DVR will not schedule a recording for a higher quality episode then the one that currently exists
Server Version#: 1.22.1.4275
Tuner Make/Model: HDHomeRun CONNECT QUATRO
Guide/Lineup name: Star Trek 1966
Channel number/Name: H&I (480i) / MeTV (720p)
In the show’s recording options I have enabled replace lower resolution items. If the show is initially recorded in lower resolution - 480i, the DVR will not schedule a recording of the higher resolution of the show at 720p. Currently I have to manually go in and delete the recording and then the DVR recognizes that there is no recording and will schedule it. I have noticed this issue with other shows as well and a completely different server with a different tuner. Is there a log I can check for why this happens.
