DVR Setup + Postcode
I’m trying to run Setup for the Live TV & DVR, however when clicking through to the page where you select language and post code I’m unable to get past. I’ve tried looking this up and people have mentioned only using 3 digits so I’ve tried also ‘TS1’ etc but having no luck and the Continue button shows as greyed out.
My server is running within Docker on Unraid using Version 1.15.1.791 - binhex/arch-plex:1.15.1.791-6-02
dvr
The first problem:
There has been a change in DVR EPG provider that came in on 1st July. The minimum version of Plex Media Server is 1.16.
The second problem:
Thank you! Just updated to 1.18.5.2309 and this has solved my issue. Can’t remember why now but I had to downgrade a while ago and didn’t realise I wasn’t on the latest. :slight_smile:
