DVR Won't let me select library as destination for DVR
As the title says, I can’t select a particular library (called “Recorded TV”) as the destination library for the show… I’ve tried changing the type of library, from TV to Other to Movie, nothing works…
Can anyone give me a hint as to what I’m doing wrong? This used to work fine on my previous Plex Server (I just migrated), so I’m at a bit of a loss as to what I’m doing wrong
ok, found the issue, program was being misidentified from the EPG…
Hi, I have this exact problem where i cannot see some libraries as a destination for my DVR recordings but i don’t understand what you mean by the solution, can you explain more please?
I have figured it out, i had to assign the groups to each category in xTeVe i.e. “Series” “Films” etc then Plex figured out which folder they could go into.
my EPG provider mislabeled the show… It was a TV show, but was listed as a movie…
As such, because the library was classified as “TV”, the DVR wouldn’t let me set the destination there as it thought the show was a Movie
