n01an
June 26, 2019, 7:30pm
1
I setup a plex server, currently running Version 1.16.1.1273 on windows 10.
The problem has persisted over multiple updates, and it’s finally annoying enough to make a post about.
When i schedule recordings, the folders that are created are always missing the first letter.
Example, Paw Patrol recordings get generated in a folder called aw Patrol.
The recordings themselves are properly named.
Any ideas?
Do you have fancy characters in the path name of your tv show folder?
Please post the complete path.
n01an
June 26, 2019, 8:21pm
3
I don’t think it’s anything fancy. There are several recording folders, which are mapped as drive letters in windows. The actual shares reside on a Synology NAS.
K:\ is where Kid Shows are recorded, as is just chosen as the K:\ in the recording options.
So you are using the naked drive letter and no folder?
I cannot recommend this. Always use a subfolder as “target” for a library.
n01an
June 26, 2019, 8:35pm
5
Thanks, i’ll give it a shot and post results.
system
Closed
September 24, 2019, 8:35pm
6
