Server Version#: Version 1.28.0.5999
Tuner Make/Model: HDHomeRun CONNECT DUO
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
Hello, I am curious if I can set the location that the DVR is recording to. My NAS is almost full, and it seems that the DVR is consuming the NAS space. I want to set it to record to an external HD. Thanks.
Just create a new library in Plex using whatever folder you want, then set your recordings to use that library.
