Editing advanced parameters
Server Version#:4.139.0
I found an article for advanced option control in plex. It lists several types of servers but not QNAP.
Does anyone know where we can control something like LongRunningJobThreads ?
Sonic has taken nearly two weeks to process my music libary but it keeps stalling.
When i run ‘top’, i can see two processes running. I’ve 4 cores in the qnap. and it looks like one process grabs 3, leaving just one for the second process and everything else.
I thought I’d lower the value to 1 and see if that helped stop it pausing, but not sure where to update the variable.
For an easy way, try this 3rd. Party tool:
thanks, I’ve found the UI for the plugin there (vv3.0.0) but can’t get past login yet
ah… I think thats the non-NG version. Is Webtools NG compatible with QNAP ?
For QNAP it should be in /.qpkg/PlexMediaServer/Library/Plex Media Server ( might be a bit different depending on which version of OS you have running) https://support.plex.tv/articles/202915258-where-is-the-plex-media-server-data-directory-located/
What I do is make a shared folder in FileStation to /.qpkg/PlexMediaServer which i then can mount to my computer to access the files.
Yes, it runs on your desktop
