DVR temporary file location
When recording to DVR where are the temporary files saved?
Is it possible to change the location?
I believe they post to a .grab folder wherever you have your recordings aimed to go. I have a whole separate library and folder structure for DVRd shows, so this folder is easy to find for me.
Thank you. That means they are going to the disk that I want them to.
If you see the grab folder in that location, then you’re good.
