Ubuntu 16.04LTS
Server Version#: 1.15.0.659 (Docker installation)
Player Version#: 3.77.4
For recording, I have it set to replace lower resolution episodes.
It appears that episodes recorded in 480i are not being replaced by 720p version. Note that the 480i was already watched, but I would think it would replace it whether it was watched or not.
Note that the 480i episodes are way ahead (season 4) of the 720p episodes (season 2).
Under the Recordings -> Calendar View, only the 480i shows that it will be recorded, but not the 720p. The same program is on at the same time, but different channels obviously.
If I change the recording parameters to record only from the 720p channel and/or HD only , it does not show up under Recordings -> Calendar View neither.
So it appears that the recording over lower resolution episodes does not work, is this a known bug?
