I have tried several times to get someone to look at this. I have even put logs out in the forums but I never get a comment of any kind.
The issue I have is Plex Crashes after the DVR is installed. I remove it and it works fine.
I think the issue is the guide it never gets fully loaded before the crash. Plex crashes about 5 10 minutes after DVR installed. I have 10 gig available on the Hard drive so space should not be an issue.
I have the latest version and I have backed down through multiple versions and see no change.
My DVR is on HDHomerun.
How do I get the attention of Plex Support does anyone know?
Help asap???
Checking your account, this is the first post you’ve made. If you can point me to your post with your logs, I can take a look.
