DVR Setup Fails at postcode - Unable to Fetch Guide Settings
Server Version#: 1.19.3.2793
Player Version#: Any
Tuner Make/Model: HDHomerun Quattro
Guide/Lineup name: English - EX39
Using XMLTV?: No
Channel number/Name: N/A
EPG whent empty, so I did the usual and removed the DVR to add it back in, unfortunately it won’t add back in… Fails at the Postcode.
Occasionally if I keep trying it gets to the next stage then dies.
Looking at the logs the only real error is:
May 13, 2020 14:33:25.502 [0x7f9f97735700] ERROR - Error issuing curl_easy_perform(handle): 28
May 13, 2020 14:33:25.502 [0x7f9f97735700] DEBUG - HTTP simulating 408 after curl timeout
May 13, 2020 14:33:25.502 [0x7f9f97735700] ERROR - HTTP 408 downloading url https://epg.provider.plex.tv/lineups?country=GB&postalCode=EX3&X-Plex-Api-Token=xxxxxxxxxxxxxxxxxxxx
Needless to say, I’ve tried reinstalling Plex and getting the latest version.
I can see lots of posts about EPG not working properly, so it’s probably related, but I can’t get the Tuner installed to see!
What we need is a way to install the tuner ignoring the EPG, with the option to record by selecting the time, date and channel for when this stuff goes wrong (which it seems to quite regularly!)
Anyone else having this issue?
I’m getting the same error. I had a channel line-up change and had to delete and re add my HD HomeRun Prime and now I’m getting this exact same error.
