMH (Sat.1 emotions HD)
246 ONEARHD (one HD)
247 ZDFNGHD (ZDFneo HD)
251 BRKLRAD (BR-KLASSIK)
252 HR2RAD (hr2)
254 MDRKULT (MDR Kultur)
256 NDRKULT (NDR KULTUR)
258 SWR2RAD (SWR 2)
259 WDR3RAD (WDR 3)
260 WDR5RAD (WDR 5)
261 BAYERN2 (Bayern 2)
262 KULTRAD (kulturradio)
263 BREMEN2 (Bremen Zwei)
264 SR2KULT (SR 2 Kultur)
266 MDRKLRA (MDR KLASSIK)
280 123TVGH (1-2-3.tv HD)
281 HSE24HD (HSE24 HD)
282 QVCGHD (QVC HD)
283 SONTVHD (sonnenklar.TV HD)
290 123TVGR (1-2-3.tv)
291 HSE24G (HSE24)
292 CH21SHP (Channel21)
293 SONTV (sonnenklar.TV)
295 QVCDEUT (QVC)
296 JUWELTV (Juwelo TV)
297 HSE24EX (HSE24 EXTRA)
298 QVC2DE (QVC Zwei)
301 STMAIN (13TH STREET)
302 SYFYD (Syfy)
307 KINOWLT (KinoweltTV)
310 AXND (AXN)
313 SLVRMOV (SILVERLINE)
316 KEINCL (kabel eins classics)
318 TNTGLTZ (TNT Comedy)
319 TNTFILM (TNT Film)
320 TNTSKD (TNT Serie )
321 FOXKD (FOX )
322 ROMTV (Romance TV)
323 TNTFHD (TNT Film HD)
324 TNTSHKD (TNT Serie HD )
325 FOXHDKD (FOX HD )
326 13STHD (13th Street HD)
327 SYFYHDG (SyFy HD)
328 ROMTVHD (Romance TV HD)
329 TNTGLHD (TNT Comedy HD)
330 KINTVHD (Kinowelt HD)
331 AXNDEUH (AXN HD)
332 UNIDHD (Universal Channel HD)
333 SETDHD (Sony Channel HD)
335 KEINCLH (kabel eins classics HD)
336 RTLCRHD (RTL Crime HD)
351 DEFUNK (Deutschlandfunk)
352 DWISSEN (Deutschlandfunk Nova)
353 DKULTUR (Deutschlandfunk Kultur)
355 MDRINFO (MDR Aktuell)
357 RAHOREB (radio horeb)
358 ERFPLUS (ERF Plus)
359 BBCWS (BBC World Service)
360 B5AKRAD (B5 aktuell)
361 B5PLRAD (B5 plus)
362 SWRAKT (SWR Aktuell)
363 COSMORA (COSMO)
364 HRINFOR (hr iNFO)
365 ANTSAAR (antenne Saar)
366 INFORAD (InfoRadio)
367 NDRINFO (NDR INFO)
369 WDREVEN (WDR Event)
370 WDR2RAD (WDR 2)
371 MEGARAD (Mega Radio)
401 SP1GERH (SPORT1)
402 EUROSGR (Eurosport 1)
403 EURSP2 (Eurosport 2)
404 SKYSNG (Sky Sport News)
405 SKYSNGH (Sky Sports News HD)
410 SPRT1PL (SPORT1+)
420 SPODTV (SPORTDIGITAL FUSSBALL)
446 EUROHD (Eurosport 1 HD)
447 EURS2HD (Eurosport 2 HD)
449 SPO1HD (SPORT1 HD)
450 SPRT1HD (SPORT1+ HD)
451 KLASSIK (Klassik)
451 ESPO1HD (eSPORTS1 HD)
452 SPODHD (SPORTDIGITAL FUSSBALL HD)
452 WRLDMSC (World Music)
453 CNTRYRA (Country)
454 RNROLDI (Rock'n'Roll Oldies)
455 SUMFEEL (Summer Feelings)
456 CLSSRCK (Classic Rock)
457 SAIMUS (Saisonale Musik)
458 POPRKSL (Pop Rock Soul)
459 COOLJZZ (Cool Jazz)
460 RNBSLCL (R'n'B & Soul Classics)
461 URBANRA (Urban)
462 6070HIT (60er & 70er Hits)
463 8090HIT (80er & 90er Hits)
464 KUSCHEL (Kuschelsongs)
465 DNCPRTY (Dance Party)
466 CHILLOT (Chillout)
467 SYMRAD (Symphonie)
468 JAZZCL (Jazz Classics)
469 NEWAGER (New Age)
470 VLKSMSC (Volksmusik)
471 KNDRHTS (Kinderhits)
472 BLUESRA (Blues)
473 CTLLNG (Cocktail Lounge)
474 REGGAER (Reggae)
475 ROCKANT (Rock Anthems)
476 TURKMUZ (Türk Müzigi)
477 RUSKAMU (Russkaja Musyka)
478 ARABICR (Arabic)
479 HITSAKT (Hits Aktuell)
480 SCHLGRR (Schlager)
502 ARDALPH (ARD-alpha)
503 DMAXD (DMAX)
505 WELTDW (Welt der Wunder)
506 KAB1DOK (Kabel eins Doku)
507 N24DKHD (N24 Doku HD)
508 N24DOKU (N24 Doku)
509 HEALTHD (HealthTV)
510 HISTD (HISTORY)
511 CIDE (Crime+Investigation)
513 NGEODEU (National Geographic)
516 SPIELW (Spiegel TV Wissen)
518 ARDALHD (ARD-alpha HD)
519 DMAXDHD (DMAX HD)
520 NGHDKD (National Geographic HD )
522 SPIELWH (Spiegel TV Wissen HD)
523 CIDEHD (Crime+Investigation HD)
524 HISTHDD (HISTORY HD)
525 NTGWHD (National Geographic Wild HD)
526 DSCHDKD (Discovery HD )
527 GEOTHD (GEO Television HD)
531 BIBLTV (Bibel TV)
551 NTVGERH (n-tv)
552 DPHOENXG (PHOENIX)
553 WELTDE (Welt)
554 EURNWGR (euronews)
555 NHKWRLD (NHK World TV)
559 TAGARD (tagesschau24)
560 INFOGEH (ZDFinfo)
563 BBCWLD (BBC World News)
565 CNBCSKG (CNBC/Sky News)
566 CNNEUVM (CNN International)
567 ALJAZ (Al Jazeera)
572 CNNEUHD (CNN International HD)
573 WELTHDE (Welt HD)
575 PHONXHD (PHOENIX HD)
576 NTVHD (n-tv HD)
577 BIBGEHD (Bibel TV HD)
578 TAGARHD (tagesschau24 HD)
579 ZDFINHD (ZDFinfo HD)
580 KAB1DOH (Kabel eins Doku HD)
601 SUPRTL (Super RTL)
602 KIKAGH (KiKA)
603 NICKCC (Nick/Comedy Central +1)
605 TOGPLUS (Toggo Plus)
606 DISJRKD (Disney Junior )
610 BOOMDEU (Boomerang)
611 CNGRM (Cartoon Network)
612 FIXFOXI (Fix & Foxi)
617 SURTLHD (Super RTL HD)
618 NICKCC1 (Nick/Comedy Central +1 HD)
620 CNGERHD (Cartoon Network HD)
621 BOOMDHD (Boomerang HD)
622 KIKAKHD (KiKA HD)
625 NICKJDH (Nick Jr. HD)
627 DISJRDH (Disney Junior HD)
701 DMF (Deutsches Musik Fernsehen)
703 DMUSTV (Deluxe Music TV Europe)
705 DMUSTVH (Deluxe Music Europe HD)
706 DMFHD (Deutsches Musik Fernsehen HD)
710 MTVBND (MTV Hits)
718 GTLNTV (Gute Laune TV)
751 LUSTPUR (Lust Pur)
798 DAZN1 (DAZN 1)
799 DAZN2 (DAZN 2)
805 BEINMOT (beIN MOVIES TURK)
806 BEINGTU (beIN GURME)
808 HALKTU (Halk TV)
809 SHOTURK (Show Turk)
811 EURODTU (Euro D Turkey)
812 KAN7AVR (Kanal 7 Avrupa)
813 EUROSTU (Euro Star Turkey)
814 TVPOL (TV Polonia)
815 ITVNEU (TVN International Europe)
822 RTVDE (OstWest)
823 KINOMIR (Nash Kinomir)
824 TLBTLD (TeleBom/TeleDom)
825 CHONRUS (Channel One Russia)
826 RTREU (RTR Planeta)
831 FR2 (France 2)
832 TV5MON (TV5 Monde Europe)
836 FR24POR (France 24 HD)
845 ARIFTV (Arirang TV/Fashion TV)
847 SONLIFE (SonLife Broadcasting Network)
850 TNTSENG (TNT Serie )
851 TNTF (TNT Film)
852 AXNITE (AXN)
853 BBCETEU (BBC Entertainment)
854 NGEODEU (National Geographic)
863 DJREKD (Disney Junior )
864 BOOMKD (Boomerang )
865 CNETKD (Cartoon Network )
866 RAIUNO (Rai 1)
867 RAIDUE (Rai 2)
868 RAITRE (Rai 3)
871 TVEINTS (TVE Internacional)
872 CAN24H (Canal 24H)
881 RTPIE (RTP Internacional Europe)
883 BVNEU (BVN)
884 HRT1 (HRT1)
885 DUNASD (Duna TV)
889 ALJABAJ (AlJaz Balkan/AlJaz)
890 ORIENTV (Tunisie 1 / Orient TV)
891 ANT1EU (Ant1 Europe)
897 PCNENTV (PCNE/NTD TV)
900 SKY1DEH (Sky1 HD)
901 SKYKGHD (Sky Krimi HD)
902 SKYADHD (Sky Atlantic HD)
903 FOXDHD (FOX HD)
904 TNTSEHD (TNT Serie HD)
905 SYFYHDG (SyFy HD)
906 13STHD (13th Street HD)
907 UNIDHD (Universal Channel HD)
909 NGEOHD (National Geographic HD)
910 NTGWHD (National Geographic Wild HD)
911 DSCGHD (Discovery Channel HD)
912 TNTGLTZ (TNT Comedy)
913 BUHSEHD (BEATE-UHSE.TV HD)
914 HEIMKAN (Heimatkanal)
915 ROMTV (Romance TV)
916 CLSSCA (Classica)
917 BOOMDEU (Boomerang)
918 DISJRDH (Disney Junior HD)
919 JUNR (Junior)
920 SPIEG (Spiegel Geschichte)
921 SKYCPHD (Sky Cinema Premieren HD)
922 SKCBOHD (Sky Cinema Best Of HD)
923 SKYCTHG (Sky Cinema Thriller HD)
924 SKYGRHD (Sky Cinema Action HD)
925 SKYCIHD (Sky Cinema Special HD)
926 SKYCPSD (Sky Cinema Premieren)
927 SKCP24SD (Sky Cinema Premieren +24)
928 SKCBOSD (Sky Cinema Best Of)
929 SKYGR (Sky Cinema Action)
930 SKYFAMG (Sky Cinema Family)
931 SKYCOMG (Sky Cinema Fun)
933 SKNOSTG (Sky Cinema Classics)
934 TNTFILM (TNT Film)
935 SKYBUHD (Sky Sport Bundesliga 1 HD)
936 SKYB2HD (Sky Sport Bundesliga 2 HD)
937 SKYB3HD (Sky Sport Bundesliga 3 HD)
938 SKYB4HD (Sky Sport Bundesliga 4 HD)
939 SKYB5HD (Sky Sport Bundesliga 5 HD)
940 SKYB6HD (Sky Sport Bundesliga 6 HD)
941 SKY1GHD (Sky Sport 1 HD)
942 SKY2GHD (Sky Sport 2 HD)
943 SKYS3HD (Sky Sport 3 HD)
944 SKYS4HD (Sky Sport 4 HD)
945 SKYS5HD (Sky Sport 5 HD)
946 SKYS6HD (Sky Sport 6 HD)
947 SKYS7HD (Sky Sport 7 HD)
948 EUR3601 (Eurosport 360 HD 1)
949 EUR3602 (Eurosport 360 HD 2)
950 EUR3603 (Eurosport 360 HD 3)
951 EUR3604 (Eurosport 360 HD 4)
952 EUR3605 (Eurosport 360 HD 5)
980 BUN1 (Sky Sport Bundesliga 1)
981 SKYSP1G (Sky Sport 1)
982 SKYSP2G (Sky Sport 2)
983 SKYSPA (Sky Sport Austria)
998 SKYPUNG (Sky Serien & Shows HD)
Yes, once more, but you don’t have to map the channels anymore, this is now all automatic.
Thanks HaesleAdmin, works like a charm. And if I add some more channels via HDHomerun, release (enable) the channel at the hHDHomerunTuner and then refresh EPG in Plex? Would this be all?
Hope it works for you, mine are all (except one) adjusted from Plex,
Hello sa2000, works really good, no more listings and running the “1.000 line” job I will report actually one missing. good job Plex, and therefore at this point no need of my idea
be aware of following: series recording restricted to 1(!) channel → Tagesschau ARD 20:00 will not be found, cause the lineup number changed, workaround … deleting and new schedule. this problem has to be “solved” with every change in the lineup. If you set it to all channels, no problem…
Hi sa2000, the form is not usable for me, I do not have a URL for the lineup. Both examples refer to US and UK… we are in Germany.
Following ist missing
574 CGTN
sa2000
April 9, 2021, 9:20am
39
Tom23845:
574 CGTN
Which lineup have you now selected and what is the post code used in DVR Setup? You may have mentioned it before - but there are lots of posts. I need that information before progressing this issue
Hi sa2000, lineup was called “Horizon TV” and my Postcode is 60435, Thanks Regards Tom
