DVR records for a few seconds then stops
Both tuners were in use and then some one canceled.
Apr 22, 2023 04:32:14.653 [0x7f925b1e7b38] DEBUG - Streaming Resource: Terminated session 0x7f9261f75ad8:b88a1550-6e2c-4a79-a629-5495c4b33625 with reason Client stopped playback.
Apr 22, 2023 04:32:14.653 [0x7f925b1e7b38] DEBUG - Streaming Resource: Terminated session 0x7f9263d91168:3a645c10-bcb3-4207-80cd-3666c9f8bb76 with reason Client stopped playback.
this is really strange. there was only this one recording scheduled and as it was 4 am in the morning, now other playing took place…
yesterday 23:07 a recording again created only 0 Byte file (and since then it seems to be broken for all following scheduled recordings)
here is the debug log
Plex Media Server Logs_2023-04-23_11-58-04.zip (5.6 MB)
esp. lines in server log like this look strange:
Apr 22, 2023 23:07:07.406 [0x7f92598acb38] DEBUG - [Grabber/acbc436d65dff70e30c00c2abc63c195892b5d6e] TPU: hardware transcoding: enabled, but no hardware decode accelerator found
it may be related to some stream issue (from tuner service log)
Apr 22, 2023 23:07:13.475 [0x7fd40bd64b38] WARN - [E] http_streamer_t::handle_read: read_error: End of file (2)
Apr 22, 2023 23:07:13.475 [0x7fd40bf6ab38] WARN - [E] http_streamer_t: http write error
Apr 22, 2023 23:07:13.475 [0x7fd40b310b38] INFO - [I] http_streamer_t::send_thread_func: removing http client
Apr 22, 2023 23:07:13.475 [0x7fd40b310b38] INFO - [I] http_streamer_t::send_thread_func: all clients are deleted. Setting exit flag
for me this looks like a bug in PLEX…
I don’t understand the differences:
today 14:27 and 15:07 it did not work; 15:17 it worked well… the only difference was the TV channel …
Plex Media Server Logs_2023-04-23_17-55-58.zip (5.5 MB)
BTW: the hardware acceleration is detected and used properly on streaming live tv:
Apr 23, 2023 21:07:42.720 [0x7f9735dbfb38] DEBUG - [Req#2977e/Transcode/D74FBA6B-A415-4F3C-B61A-8E2B68F44719] TPU: hardware transcoding: final decoder: vaapi, final encoder: vaapi
What I’m seeing for the recording fails is that the transcoder/FFMPEG is exiting with an error:
Here it is from your log for the 14:27 fail:
Apr 23, 2023 14:27:11.851 [0x7f9739c43b38] ERROR - [Req#63f4/Transcode/560fd751-78e7-4831-b95b-05cebac4894d/34d29173-0925-4a79-88f7-42ac4d9db2b7] Could not write header for output file #0 (incorrect codec parameters ?): Invalid argument
and here for the 15:07 fail:
Apr 23, 2023 15:07:12.043 [0x7f9739c43b38] ERROR - [Req#cff4/Transcode/830b3153-bb5f-4c82-ad64-0dd6cf4acb37/b0c3b482-5452-4ce4-9296-922a938c2766] Could not write header for output file #0 (incorrect codec parameters ?): Invalid argument
When I look up ā€œCould not write header for output file #0 (incorrect codec parameters ?)ā€ I find posts where it was determined that the problem was that FFMPEG didn’t have the codec needed to complete a necessary conversion. This could be consistent with one channel broadcasting with a format where you don’t have codecs available for a conversion needed, or the codecs you do have are corrupted for the needed operation. Another channel that works may be using a different audio format (just as an example) that doesn’t need conversion or you do have the needed codecs.
That puts me back to thinking this is a problem with your codecs. If you deleted your codecs then Plex should re-download codecs as needed. If there is something going on where your Plex instance can’t download codecs it is going to cause a problem either now or in the future. Making a backup of your codecs before deleting was a good idea, but if you have to manually restore a codec because Plex couldn’t download, then you may just be restoring the problem.
  • Do you have a firewall on the Linux computer where you run Plex? (UFW or other?)
  • Does your router have DNS Rebind protection? I had to allow plex.direct rebinds in my router config for one of my local devices to connect correctly. @pl_5309 suggests it could be the problem. This Plex article discusses DNS Rebind protection. See the ā€œWhy isn’t it workingā€ section.
  • Are you running any add blockers on your network? I run pi-hole without any interference with Plex, but it is possible that an add blocker could cause an issue.
Since you did see improvement with live tv after deleting, but then had a problem with codecs not downloading, I think this is a good place to focus. I’d suggest re-deleting any codecs you manually restored (or just go through the codec delete process again) and work the problem with Plex not downloading codecs.
@hokierulz thanks for guiding me to the page on DNS rebinding. Now I got the issue and changed it to work with plex.direct. Let’s wait and see if it works better now.
I have no adblocker of FW in place on the server running PLEX…
The linux kernel being used isn’t the default ā€œgenericā€, is this a VM or are you doing other virtualization?
While the Plex Tuner Service certainly has had issues in the past, there are no clear indications that it is crashing. Their might me something external to Plex that is causing the the USB ports to disconnect from the tuners, power, resources etc.
@pl_5309 it is just a bare metal installation of Ubuntu 22.04 LTS from a few months ago…
unfortunately, the problem still persists. I just had a recording stopped after 18 minutes what should have been 1h30m… (started at 14:27 )
I was even able to provoke the 0 byte recording file, when I tried to press the record button from a running live tv stream (while the live stream continued normally)
Plex Media Server Logs_2023-04-24_15-18-41.zip (5.5 MB)
addendum: just again at 16:57 only 10 seconds recorded, ~970KB but the content seems to be invalid (can’t be played)
Plex Media Server Logs_2023-04-24_17-33-30.zip (5.4 MB)
I’ve only looked at the logs for the first set where the recording stopped at 14:27. These are very interesting because there weren’t the codec issues and the transcoder didn’t terminate with an error. This one is very different. The recording started normally:
Apr 24, 2023 14:27:00.528 [0x7f84db475b38] DEBUG - [Grabber/5fc76e33e06f4d002d64116e-5fc705f1104230002d14da54-y6ydldk5pueqpegs6usjhmpk/52a30e4f712748e7b2ed1c567737ff644ae0ab48] Starting operation for 'Liebe nach Rezept (2007)' on channel 5fc76e33e06f4d002d64116e-5fc705db3f45c6002eab5481.
Apr 24, 2023 14:27:00.529 [0x7f84db475b38] DEBUG - [Grabber/5fc76e33e06f4d002d64116e-5fc705f1104230002d14da54-y6ydldk5pueqpegs6usjhmpk/52a30e4f712748e7b2ed1c567737ff644ae0ab48] Activity: registered new activity 6bbe5d23-c400-4588-913f-9933b82378e0 - "Recording"
Apr 24, 2023 14:27:00.529 [0x7f84db475b38] DEBUG - [Grabber/5fc76e33e06f4d002d64116e-5fc705f1104230002d14da54-y6ydldk5pueqpegs6usjhmpk/52a30e4f712748e7b2ed1c567737ff644ae0ab48] Grabber: Remote starting a media grab on device device://tv.plex.grabbers.tunerservice/dvb%23v4l%23%2fsys%2fdevices%2fpci0000%3a00%2f0000%3a00%3a14.0%2fusb1%2f1-1%2f1-1%3a1.0%3a100504024551 ( EyeTV Hybrid, supported) tuner 0.
and even set the correct stop time (it appears that you are CEST, correct?):
Apr 24, 2023 14:27:00.549 [0x7f84db475b38] DEBUG - [Grabber/5fc76e33e06f4d002d64116e-5fc705f1104230002d14da54-y6ydldk5pueqpegs6usjhmpk/52a30e4f712748e7b2ed1c567737ff644ae0ab48] MediaRecorderVirtual: setting stop time to 2023-04-24 16:05:00
but then when it stopped early it was a ā€œnormalā€ recording stop even though it stopped earlier than it should have (e.g. no transcoder errors.) It reported the following line:
Apr 24, 2023 14:46:07.671 [0x7f84decc9b38] DEBUG - [Req#75664/Live/9ace8e4c-518d-4667-b71d-fde2177e593f/bfeb04ff-ec54-49d0-b2ae-fd62bbc3dd6e] buildLiveM3U8: ended due to segment 25181.874922 past end time 2023-04-24 14:05:00.000000000 +0000
This seems odd, but note the +0000, which I believe it indicating that this stop time is being reported in GMT - which I think would be the correct stop time if your time zone is CEST (GMT + 2 would be 16:05, which is correct.)
So, why did it think that GMT 14:05 was past the stop time at 14:46 CEST? Mine works - I’m currently in a time zone that is GMT-4, and mine will report a midnight stop in the same log line for a show that is set to end at 20:00:00.
Would you please check the that the time and time zone are correct on your Linux server where Plex Server runs? Does your tuner have a web interface or some way to check settings and get logs? If so, would you please check that the current time on your tuner is correct, and if your tuner has a time zone setting that it is correct? (It may not have a time zone - my HDHR Extend tuner is always in GMT and works correctly with Plex.)
@hokierulz thank you for taking time for my issues.
Yes, I’m located in Frankfurt, Germany. GMT+2 at the moment and the settings on the machine are correct:
:~$ date
Mo 24. Apr 20:46:47 CEST 2023
I use two pretty old Elgato Hybrid TV USB Sticks. they are pretty simple DVB-C Tuners and have no interface or configuration, but DVBAPI works fine with them as I can see with i.e. Kaffeine
see Elgato EyeTV hybrid - LinuxTVWiki
so it seems, I encounter different problems with similar symptoms… :frowning:
and several more unsuccessful tries:
17:57
18:42
19:37
but also some good ones from a different channel
18:07
18:42
Plex Media Server Logs_2023-04-24_21-16-42.zip (6.1 MB)
Is it appearing to be channel specific? This one is hard because it isn’t consistent, and failures are happening at different points in the recording process with possibly different causes, though I’m still not sure of even that.
One random idea you may want to try: Shut down Plex, pull one of your tuners, and then start Plex and see how it does. Plex should just mark the removed tuner as being dead. If Plex then gets recording failures then capture the logs. Then shut down Plex, switch to the other tuner, start Plex and try again, once again capturing logs if there are failures.
I know you do a lot of recordings, so Plex will have to reduce the number of scheduled recordings when you only have one tuner available. I’m trying to eliminate a scenario where one tuner is bad, or somehow the two tuners aren’t playing nice together…
@hokierulz it is not channel specific, but on some channels it seems to happen more often than on others.
I’ll try with only one Tuner tomorrow. I also have a different one to test also…
@hokierulz no change with only one tuner: I see the 0 Byte and the 10 sec recordings
However, I had to delete the second tuner in Plex as it tried to use it anyway (telling me that something could not be recorded due to missing antenna kable… weird)
I’ll test now with a different tuner…
addendum: my third tuner seems to be broken: no channel found on scanning (of course at the same cable as the other two) :frowning:
now I’m stuck…
Thank you for trying that. This one has been stuck in the back of my head. I THINK we resolved a problem with your codecs - I’m not seeing transcoder codec errors in the last set of logs you sent. Now it just seems to decided to stop recording randomly, but without any actual errors. Be patient with me.
So how does Plex Server decided when to stop recording? From what I can see it stops when it sees a segment of A/V come into the transcoder where the segment end is past the recording end time. For example, I think this was the end of a good recording from your logs:
Apr 24, 2023 19:09:58.256 [0x7f84dc89db38] DEBUG - [Req#977cd/Transcode/4fc22657-beb4-4ad9-a32c-1e9223d20218/20570c6f-0c6e-4399-9c15-ca52e2e9fcc4] Transcoder segment range: 0 - 3776 (3776)
Apr 24, 2023 19:09:58.257 [0x7f84dd323b38] DEBUG - [Req#977d5/Transcode/4fc22657-beb4-4ad9-a32c-1e9223d20218/20570c6f-0c6e-4399-9c15-ca52e2e9fcc4] Transcoder segment range: 0 - 3777 (3776)
Apr 24, 2023 19:09:58.268 [0x7f84db87bb38] DEBUG - [HCl#310a] HTTP requesting GET http://127.0.0.1:32600/devices/dvb%23v4l%230%23%2fsys%2fdevices%2fpci0000%3a00%2f0000%3a00%3a14.0%2fusb1%2f1-2%2f1-2%3a1.0
Apr 24, 2023 19:09:58.321 [0x7f84e5eb5b38] DEBUG - [HttpClient/HCl#310a] HTTP/1.1 (0.1s) 200 response from GET http://127.0.0.1:32600/devices/dvb%23v4l%230%23%2fsys%2fdevices%2fpci0000%3a00%2f0000%3a00%3a14.0%2fusb1%2f1-2%2f1-2%3a1.0 (reused)
Apr 24, 2023 19:09:58.688 [0x7f84dc89db38] DEBUG - [Req#977d1/Live/4fc22657-beb4-4ad9-a32c-1e9223d20218/a0e10ab2-4ec6-476b-83ce-0dd0feb0078d] buildLiveM3U8: min 0 max 3776 ended 0
Apr 24, 2023 19:09:58.690 [0x7f84dc89db38] DEBUG - [Req#977d1/Live/4fc22657-beb4-4ad9-a32c-1e9223d20218/a0e10ab2-4ec6-476b-83ce-0dd0feb0078d] buildLiveM3U8: ended due to segment 3776.780511 past end time 2023-04-24 17:10:00.000000000 +0000
Cool, transcoder segment 3776 ends after the recording end and we stop recording.
Here are your logs from a ā€œfailedā€ recording that stopped without any obvious errors after only ā€œrecordingā€ something like 11 seconds:
Apr 24, 2023 17:57:12.311 [0x7f84e2446b38] DEBUG - [Req#8a1d6/Transcode/4008569e-1d57-42e6-9a4b-d2f7313cb40e/d33532ec-b74d-4893-9afa-4fe6841e6599] Transcoder segment range: 0 - 3 (2)
Apr 24, 2023 17:57:12.311 [0x7f84deadbb38] DEBUG - [Req#8a1d7/Transcode/4008569e-1d57-42e6-9a4b-d2f7313cb40e/d33532ec-b74d-4893-9afa-4fe6841e6599] Transcoder segment range: 0 - 3 (3)
Apr 24, 2023 17:57:12.311 [0x7f84e2446b38] DEBUG - [Req#8a1d9/Transcode/4008569e-1d57-42e6-9a4b-d2f7313cb40e/d33532ec-b74d-4893-9afa-4fe6841e6599] Transcoder segment range: 0 - 4 (3)
Apr 24, 2023 17:57:12.318 [0x7f84deadbb38] DEBUG - [Req#8a1db/Transcode/4008569e-1d57-42e6-9a4b-d2f7313cb40e/d33532ec-b74d-4893-9afa-4fe6841e6599] Transcoder segment range: 0 - 4 (4)
Apr 24, 2023 17:57:12.319 [0x7f84e2446b38] DEBUG - [Req#8a1de/Transcode/4008569e-1d57-42e6-9a4b-d2f7313cb40e/d33532ec-b74d-4893-9afa-4fe6841e6599] Transcoder segment range: 0 - 5 (4)
Apr 24, 2023 17:57:12.338 [0x7f84e079fb38] DEBUG - [Req#8a1b2/Live/4008569e-1d57-42e6-9a4b-d2f7313cb40e/25dc8964-e475-4b2a-910e-499f73a3c020] buildLiveM3U8: min 0 max 4 ended 0
Apr 24, 2023 17:57:12.338 [0x7f84e079fb38] DEBUG - [Req#8a1b2/Live/4008569e-1d57-42e6-9a4b-d2f7313cb40e/25dc8964-e475-4b2a-910e-499f73a3c020] buildLiveM3U8: ended due to segment 21317.664633 past end time 2023-04-24 16:35:00.000000000 +0000
WHAAAAT? Am I missing something obvious or maybe I don’t understand what it is doing? Where did segment 21317 come from that it then said was after the end time and caused it to stop?
Would you check something? Shut down your Plex Server process, and then on you Linux box where Plex server runs go to directory /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions. (I’m pretty sure based on your logs you haven’t overridden the default transcode directory.) Is this directory empty? Based on what I understand, with the Plex Server process shut down it should be. If it isn’t, would you copy/paste back to this thread what is there?
Edit: Please also check /media/christoph/tv_shows/.grab to see if it is empty as well.
@hokierulz I highly appreciate that you spend so much time diving into my problem!
are both empty if PLEX is not running, as you expected… :frowning:
@OttoKerner : Would you be able to recommend anyone that is a Live TV/Recording specialist that could help us? What we are seeing is below.
@chris299 is having an issue that so far I can’t replicate, but he has provided logs with a lot of examples. The behavior is that recordings are inconsistently terminating early. Sometimes the recordings complete, sometimes the recordings terminate early after recording for some time, and sometimes the recordings terminate almost immediately.
When the recordings terminate early they reference a transcoder segment that appears to be out of range for the transcoder segments available, and then it declares that the transcoder segment is beyond the end of the recording (in GMT) and the recording stops. Example:
Apr 24, 2023 14:46:07.670 [0x7f84decc9b38] DEBUG - [Req#75664/Live/9ace8e4c-518d-4667-b71d-fde2177e593f/bfeb04ff-ec54-49d0-b2ae-fd62bbc3dd6e] buildLiveM3U8: min 0 max 1135 ended 0
  • First line: The current transcoder segment range is min 0 max 1135 ended 0
  • Second line: Transcoder segment 25181 is past the end time (in GMT) for the recording (How can we have segment 25181? And the recording end time is supposed the be at 16:05 CEST, or 14:05 GMT as in the second log line, which is still over an hour in the future for this example.)
When the recordings terminate at the right time they reference a transcoder segment that is correctly in the range listed in the previous line of the logs.
Note that these logs are from a server in CEST, so perhaps it is a time zone issue since CEST is GMT + 2, and I’m GMT - 4 and so the issue wouldn’t happen for my recordings…
@BigWheel - would you have any thoughts on this issue, or recommendations for someone that may be able to assist with this recording issue (see the previous post for details.) Any suggestions on how to proceed would be greatly appreciated!
I am also having the EXACT same issue but in Windows 10.
Plex Media Server v1.32.0.6973-a787c5a8e - Microsoft PC x64 - build: windows-x86 windows - GMT -04:00
Windows version: 10.0 (Build 19045), language en-US
HDHomeRun CONNECT 4K
Been recording fine for YEARS, but all of a sudden it started randomly stopping while recording…some shows would make it, but anything 1 hour long would never finish.
I found something interesting. I see the logs of @chris299 the recording crash happened WHILE it was in the middle of processing subscriptions, mine does too! Coincidence? I think not!!!
Here’s my logs, Plex STARTS some ā€œProcessing subscriptionsā€ and then BAM crashes the recording. I checked the logs of a successful 30 minute recording…there was NO ā€œsubscription processingā€, Plex had done it 30 minutes prior.
Here are two logs of the recording failing:
Log 1:
Apr 29, 2023 12:29:28.282 [5720] DEBUG - Activity: registered new activity 6de09f7a-3d02-40d4-b7ae-5a0bed863260 - "Processing subscriptions"
Apr 29, 2023 12:29:28.283 [5720] DEBUG - Subscription: Scheduling subscriptions.
Apr 29, 2023 12:29:28.291 [12812] DEBUG - [Req#1127ab/Transcode/eabe42f3-57f0-451b-9645-7767319b0f1c/e033f553-2957-4edf-80fd-8e8f3099900b] Transcoder segment range: 0 - 1764 (1764)
Apr 29, 2023 12:29:28.292 [10796] ERROR - [Req#1127b4/Transcode/1400e589-a741-4169-b9ae-d00a57090bf1/581cae71-2d7b-4462-a17b-2862e22a8264] av_interleaved_write_frame(): Invalid argument
Apr 29, 2023 12:29:28.296 [10796] ERROR - [Req#1127b7/Transcode/1400e589-a741-4169-b9ae-d00a57090bf1/581cae71-2d7b-4462-a17b-2862e22a8264] Error writing trailer of \\DS220J\Plex\TV Shows\.grab\30f443b71fa317925635f047dbb4ba85b30b3766-6762948aaaca8419fbe3efd4fb234959f252f241\America's Test Kitchen (2001) - S23E14 - Pork Chops and Maple Cake.ts: Invalid argument
Apr 29, 2023 12:29:28.297 [12812] DEBUG - [Req#1127b6/Transcode/eabe42f3-57f0-451b-9645-7767319b0f1c/e033f553-2957-4edf-80fd-8e8f3099900b] Transcoder segment range: 0 - 1765 (1764)
Apr 29, 2023 12:29:28.302 [12812] ERROR - [Req#1127bb/Transcode/1400e589-a741-4169-b9ae-d00a57090bf1/581cae71-2d7b-4462-a17b-2862e22a8264] Error closing file \\DS220J\Plex\TV Shows\.grab\30f443b71fa317925635f047dbb4ba85b30b3766-6762948aaaca8419fbe3efd4fb234959f252f241\America's Test Kitchen (2001) - S23E14 - Pork Chops and Maple Cake.ts: Invalid argument
Apr 29, 2023 12:29:28.333 [4088] DEBUG - Jobs: 'C:\Program Files (x86)\Plex\Plex Media Server\Plex Transcoder.exe' exit code for process 6260 is 1 (failure)
Apr 29, 2023 12:29:28.334 [3880] DEBUG - [Grabber/30f443b71fa317925635f047dbb4ba85b30b3766] Recorder: No more consumers, stopping.
Apr 29, 2023 12:29:28.334 [3880] DEBUG - [Grabber/30f443b71fa317925635f047dbb4ba85b30b3766] Recorder: Asked to stop recording 'America's Test Kitchen - E14 - Pork Chops and Maple Cake' on channel 5fc76c37286b56002e2bb794-5fc705f9088e7d002d4c722e.
Apr 29, 2023 12:29:28.334 [3880] DEBUG - [Grabber/30f443b71fa317925635f047dbb4ba85b30b3766] Recorder: Stopping transcode session.
Apr 29, 2023 12:29:28.334 [3880] DEBUG - [Grabber/30f443b71fa317925635f047dbb4ba85b30b3766] Killing job.
Apr 29, 2023 12:29:28.337 [4624] DEBUG - [Grabber/30f443b71fa317925635f047dbb4ba85b30b3766] Recording for 'America's Test Kitchen - E14 - Pork Chops and Maple Cake' on channel 5fc76c37286b56002e2bb794-5fc705f9088e7d002d4c722e stopped with status complete.
Apr 29, 2023 12:29:28.337 [4624] DEBUG - [Grabber/30f443b71fa317925635f047dbb4ba85b30b3766] Using recording status.
Apr 29, 2023 12:29:28.338 [10808] DEBUG - Streaming Resource: Terminated session 0B80B248:1400e589-a741-4169-b9ae-d00a57090bf1 with reason Recording failed. Please check your tuner or antenna.
Apr 29, 2023 12:29:28.338 [10808] DEBUG - Killing job.
Apr 29, 2023 12:29:28.338 [4624] DEBUG - [Grabber/30f443b71fa317925635f047dbb4ba85b30b3766] Activity: updated activity 75697b94-5e3f-486d-80b2-5db8e87202d6 - completed 100.0% - Recording
Apr 29, 2023 12:29:28.339 [10808] DEBUG - Job was already killed, not killing again.
Apr 29, 2023 12:29:28.339 [10808] DEBUG - Stopping transcode session 1400e589-a741-4169-b9ae-d00a57090bf1
Apr 29, 2023 12:29:28.340 [4624] DEBUG - [Grabber/30f443b71fa317925635f047dbb4ba85b30b3766] Activity: updated activity 75697b94-5e3f-486d-80b2-5db8e87202d6 - completed 100.0% - Recording
Apr 29, 2023 12:29:28.341 [4624] DEBUG - [Grabber/30f443b71fa317925635f047dbb4ba85b30b3766] [MI] Opening input file: "\\DS220J\Plex\TV Shows\.grab\30f443b71fa317925635f047dbb4ba85b30b3766-6762948aaaca8419fbe3efd4fb234959f252f241\America's Test Kitchen (2001) - S23E14 - Pork Chops and Maple Cake.ts"
Apr 29, 2023 12:29:28.342 [4624] DEBUG - [Grabber/30f443b71fa317925635f047dbb4ba85b30b3766] [FFMPEG] - Opening '\\DS220J\Plex\TV Shows\.grab\30f443b71fa317925635f047dbb4ba85b30b3766-6762948aaaca8419fbe3efd4fb234959f252f241\America's Test Kitchen (2001) - S23E14 - Pork Chops and Maple Cake.ts' for reading
Apr 29, 2023 12:29:28.342 [4624] DEBUG - [Grabber/30f443b71fa317925635f047dbb4ba85b30b3766] [FFMPEG] - Setting default whitelist 'file,crypto,data'
Apr 29, 2023 12:29:28.350 [11764] DEBUG - [Grabber/30f443b71fa317925635f047dbb4ba85b30b3766] Activity: updated activity 78b5480d-355e-4e08-9699-95aa71b5f9d6 - completed 75.0% - Refreshing Sub
Apr 29, 2023 12:29:28.352 [3880] DEBUG - [Grabber/30f443b71fa317925635f047dbb4ba85b30b3766] Job was already killed, not killing again.
Apr 29, 2023 12:29:28.352 [3880] DEBUG - [Grabber/30f443b71fa317925635f047dbb4ba85b30b3766] Stopping transcode session eabe42f3-57f0-451b-9645-7767319b0f1c
Apr 29, 2023 12:29:28.372 [4088] DEBUG - Jobs: 'C:\Program Files (x86)\Plex\Plex Media Server\Plex Transcoder.exe' exit code for process 7880 is -1059143458 (intentional termination)
Apr 29, 2023 12:29:28.372 [7988] DEBUG - [Grabber/30f443b71fa317925635f047dbb4ba85b30b3766] Grabber: Freed a tuner on device://tv.plex.grabbers.hdhomerun/1080EB72 (now 4 available)
Apr 29, 2023 12:29:28.373 [8944] DEBUG - [Grabber/30f443b71fa317925635f047dbb4ba85b30b3766] Cleaning directory for session eabe42f3-57f0-451b-9645-7767319b0f1c (C:\Users\MikeTwo\AppData\Local\Plex Media Server\Cache\Transcode\Sessions\plex-transcode-eabe42f3-57f0-451b-9645-7767319b0f1c)
Log 2:
Apr 30, 2023 21:46:18.135 [10016] DEBUG - Activity: registered new activity 87e6c6a2-d01d-4217-88c0-c00283fb26cc - "Processing subscriptions"
Apr 30, 2023 21:46:18.135 [10016] DEBUG - Subscription: Scheduling subscriptions.
Apr 30, 2023 21:46:18.142 [9192] ERROR - [Req#9eb0/Transcode/acbf17a5-659a-4a1e-9dee-d9cd9679d431/974a101d-da1f-46df-80d1-33c812c21ba6] av_interleaved_write_frame(): Invalid argument
Apr 30, 2023 21:46:18.144 [9192] ERROR - [Req#9eb2/Transcode/acbf17a5-659a-4a1e-9dee-d9cd9679d431/974a101d-da1f-46df-80d1-33c812c21ba6] Error writing trailer of \\DS220J\Plex\TV Shows\.grab\c41a6f60aae930f1966224ab20c2bfa632123973-6762948aaaca8419fbe3efd4fb234959f252f241\Tom Jones on Masterpiece (2023) - S01E01 - Tom Jones on Masterpiece.ts: Invalid argument
Apr 30, 2023 21:46:18.150 [9192] ERROR - [Req#9eb4/Transcode/acbf17a5-659a-4a1e-9dee-d9cd9679d431/974a101d-da1f-46df-80d1-33c812c21ba6] Error closing file \\DS220J\Plex\TV Shows\.grab\c41a6f60aae930f1966224ab20c2bfa632123973-6762948aaaca8419fbe3efd4fb234959f252f241\Tom Jones on Masterpiece (2023) - S01E01 - Tom Jones on Masterpiece.ts: Invalid argument
Apr 30, 2023 21:46:18.174 [8496] DEBUG - Jobs: 'C:\Program Files (x86)\Plex\Plex Media Server\Plex Transcoder.exe' exit code for process 9968 is 1 (failure)
Apr 30, 2023 21:46:18.174 [11140] DEBUG - [Grabber/c41a6f60aae930f1966224ab20c2bfa632123973] Recorder: No more consumers, stopping.
Apr 30, 2023 21:46:18.174 [11140] DEBUG - [Grabber/c41a6f60aae930f1966224ab20c2bfa632123973] Recorder: Asked to stop recording 'Tom Jones on Masterpiece - E1 - Tom Jones on Masterpiece' on channel 5fc76c37286b56002e2bb794-5fc705f9088e7d002d4c722e.
Apr 30, 2023 21:46:18.174 [11140] DEBUG - [Grabber/c41a6f60aae930f1966224ab20c2bfa632123973] Recorder: Stopping transcode session.
Apr 30, 2023 21:46:18.174 [11140] DEBUG - [Grabber/c41a6f60aae930f1966224ab20c2bfa632123973] Killing job.
Apr 30, 2023 21:46:18.188 [4688] DEBUG - Streaming Resource: Terminated session 0D073AD8:acbf17a5-659a-4a1e-9dee-d9cd9679d431 with reason Recording failed. Please check your tuner or antenna.
Apr 30, 2023 21:46:18.188 [4620] DEBUG - [Grabber/c41a6f60aae930f1966224ab20c2bfa632123973] Recording for 'Tom Jones on Masterpiece - E1 - Tom Jones on Masterpiece' on channel 5fc76c37286b56002e2bb794-5fc705f9088e7d002d4c722e stopped with status complete.
Apr 30, 2023 21:46:18.188 [4620] DEBUG - [Grabber/c41a6f60aae930f1966224ab20c2bfa632123973] Using recording status.
Apr 30, 2023 21:46:18.189 [4620] DEBUG - [Grabber/c41a6f60aae930f1966224ab20c2bfa632123973] Activity: updated activity fc51e968-d367-445b-b4f8-c8554e49173e - completed 100.0% - Recording
Apr 30, 2023 21:46:18.189 [11140] DEBUG - [Grabber/c41a6f60aae930f1966224ab20c2bfa632123973] Job was already killed, not killing again.
Apr 30, 2023 21:46:18.190 [11140] DEBUG - [Grabber/c41a6f60aae930f1966224ab20c2bfa632123973] Stopping transcode session 8a89e033-03ee-45f2-a09e-65f83c95d58f
Apr 30, 2023 21:46:18.190 [4620] DEBUG - [Grabber/c41a6f60aae930f1966224ab20c2bfa632123973] Activity: updated activity fc51e968-d367-445b-b4f8-c8554e49173e - completed 100.0% - Recording
Apr 30, 2023 21:46:18.190 [4620] DEBUG - [Grabber/c41a6f60aae930f1966224ab20c2bfa632123973] [MI] Opening input file: "\\DS220J\Plex\TV Shows\.grab\c41a6f60aae930f1966224ab20c2bfa632123973-6762948aaaca8419fbe3efd4fb234959f252f241\Tom Jones on Masterpiece (2023) - S01E01 - Tom Jones on Masterpiece.ts"
Apr 30, 2023 21:46:18.190 [4620] DEBUG - [Grabber/c41a6f60aae930f1966224ab20c2bfa632123973] [FFMPEG] - Opening '\\DS220J\Plex\TV Shows\.grab\c41a6f60aae930f1966224ab20c2bfa632123973-6762948aaaca8419fbe3efd4fb234959f252f241\Tom Jones on Masterpiece (2023) - S01E01 - Tom Jones on Masterpiece.ts' for reading
Apr 30, 2023 21:46:18.190 [4620] DEBUG - [Grabber/c41a6f60aae930f1966224ab20c2bfa632123973] [FFMPEG] - Setting default whitelist 'file,crypto,data'
Apr 30, 2023 21:46:18.192 [7792] DEBUG - Killing job.
Apr 30, 2023 21:46:18.192 [7792] DEBUG - Job was already killed, not killing again.
Apr 30, 2023 21:46:18.192 [7792] DEBUG - Stopping transcode session acbf17a5-659a-4a1e-9dee-d9cd9679d431
Apr 30, 2023 21:46:18.205 [5368] DEBUG - [Grabber/c41a6f60aae930f1966224ab20c2bfa632123973] Activity: updated activity e032699b-ce19-46e4-a37b-94added7bc2e - completed 50.0% - Refreshing Sub
Apr 30, 2023 21:46:18.206 [8496] DEBUG - Jobs: 'C:\Program Files (x86)\Plex\Plex Media Server\Plex Transcoder.exe' exit code for process 10404 is -1059143458 (intentional termination)
Apr 30, 2023 21:46:18.206 [3132] DEBUG - [Grabber/c41a6f60aae930f1966224ab20c2bfa632123973] Grabber: Freed a tuner on device://tv.plex.grabbers.hdhomerun/1080EB72 (now 4 available)
Apr 30, 2023 21:46:18.207 [6964] DEBUG - [Grabber/c41a6f60aae930f1966224ab20c2bfa632123973] Cleaning directory for session 8a89e033-03ee-45f2-a09e-65f83c95d58f (C:\Users\MikeTwo\AppData\Local\Plex Media Server\Cache\Transcode\Sessions\plex-transcode-8a89e033-03ee-45f2-a09e-65f83c95d58f)
Apr 30, 2023 21:46:18.226 [7792] DEBUG - Streaming Resource: Removing session 0D073AD8:acbf17a5-659a-4a1e-9dee-d9cd9679d431
@chris299 log:
Apr 24, 2023 13:46:12.778 [0x7f84d9e54b38] DEBUG - Subscription: No match in the library for 'Die Vergesslichkeit der Eichhƶrnchen (2021)', grabbing.
Apr 24, 2023 13:46:12.779 [0x7f84d9e54b38] DEBUG - Activity: updated activity ec8a21ca-b852-47d1-8cbd-3f91fd5321b6 - completed 0.0% - Refreshing Sub
Apr 24, 2023 13:46:12.779 [0x7f84d9e54b38] DEBUG - Activity: updated activity c7521d04-3733-423a-b2df-7362c01edb2b - completed 46.0% - Processing subscriptions
Apr 24, 2023 13:46:12.780 [0x7f84d9e54b38] DEBUG - Activity: updated activity 30dee82b-570f-425f-a944-400364fec640 - completed 0.0% - Refreshing Sub
Apr 24, 2023 13:46:12.781 [0x7f84da45db38] DEBUG - Subscription: No existing library item episode 'grandparentGuid: plex://show/5fc6aca8c2d465002df8e21c grandparentThumb: https://metadata-static.plex.tv/8/gracenote/848d7bcda48393167528f1290a2b374d.jpg grandparentTitle: Punkt 12 - Das RTL-Mittagsjournal grandparentYear: 1992 guid: plex://episode/643375f699fb830f1b1b57a6 originallyAvailableAt: 2023-04-24 parentGuid: plex://season/5fc6aca8c2d465002df8e21c/2023 parentIndex: 2023 parentTitle: Staffel 2023 ratingKey: plex%3A%2F%2Fepisode%2F643375f699fb830f1b1b57a6 title: Punkt 12 - Das RTL-Mittagsjournal type: 4 year: 2023'
Apr 24, 2023 13:46:12.781 [0x7f84da45db38] DEBUG - Subscription: Checking in provider Live TV & DVR
Apr 24, 2023 13:46:12.781 [0x7f84da45db38] DEBUG - Downloading document http://127.0.0.1:32400/tv.plex.providers.epg.cloud:2/metadata/plex%3a%2f%2fepisode%2f643375f699fb830f1b1b57a6?includeChapters=1&includeMarkers=1&includeParentKey=1&includePreferences=1
Apr 24, 2023 13:46:12.785 [0x7f84d9e54b38] DEBUG - Subscription: No existing library item episode 'grandparentGuid: plex://show/63033fd2a7a864b0a77f4ec4 grandparentThumb: https://metadata-static.plex.tv/a/gracenote/ac5242cb3dd2b50c1e3c5b2963231d8e.jpg grandparentTitle: Barbara Salesch - Das Strafgericht grandparentYear: 2022 guid: plex://episode/64424acda6921a45d9957269 index: 20 originallyAvailableAt: 2023-04-24 parentGuid: plex://season/63033fd2a7a864b0a77f4ec4/3 parentIndex: 3 parentTitle: Staffel 3 ratingKey: plex%3A%2F%2Fepisode%2F64424acda6921a45d9957269 title: Baby-Geburtstag eskaliert! Stieß Großmutter Gast vom Balkon? type: 4 year: 2023'
Apr 24, 2023 13:46:12.786 [0x7f84d9e54b38] DEBUG - Subscription: Checking in provider Live TV & DVR
Apr 24, 2023 13:46:12.786 [0x7f84d9e54b38] DEBUG - Downloading document http://127.0.0.1:32400/tv.plex.providers.epg.cloud:2/metadata/plex%3a%2f%2fepisode%2f64424acda6921a45d9957269?includeChapters=1&includeMarkers=1&includeParentKey=1&includePreferences=1
Apr 24, 2023 13:46:12.791 [0x7f84da45db38] DEBUG - Subscription: The item at /tv.plex.providers.epg.cloud:2/metadata/plex%3A%2F%2Fepisode%2F643375f699fb830f1b1b57a6 is of type 4
Apr 24, 2023 13:46:12.791 [0x7f84da45db38] DEBUG - Downloading document http://127.0.0.1:32400/tv.plex.providers.epg.cloud:2/metadata/plex%3a%2f%2fshow%2f5fc6aca8c2d465002df8e21c?includeChapters=1&includeMarkers=1&includeParentKey=1&includePreferences=1
Apr 24, 2023 13:46:12.798 [0x7f84d9e54b38] DEBUG - Subscription: The item at /tv.plex.providers.epg.cloud:2/metadata/plex%3A%2F%2Fepisode%2F64424acda6921a45d9957269 is of type 4
Apr 24, 2023 13:46:12.798 [0x7f84d9e54b38] DEBUG - Downloading document http://127.0.0.1:32400/tv.plex.providers.epg.cloud:2/metadata/plex%3a%2f%2fshow%2f63033fd2a7a864b0a77f4ec4?includeChapters=1&includeMarkers=1&includeParentKey=1&includePreferences=1
Apr 24, 2023 13:46:12.866 [0x7f84decc9b38] DEBUG - Request: [192.168.246.129:60234 (Subnet)] DELETE /media/subscriptions/451 (18 live) #68a85 TLS GZIP Signed-in Token (chris299) (DELL-XPS-CW)
Apr 24, 2023 13:46:12.866 [0x7f84decc9b38] DEBUG - [Req#68a85] Subscription: Cancelling grabs for subscription 451: 'Live TV - Session y6ydldk5pueqpegs6usjhmpk' on channel 5fc76e33e06f4d002d64116e-5fc705f1104230002d14da55
Apr 24, 2023 13:46:12.866 [0x7f84decc9b38] DEBUG - [Req#68a85/Grabber/5fc76e33e06f4d002d64116e-5fc705f1104230002d14da55-y6ydldk5pueqpegs6usjhmpk] Cancelling operation for 'Live TV - Session y6ydldk5pueqpegs6usjhmpk' on channel 5fc76e33e06f4d002d64116e-5fc705f1104230002d14da55 with status cancelled.
Apr 24, 2023 13:46:12.866 [0x7f84decc9b38] DEBUG - [Req#68a85/Grabber/5fc76e33e06f4d002d64116e-5fc705f1104230002d14da55-y6ydldk5pueqpegs6usjhmpk] Operation was active, stopping recorder.
Apr 24, 2023 13:46:12.866 [0x7f84decc9b38] DEBUG - [Req#68a85/Grabber/5fc76e33e06f4d002d64116e-5fc705f1104230002d14da55-y6ydldk5pueqpegs6usjhmpk] We've cancelled the grab with 292 seconds remaining.
Apr 24, 2023 13:46:12.866 [0x7f84dd6b3b38] DEBUG - [Grabber/5fc76e33e06f4d002d64116e-5fc705f1104230002d14da55-y6ydldk5pueqpegs6usjhmpk] Recording for 'Live TV - Session y6ydldk5pueqpegs6usjhmpk' on channel 5fc76e33e06f4d002d64116e-5fc705f1104230002d14da55 stopped with status complete.
Apr 24, 2023 13:46:12.866 [0x7f84dd6b3b38] DEBUG - [Grabber/5fc76e33e06f4d002d64116e-5fc705f1104230002d14da55-y6ydldk5pueqpegs6usjhmpk] This was a rolling sub, not assimilating.
Apr 24, 2023 13:46:12.866 [0x7f84dd6b3b38] DEBUG - [Grabber/5fc76e33e06f4d002d64116e-5fc705f1104230002d14da55-y6ydldk5pueqpegs6usjhmpk] Grabber: Operation for 'Live TV - Session y6ydldk5pueqpegs6usjhmpk' on channel 5fc76e33e06f4d002d64116e-5fc705f1104230002d14da55 completed with status complete (Success)
Apr 24, 2023 13:46:12.867 [0x7f84dd6b3b38] DEBUG - [Grabber/5fc76e33e06f4d002d64116e-5fc705f1104230002d14da55-y6ydldk5pueqpegs6usjhmpk] Activity: Ended activity ff8c3676-72c0-430a-a749-1a03a4c089d0.
Apr 24, 2023 13:46:12.867 [0x7f84dd6b3b38] DEBUG - [Grabber/5fc76e33e06f4d002d64116e-5fc705f1104230002d14da55-y6ydldk5pueqpegs6usjhmpk] Grabber: Cleaning up rolling grab for channel 5fc76e33e06f4d002d64116e-5fc705f1104230002d14da55.
Apr 24, 2023 13:46:12.867 [0x7f84dd6b3b38] DEBUG - [Grabber/5fc76e33e06f4d002d64116e-5fc705f1104230002d14da55-y6ydldk5pueqpegs6usjhmpk] Recorder: No more consumers, stopping.
Apr 24, 2023 13:46:12.867 [0x7f84dd6b3b38] DEBUG - [Grabber/5fc76e33e06f4d002d64116e-5fc705f1104230002d14da55-y6ydldk5pueqpegs6usjhmpk] Recorder: Asked to stop recording 'Live TV - Session y6ydldk5pueqpegs6usjhmpk' on channel 5fc76e33e06f4d002d64116e-5fc705f1104230002d14da55.
Apr 24, 2023 13:46:12.867 [0x7f84dd6b3b38] DEBUG - [Grabber/5fc76e33e06f4d002d64116e-5fc705f1104230002d14da55-y6ydldk5pueqpegs6usjhmpk] Recorder: Stopping transcode session.
Apr 24, 2023 13:46:12.867 [0x7f84dd6b3b38] DEBUG - [Grabber/5fc76e33e06f4d002d64116e-5fc705f1104230002d14da55-y6ydldk5pueqpegs6usjhmpk] Killing job.
Apr 24, 2023 13:46:12.867 [0x7f84dd6b3b38] DEBUG - [Grabber/5fc76e33e06f4d002d64116e-5fc705f1104230002d14da55-y6ydldk5pueqpegs6usjhmpk] Signalling job ID 107285 with 9
Apr 24, 2023 13:46:12.867 [0x7f84dd6b3b38] DEBUG - [Grabber/5fc76e33e06f4d002d64116e-5fc705f1104230002d14da55-y6ydldk5pueqpegs6usjhmpk] Job was already killed, not killing again.
Apr 24, 2023 13:46:12.867 [0x7f84dd6b3b38] DEBUG - [Grabber/5fc76e33e06f4d002d64116e-5fc705f1104230002d14da55-y6ydldk5pueqpegs6usjhmpk] Stopping transcode session 3014bf3e-1711-4f83-98e2-0a3b31d15fa6
Apr 24, 2023 13:46:12.867 [0x7f84db475b38] DEBUG - [HCl#1e7c] HTTP requesting GET http://127.0.0.1:32600/devices/dvb%23v4l%230%23%2fsys%2fdevices%2fpci0000%3a00%2f0000%3a00%3a14.0%2fusb1%2f1-1%2f1-1%3a1.0
Apr 24, 2023 13:46:12.867 [0x7f84dc690b38] DEBUG - [Grabber/5fc76e33e06f4d002d64116e-5fc705f1104230002d14da55-y6ydldk5pueqpegs6usjhmpk] Activity: updated activity ad5dfb9e-0f83-4004-b802-2d97e8cf917e - completed 100.0% - Refreshing Sub
Apr 24, 2023 13:46:12.867 [0x7f84decc9b38] DEBUG - [Req#68a85] Activity: registered new activity 71bcf7f6-8bb4-4cf4-805f-daac5e90ede6 - "Processing subscriptions"
Apr 24, 2023 13:46:12.868 [0x7f84decc9b38] DEBUG - [Req#68a85] Subscription: Scheduling subscriptions.
Apr 24, 2023 13:46:12.868 [0x7f84dd6b3b38] DEBUG - [Grabber/5fc76e33e06f4d002d64116e-5fc705f1104230002d14da55-y6ydldk5pueqpegs6usjhmpk] Grabber: Freed a tuner on device://tv.plex.grabbers.tunerservice/dvb%23v4l%23%2fsys%2fdevices%2fpci0000%3a00%2f0000%3a00%3a14.0%2fusb1%2f1-1%2f1-1%3a1.0%3a100504024551 (now 1 available)
Apr 24, 2023 13:46:12.868 [0x7f84e7df9b38] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 107285 is -9 (signal: Killed)
Apr 24, 2023 13:46:12.868 [0x7f84dc893b38] DEBUG - Notifying consumer that data is complete.
Apr 24, 2023 13:46:12.869 [0x7f84dc690b38] DEBUG - [Grabber/5fc76e33e06f4d002d64116e-5fc705f1104230002d14da55-y6ydldk5pueqpegs6usjhmpk] Activity: Ended activity ad5dfb9e-0f83-4004-b802-2d97e8cf917e.
Apr 24, 2023 13:46:12.869 [0x7f84e7bf6b38] DEBUG - Completed: [127.0.0.1:54050] 200 GET /livetv/sessions/3014bf3e-1711-4f83-98e2-0a3b31d15fa6/y6ydldk5pueqpegs6usjhmpk/00006.ts (17 live) #68a3f 383ms 262185 bytes (pipelined: 4) (range: bytes=0-)
Apr 24, 2023 13:46:12.869 [0x7f84e7bf6b38] DEBUG - Removed transcode data consumer, active count 1 => 0
Apr 24, 2023 13:46:12.869 [0x7f84db87bb38] DEBUG - Cleaning directory for session 3014bf3e-1711-4f83-98e2-0a3b31d15fa6 (/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-3014bf3e-1711-4f83-98e2-0a3b31d15fa6)
Apr 24, 2023 13:46:12.869 [0x7f84dd6b3b38] DEBUG - [Grabber/5fc76e33e06f4d002d64116e-5fc705f1104230002d14da55-y6ydldk5pueqpegs6usjhmpk] Subscription: Cancelling grabs for subscription 451: 'Live TV - Session y6ydldk5pueqpegs6usjhmpk' on channel 5fc76e33e06f4d002d64116e-5fc705f1104230002d14da55
Apr 24, 2023 13:46:12.871 [0x7f84d9c51b38] DEBUG - Request: [127.0.0.1:54180 (Loopback)] GET /livetv/sessions/3014bf3e-1711-4f83-98e2-0a3b31d15fa6/y6ydldk5pueqpegs6usjhmpk/index.m3u8?offset=0.000000 (17 live) #68cd0 Signed-in Token (chris299) (DELL-XPS-CW) (range: bytes=0-)
Apr 24, 2023 13:46:12.871 [0x7f84d9c51b38] WARN - [Req#68cd0/Live/3014bf3e-1711-4f83-98e2-0a3b31d15fa6] Failed to find consumer
Apr 24, 2023 13:46:12.871 [0x7f84e79f3b38] DEBUG - Completed: [127.0.0.1:54180] 404 GET /livetv/sessions/3014bf3e-1711-4f83-98e2-0a3b31d15fa6/y6ydldk5pueqpegs6usjhmpk/index.m3u8?offset=0.000000 (17 live) #68cd0 0ms 288 bytes (pipelined: 3) (range: bytes=0-)
Apr 24, 2023 13:46:12.871 [0x7f84dd6b3b38] DEBUG - [Grabber/5fc76e33e06f4d002d64116e-5fc705f1104230002d14da55-y6ydldk5pueqpegs6usjhmpk] Activity: registered new activity 35e02d3c-6ca6-4809-b9c4-71eb7410d828 - "Processing subscriptions"
Apr 24, 2023 13:46:12.871 [0x7f84e1331b38] DEBUG - Request: [127.0.0.1:54286 (Loopback)] GET /livetv/sessions/3014bf3e-1711-4f83-98e2-0a3b31d15fa6/y6ydldk5pueqpegs6usjhmpk/index.m3u8?offset=0.000000 (17 live) #68cf3 Signed-in Token (chris299) (DELL-XPS-CW) (range: bytes=0-)
Apr 24, 2023 13:46:12.872 [0x7f84e1331b38] WARN - [Req#68cf3/Live/3014bf3e-1711-4f83-98e2-0a3b31d15fa6] Failed to find consumer
Apr 24, 2023 13:46:12.872 [0x7f84e7bf6b38] DEBUG - Completed: [127.0.0.1:54286] 404 GET /livetv/sessions/3014bf3e-1711-4f83-98e2-0a3b31d15fa6/y6ydldk5pueqpegs6usjhmpk/index.m3u8?offset=0.000000 (17 live) #68cf3 0ms 288 bytes (pipelined: 1) (range: bytes=0-)
Apr 24, 2023 13:46:12.872 [0x7f84de4bdb38] DEBUG - Request: [127.0.0.1:54300 (Loopback)] GET /livetv/sessions/3014bf3e-1711-4f83-98e2-0a3b31d15fa6/y6ydldk5pueqpegs6usjhmpk/index.m3u8?offset=0.000000 (18 live) #6944b Signed-in Token (chris299) (DELL-XPS-CW) (range: bytes=0-)
Apr 24, 2023 13:46:12.872 [0x7f84de4bdb38] WARN - [Req#6944b/Live/3014bf3e-1711-4f83-98e2-0a3b31d15fa6] Failed to find consumer
Apr 24, 2023 13:46:12.873 [0x7f84e7bf6b38] DEBUG - Completed: [127.0.0.1:54300] 404 GET /livetv/sessions/3014bf3e-1711-4f83-98e2-0a3b31d15fa6/y6ydldk5pueqpegs6usjhmpk/index.m3u8?offset=0.000000 (18 live) #6944b 0ms 288 bytes (pipelined: 1) (range: bytes=0-)
Apr 24, 2023 13:46:12.873 [0x7f84ddfffb38] DEBUG - [Req#69453/Transcode/ccd2rdlmucl6fwmhmxko92g1/2edfbd97-0ddc-46ed-a626-18bcf5be44a0] Transcoder segment range: 0 - 5 (5)
Apr 24, 2023 13:46:12.875 [0x7f84decc9b38] DEBUG - [Req#68a85] It took 150.000000 ms to retrieve 59 items.
Apr 24, 2023 13:46:12.875 [0x7f84e7df9b38] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 107304 is 0 (success)
Apr 24, 2023 13:46:12.875 [0x7f84da863b38] DEBUG - Notifying consumer that data is complete.
Apr 24, 2023 13:46:12.875 [0x7f84df0c4b38] DEBUG - Killing job.
Apr 24, 2023 13:46:12.875 [0x7f84dbc8cb38] DEBUG - [TranscodeOutputStream] Input processing thread exited after writing 4624356 bytes, m_closed=0, m_endOfFileReached=1, session->isStopped()=0
Apr 24, 2023 13:46:12.875 [0x7f84df0c4b38] DEBUG - Signalling job ID 107304 with 9
Apr 24, 2023 13:46:12.875 [0x7f84df0c4b38] DEBUG - Job was already killed, not killing again.
Apr 24, 2023 13:46:12.875 [0x7f84df0c4b38] DEBUG - Stopping transcode session ccd2rdlmucl6fwmhmxko92g1
Apr 24, 2023 13:46:12.876 [0x7f84db06fb38] DEBUG - Cleaning directory for session ccd2rdlmucl6fwmhmxko92g1 (/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-ccd2rdlmucl6fwmhmxko92g1-2edfbd97-0ddc-46ed-a626-18bcf5be44a0)
Apr 24, 2023 13:46:12.876 [0x7f84da863b38] DEBUG - Streaming Resource: Terminated session 0x7f84e003c048:y6ydldk5pueqpegs6usjhmpk with reason Recording failed. Please check your tuner or antenna.
@hokierulz Thank you very much for your efforts again.
Do you think there’s a chance someone at Plex will take a look at this?
Unfortunately, an unreliable DVR doesn’t make sense… :frowning:
The person to help would be SA2000 but if you are still using the EyeTV that isn’t on the supported or community supported list. https://support.plex.tv/articles/225877427-supported-dvr-tuners-and-antennas/
In the past there has been a problem with the ā€˜Plex Tuner Service’ sometimes crashing and restarting but in the end I think getting a supported tuner will at least put the ball back in the Plex court.
