DVR UK Postcodes Not Working
Just updated to latest version and got a message to delete and setup a new DVR which I have. Now I can’t complete the setup of the new DVR as it won’t accept ANY UK postcode. So now I have no DVR at all.
Any way to get this working?
Server Version#: 1.21.1.3830
Tuner Make/Model: HDHomeRun CONNECT QUATRO
Guide/Lineup name:
Using XMLTV?: no
Channel number/Name:
My post code works. Don’t forget it has to be upper case letters. May I ask are you able to get HD channels to show and play in Plex.
Got it to work by entering a london postcode SE2 instead of my Kent one DA1, strange but now works.
HD channels are also showing.
Oh that’s good. I may need to buy hdhomerun then
What I have noticed is that the new EPG seems to be a bit more up to date i.e. tagging “new” shows properly. Was a bit hit and miss before, suppose time will tell if this continues.
oh that’s good then as I am new to using the dvr function on plex. Would you know if it is possible to use hardware transcoding on live tv streaming. Even though shoud’nt need it just be a fun feature to use.
Also just got HD channels to work after a week of trying.
Capital letters! Been trying this for days after also deleting as guided. Never thought to try capitals! Thanks.
