Edi cast
OK so am trying to add TV shows to my plex account but it completely came up with the wrong show and cast and meta-data, so I am asking that a feature be added too where you can edit the cast
If the show is incorrect then your 2 best options are (the easiest method first).
  1. Fix Match
  2. The Plex Dance ™
I would however recommend the 2nd option because in the event your plex crashes and you have to rebuild everything up again you won’t need to do another “fix match” again.
And welcome to the forums!
Hi @Freestyler589 – as per NewPlaza’s comment… you should either automatically get that data by following the naming conventions or alternatively manually fixing an incorrect match.
As for editing the cast itself, there already exists a feature suggestion with more votes. Hence I’m closing this one to avoid votes being distributed between the 2 of them (and none getting sufficient attention).
