Server Version#: 1.18.3.2129
PMS When recording the new Magnum P.I. show names the file with the 1980 date instead of the 2018 date, so any other server that indexes the media folder will match the wrong version of the show.
Interestingly enough the PMS where the DVR is shows the correct meta data (it’s just the file name that is wrong), so I’m guessing that there is a disconnect between what it decides to name the file and what it used to pull the meta data.
- /volume1/Media/TV Shows/Magnum P.I. (1980)/Season 02/Magnum P.I. (1980) - S02E13 - Mondays Are For Murder.ts
Date should be 2018, 1980.
The debug logs don’t show anything that might indicate why it thinks it should be one year or the other. Most of the logs don’t reference the year at all. Here’s some:
Plex Media Server.3.log:Jan 10, 2020 19:59:03.046 [0x7f7e81abf700] DEBUG - Job running: EAE_ROOT='/volume1/Plex/tmp_transcoding/pms-0e16f13f-dabe-422f-8d96-434f8d06b772/EasyAudioEncoder' FFMPEG_EXTERNAL_LI
BS='/volume1/Plex/Library/Application\ Support/Plex\ Media\ Server/Codecs/8bf330d-2772-linux-x86_64/' XDG_CACHE_HOME='/volume1/Plex/Library/Application Support/Plex Media Server/Cache' XDG_DATA_HOME='/volu
me1/@appstore/Plex Media Server/Resources' X_PLEX_TOKEN='xxxxxxxxxxxxxxxxxxxx' '/volume1/@appstore/Plex Media Server/Plex Transcoder' '-codec:0' 'h264' '-noaccurate_seek' '-live_start_index' '0' '-probesiz
e' '20000000' '-i' 'http://127.0.0.1:32400/livetv/sessions/d2a6da53-a60d-4a4e-b469-49b098f84605/bee88bab-64c9-40dd-a5cb-8449d68a21fa/index.m3u8?offset=-1.000000&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx' '-map' '0
:0' '-codec:0' 'copy' '-map' '0:1' '-metadata:s:1' 'language=eng' '-codec:1' 'copy' '-f' 'mpegts' '-map_metadata' '-1' '-map_chapters' '-1' '/volume1/Media/TV Shows/.grab/c2accb587480f851cadcaee74fe91087e2
1e4a91/Magnum P.I. (1980) - S02E13 - Mondays Are For Murder.ts' '-y' '-nostats' '-loglevel' 'quiet' '-loglevel_plex' 'error' '-xioerror' '-progressurl' 'http://127.0.0.1:32400/video/:/transcode/session/bee
88bab-64c9-40dd-a5cb-8449d68a21fa/9bab39f4-043b-4f8b-9c1f-4a3d33727700/progress'
Plex Media Server.3.log:Jan 10, 2020 21:03:01.337 [0x7f7e1ece6700] DEBUG - Recorder: Asked to stop recording 'Magnum P.I. - E13 - Mondays Are For Murder' on channel 2.1.
Plex Media Server.3.log:Jan 10, 2020 21:03:01.339 [0x7f7e231c1700] DEBUG - Grabber: Recording for 'Magnum P.I. - E13 - Mondays Are For Murder' on channel 2.1 stopped with status complete.
Plex Media Server.3.log:Jan 10, 2020 21:03:01.340 [0x7f7e231c1700] DEBUG - [MI] Opening input file: "/volume1/Media/TV Shows/.grab/c2accb587480f851cadcaee74fe91087e21e4a91/Magnum P.I. (1980) - S02E13 - Mon
days Are For Murder.ts"
Plex Media Server.3.log:Jan 10, 2020 21:03:01.341 [0x7f7e231c1700] DEBUG - [FFMPEG] - Opening '/volume1/Media/TV Shows/.grab/c2accb587480f851cadcaee74fe91087e21e4a91/Magnum P.I. (1980) - S02E13 - Mondays Are For Murder.ts' for reading
Plex Media Server.3.log:Jan 10, 2020 21:03:01.828 [0x7f7e231c1700] DEBUG - [MI] * [mpegts h264/ac3] Duration: 3837727ms, 1920x1080 (1.777778) 29.970fps, bitrate=10167kbps, audio channels=6, optimizedForStreaming=0 ("/volume1/Media/TV Shows/.grab/c2accb587480f851cadcaee74fe91087e21e4a91/Magnum P.I. (1980) - S02E13 - Mondays Are For Murder.ts")
Plex Media Server.3.log:Jan 10, 2020 21:03:01.828 [0x7f7e231c1700] DEBUG - [MI] Closing input file: "/volume1/Media/TV Shows/.grab/c2accb587480f851cadcaee74fe91087e21e4a91/Magnum P.I. (1980) - S02E13 - Mondays Are For Murder.ts"
Plex Media Server.3.log:Jan 10, 2020 21:03:01.828 [0x7f7e231c1700] DEBUG - Grabber: Scheduling 'Magnum P.I. - E13 - Mondays Are For Murder' for assimilation.
Plex Media Server.3.log:Jan 10, 2020 21:03:01.835 [0x7f7e599f0700] DEBUG - Grabber: Postprocessing, we're going to put `Magnum P.I. - E13 - Mondays Are For Murder` in `/volume1/Media/TV Shows/Magnum P.I. (1980)/Season 02/Magnum P.I. (1980) - S02E13 - Mondays Are For Murder.ts`
Plex Media Server.3.log:Jan 10, 2020 21:03:02.080 [0x7f7e599f0700] DEBUG - Grabber: Moving "/volume1/Media/TV Shows/.grab/c2accb587480f851cadcaee74fe91087e21e4a91/Magnum P.I. (1980) - S02E13 - Mondays Are For Murder.ts" to "/volume1/Media/TV Shows/Magnum P.I. (1980)/Season 02/Magnum P.I. (1980) - S02E13 - Mondays Are For Murder.ts"
Plex Media Server.3.log:Jan 10, 2020 21:03:02.834 [0x7f7e599f0700] DEBUG - Added new metadata item (Mondays Are For Murder) with ID 117945
