Qnap faq.....read me first!
Welcome to Plex QNAP FAQ:
This post will try and answer some common questions related to the combination of QNAP and Plex Media Server
For more general Tips & Tricks, see this
First of all, we urge you to look @ our support site on the NAS Guide page
Questions:
Q1: I installed the latest version, or?
If so, then make sure you didn’t do it from QNAP App-Center, since the version held on the QNAP App-Store is almost always behind the latest release
We suggest you visit http://plex.tv/download instead
Back to top
Q2: Which version do I need, Intel or Arm?
It all depends on the processor that your QNAP is running…If Intel or AMD, then go for the Intel one, but if ARM, go for the ARM one.
And to check what version you got, visit http://www.qnap.com/i/en/product/ and select your product. Then click on specifications, and look @ the top under CPU. Also note, that if running Intel, and using QTS 4.3 or above, that you need the 64bit version of PMS
Back to top
Q3: You say Arm CPU, but is all Arm devices supported?
Sadly no,
X-19 devices (most Marvel devices) are no longer developed, but still functional, and the last available version is V0.9.16.6.
X31 devices are fully supported, and developed.
X31Plus devices are fully supported, and developed.
Look here
Back to top
Q4: Will my QNAP be powerful enough to support client X?
Look here
And note, that different clients have different demands, so look up the specs for your client OS, since Plex relies on that. Without native OS support, the Plex Client has to depend on the Plex Server to transcode the media
Back to top
Q5: How do I install a downloaded QPKG from Plex?
When logging into QNAP Admin interface, select the QNAP App-Center, and then Manual install.
You can find a guide here, that shows how to install .qpkg’s manually.
Back to top
Q6: Do I have to uninstall before installing a new version?
Nope, and a bad idea…If you do so, all your information will be lost…Instead, and recommended, simply install on top of the old one
Back to top
Q7: How do I do a complete reinstall of Plex on my QNAP
In QNAP Admin Interface, select the App-Center, and then hit more/remove. After it’s done, install again. (Note that all your Metadata etc. will be gone)
Back to top
Q8: How do I find the installed version of Plex Media Server?
Simply launch the QNAP admin interface, and look in the App Center. It’s written on the icon for Plex
Back to top
Q9: How do I find out what model of QNAP I’m running?
QNAP Admin Interface. Select “Control Panel”/“System Information”. Look @ the summary page
Back to top
Q10: How do I find the QNAP firmware I’m running?
Same as above
Back to top
Q11: Where is the Plex install directory
Since this depends on your harddrive setup, do this:
Connect to the console of QNAP (SSH, look below), and type:
getcfg -f /etc/config/qpkg.conf PlexMediaServer Install_path
Back to top
Q12: How do I get to the logs directory?
Look at the Q11 above, and to the path returned, add /Library/Plex Media Server/Logs
To access it, use either SSH if on some kinda Linux, or WinSCP/Putty if on Windows.
( Hint…Also look @ Q18 as well as the easy on here: Q25
Back to top
Q13: How do I connect to my QNAP with SSH?
Depends on your OS:
  • Windows older than V10→ Use Putty.exe
  • Mac and Linux & Windows 10 and above→ In a terminal, type ssh admin@“INSERT IP ADDRESS OF QNAP”
    Back to top
Q14: Where should I put my medias?
It’s not important, as long as you DO NOT use the default shares from QNAP, like “Multimedia” etc, since they also are used with some QNAP bundled applications, that creates files and directories, that confuse the Plex scanners. If you however decide to go with that directory, we urge you to look for hidden directories and files in it, and add an exclusion for those by using PlexIgnore functionallity.
And to create a shared folder just for Plex Medias, follow this guide and remember to grant full rights to your self, so you can add new items there.
Back to top
Q15: Adding a plug-in from a Windows workstation
If running WinSCP then make sure that you have enabled to show hidden files and folders (Ctrl-Alt-H). Also make sure, that you connect using SFTP!
Then the path should be like what’s found in Q11, but add the following to the path: “/Library/Plex Media Server/Plug-ins”
After adding a plug-in, you’ll have to disable/enable your PMS from the QNAP Web-Interface
As an alternative, you could also install this one, which create an admin Share on your QNAP, pointing to the Library directory
Back to top
Q16: I have a problem with plex.tv, where I can connect to it, but not the reverse,
First of all, you need to make sure, that port forwarding is enabled on your router/firewall. See Troubleshooting Remote Access
Also make sure, that jumbo frames is not enabled, since this would break plex.tv communications. It must be set to 1500
Back to top
Q17: My media are located on a remote NAS or something else, but regardless, I need to run some script during every restart of my QNAP
This is a bit more complicated, if not used to Linux, so here’s the guide:
  • Log into your QNAP device using SSH or Telnet, and if on Windows use WinSCP ( See Q15)
  • Create a directory named : /share/MD0_DATA/.qpkg/autorun
    ** (Note that MD0_DATA might have to be replaced with something else…See Q11, and look in the path returned)
  • Now we need to edit the file controlling all the installed QPKG’s
  • Edit the file named: /etc/config/qpkg.conf (Use WinSCP if on Windows, or VI if in an SSH
    Add the following:​
[autorun]
Name = autorun
Version = 0.1
Author = Plex Community
Date = 2015-06-09
Shell = /share/MD0_DATA/.qpkg/autorun/autorun.sh
Install_Path = /share/MD0_DATA/.qpkg/autorun
Enable = TRUE
(And in above, again might have to replace “MD0_DATA” with something like “CACHEDEV1_DATA”
  • Now create a file named: /share/MD0_DATA/.qpkg/autorun/autorun.sh
    Make sure, that the first line in this file is: #!/bin/sh
    Make sure, that the autorun.sh file just created, has executable rights:
    In WinSCP, right-click and select properties
    In SSH:
    chmod +x /share/MD0_DATA/.qpkg/autorun/autorun.sh
Now add the rest of your script after the first line to the autorun.sh file
Reboot and test
Back to top
Q18: Making it easy for the future
If you want fast access to like logs and plugin’s directory in the future, then it might be a good idea to create a share for this, so in the QNAP admin interface, select the shared folders
To do it the easy way, look here
To do it manually, read ahead:
In QTS Control Panel, select Privilege - Shared Folder
Then create a new share, by pressing the Create button
Enter a valid name, like Plex Internal Library and in the field named “Enter Path Manually”, enter the path from Q11
Back to top
Q19: Adding your own certificate to Plex Media Server
This answer comes from the gifted @bcjenkins that wrote up a howto, with screenshots and everything.
You can find it here:
QTS4.2 and before
QTS4.3
Thanks mate for this
Back to top
Q20: Upgrading QTS from 32 bit to 64 bit
If your QNAP is going to be upgraded from QTS 4.2.x towards QTS 4.3.x, then note the following:
  1. Do NOT reformat the drives. It’s a simple upgrade
  2. Do NOT uninstall the existing version of PMS. Doing so will make you lose all metadata, users and so on
  3. Upgrade QTS on to of the old one, and reboot
  4. After the reboot, PMS will fail, since the old 32 bit version can’t run on a 64 bit OS, but ignore that
  5. Download and install the 64 bit version of PMS from Plex
  6. Install on top of the old one
  7. Done
    On rare occasions QTS upgrade changes file/folder permissions used by PMS, and PMS becomes unusable. On such cases:
  8. Identify the path where Plex libraries are installed (see Q11)
  9. Stop PMS and reboot the NAS
  10. take a backup of /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library/Plex Media Server (supposing that /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer is the path obtained previously). Optionally delete the Plug-in Support sub-folder (sometimes it gets corrupted too) but in this case you will have to reparametrize Agents
  11. Remove Plex Media Server and delete the /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer folder manually
  12. install PMS manually using PlexMediaServer_1.7.5.4035-313f93718_x86_64.qpkg (or later)
  13. Stop PMS and replace the newly created /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library/Plex Media Server folder by your backup
    Back to top
Q21: I got more than one network interface on my QNAP
If your QNAP is equipped with more than one Network Interface you can use more than one if, and only if, you enable trunking.
  1. If you have a switch in front of it supporting LACP/802.3ad → Read here for more info
  2. If your switch does not supports LACP then you can enable port trunking with balance-alb or balance-tlb
    If simply adding a second interface, and assigning a separate IP address to that, you will run into problems sooner or later.
    Back to top
Q22: Which IP Address should my QNAP have
Servers need fixed (or reserved) IP addresses. To avoid a clash with any other server on the internet, you MUST use what is known as Private Address Space. According to RFC 1918 these are:
10.0.0.0 – 10.255.255.255
172.16.0.0 – 172.31.255.255
192.168.0.0 – 192.168.255.255
You will not be able to perform initial parametrization if you use another IP range because PMS “thinks” that you are trying to access remotely, therefore disabling initial setup.
Back to top
Q23: Can not claim Plex Media Server
If this is a first install, and after the install, you click on the Plex icon in the QNAP App-Center, in order to open the Plex Media Sever (PMS) page, you will fail due to the fact, that it tries to access PMS using the secure HTTPS protocol.
Sadly, unless claimed, PMS will only respond to pure HTTP calls, until claimed, and as such, simply remove the s from https://...
After claiming the PMS, all will work nicely
Back to top
Q24: I have connected my QNAP to another router and now Plex clients can’t access it
When you connect your QNAP to another router (your ISP supplied a new one, you have acquired a new router, etc.), please review the IP parameters of QNAP’s network interfaces. Replacing routers often implies that LAN now uses a different IP range, and when you use fixed IP’s for QNAP (as you should), you may have to change not only its IP address, but also its gateway and DNS. Failure to do so may lead to impredictable results.
If you are “cascading” routers (connecting QNAP to the LAN port of a router whose WAN port is connected to the LAN port of another router) you may have created a double-NAT situation, and in this case it’s necessary to make a non-trivial setup to activate remote connections.
Back to top
Q25: Quick access to the internal Library Directory
If you want a quick way to access the internal Plex Library directory, where logs reside, as well as 3.Party tools/plugins can be installed in, look here: https://forums.plex.tv/t/160211
Back to top
Q26: How to restart PMS from commandline
Type the following in an SSH command prompt:
/etc/init.d/plex.sh restart
Back to top
Q27: How to update PMS from commandline (SSH)
Please take a look at this trick
Back to top
If you have some additions to this FAQ, feel free to PM either me, or some other Ninja, and we’ll look into it
Best Regards
The Ninja Team
Plex loses NAS
QNAP 4.4.3 & PLEX - Der Server verweigert den Zugriff
Cannot update plex, keeps launching adobe reader?
QNAP - new Plex install - libraries are empty?
Ubuntu 20.04.3 lts or ubuntu 21.10 for plex server
No connection to QNAP Plex server
Adding media to an existing library
Keine Rechte
How to move playlists?
Why Did My Plex Media Server Get so Large?
[BUG] Recent movies randomly disappear on load
Can't upgrade to PlexMediaServer-1.43.3.10828-00f62d37d-x86_64.qpkg
Lost All Access to PMS on my QNAP
Plex keep adding entries of the same movie in my library, now more than 400
Photo library
Unauthorized - You don't have access to this server
Missing TV Metadata Issues
Adding movies on new Qnap
HELP! In Plexamp I Switched to Tidal from Plex Media Server and Cannot Change Back
Remote access not working
This has been asked 1000 times but ... how does someone fix this stupid issue of claiming the server
Media Directory not showing up in docker
Cannot find my NAS Plex Server
2023 Plex Datenbank sichern auf Qnap
Kein Button in Mediathek von Plex um diese zu aktualisieren
Prison Break wird nicht erkannt
Qts 4.4.3
Adding new songs to my Plex Library
Urgent! Please help, no more media library!
Dudas con el servidor desde mi nas qnap
Can't get Plex running, even after total uninstall
PlexData share for QNAP systems
Another oddball naming issue- with Star Trek Enterprise and TNG, but not with Voyager
Adding new series 1883
No files showing on Plex server
Update and modify collection
PMS app on Qnap NAS > Public access without relay
My library on my QNAP does not update automatic anymore
Personal media not recognised
Plex App auf NAS Zugriff auf andere NAS?
Previewa stopped working after last plex server update
Remote access on tv's not working anymore
Library Management Question?
QNAP TS-251+ Stop and restart Plex Media Server app needed each time rebooting NAS
Can't Access Server on QNAP after latest (1.25.7)
Plex not identifying TV Shows correctly
PMS Hanging in Metadata Updating of Movies
Remote Access Green and Red icon?
After migrating from Plex QTS to QuTS hero system, movie names lost formatting
Shut down Qnap, startup Qnap in the Morning,Plex starts, but Movies not available to play
Replacing older NAS - Recommendation requested
Libraries not updating- tried previous advice
Migrating to a New PlexServer - Basic strategy
Latest Plex MEdia Server won't start on QNAP
How to move Plex Server DATA/INDEX files to a non system partition
Moving Plex settings (watch lists etc) from a windows device to a Qnap TS-X53E Nas
QNAP TS-253A PMS unable to find HDHomerun Quatro
DRINGEND ! Bekomme auf mein Plex auf dem Computer nur fremde Filme
Viewing the golder in the plax library
Remote issues after QuTS 5.2.2.2952 installation
Plex on Qnap, couple of questions
Plex not automatically launching on after rebooting QNAP
Probleme mit Plex Erreichbarkeit über Qnap NAS
Where is Server Setup on the Navigation?
Media Library folder and subfolder confusion
How to set temporary transcoder directory on a QNAP NAS?
Problem with Metadata update
Twitch App Wiedergabe Fehler
Plex Media Server on QNAP NAS not adding recently added movie
Serien und TV Database
Overnight media not found as file associated cannot be found
Plex on qnap server - TV library grouping all under one name
Cannot claim PMS on QNAP TS859
Ein Update ist verfügbar
PMS on QNAP NAS - deleted my codecs folder - HELP
Cannot load plex server from qnap after macos 15.6 update (sequoia)
Library Not Updating
How to mirror tags update to library?
PMS Server stuck on old version
I have been locked out of my plex server on my QNAP Nas
PMS auf Qnap läuft nur als Client
Unauthorized when trying to add media server to Plex
OFDB.bundle-master installieren
QNAP App Store PMS not working with new experience apps
Resetting plex server from scratch on qnap Nas
Recommended NAS folder structures - Use standard QNAP or create your own?
Plex is running but fails when I login
Kick Starting Plex from Win 11 Laptop - 4 digit code needed from app?
M.2 Caching Question
Remote Access Stopped and cant get it working!
QNAP QTS 5, Plex ver 14.2 cant run any files all codec problems
My server content is not viisible, my server is not in the list
Where is the Plex database on Qnap NAS ts-451?
Just Checking Before Scanning NAS folders into Plex - Want to get it Right
QTS and Plex Update Advice
QNAP Server not allowed
No remote access on 1.18
Ubuntu 18.04 running plex server can't mount network disk running at QNAP NAS
Q28: How to use the PlexData share
The PlexData share, available in PMS 1.19.5 and above, can be used in multiple ways, like:
  1. Obtain log files to post in the forum when Plex misbehaves
  2. Add hidden preferences to your Plex configuration (Preferences.xml)
  3. Backup / Restore your entire Plex installation
Use of the PlexData share is completely optional. It is a diagnostic and support mechanism. It has no active interaction with PMS itself. PMS is completely unaware of this mechanism and independent.
Setting up and administering the PlexData share
Before the PlexData share can be accessed and used in FileStation, you (the administrator), must
  1. Create the “PlexData” share using Control Panel - Shared Folders. You may place this share on any storage volume you wish.
  2. Assign access permissions using the Shared Folders tool (Control Panel - Shared Folders). This is a required step because every system is different. Presuming any ‘default’ access rights would not be in the best interest of all users.
  3. If you have an existing shared folder named “PlexData” and do not wish to use this feature, it can be disabled: Create an empty file "${QPKG_DIR}/Library/Plex Media Server/.disablePlexDataSymlink" and restart PMS. (QPKG_DIR) is wherever QTS installed PMS. The path name typically looks like: /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer.
  4. Restart Plex one time. This initial start/stop cycle populates the linkage in the PlexData shared folder.
Obtaining Log Files
Zipping the log files to post in the forum is as simple as:
  1. Open the PlexData share
  2. Click the link to go into “Plex Media Server”
  3. Right-Click “Logs”
  4. Compress to the ZIP file
  5. When complete, download to your computer and upload to the forum.
Backing up your Plex metadata
Backing up your Plex metadata is very easy.
  1. Stop Plex
  2. Open FileStation
  3. Click into PlexData
  4. Click into “Plex Media Server”
  5. Click the top selection box to select everything
  6. Right click anywhere in the selected block and “Compress”
    6a. Change the name from Cache to the name you want. (By default, QTS uses the name of the first entry found as the backup name.)
  7. When complete, COPY/MOVE the ZIP file to a safe place.
Restoring a backup of your Plex metadata
Restoring the backup of your Plex metadata is as easy as it was making the backup
with one additional step
  1. Stop Plex
  2. Open the PlexData share
  3. Click the link and go into “Plex Media Server”
  4. Delete everything
  5. Copy your backup ZIP into the now-empty “Plex Media Server” directory
  6. Right-click on your backup file and “Extract Here”
  7. After the extraction is complete (several minutes), you should see your full Plex Media Server directory back as it was. (You will not see any interim progress until after it completes and FileStation refreshes. This is how QNAP works)
Back to top
Create a share for Plex Library Directory
Unable to pull down metadata
Intro detection and PlexData were both "stuck" on Qnap NAS
PLEX media Server local Port 32400 on QNAP NAS not reachable
Moving from QNAP to Linux
Need help with Plex backup using QuTS
Metadata Backup
Restoring PMS on a QNAP NAS
Plex on QNAP NAS cannot be reached
Plex server cannot connect the Internet. The internal and external IP become 'unknown'
Why is there no simple UI option to disable article stripping (ArticleStrings)?
Plex Media Server Backup and Restore
Invalid Digital Signature for Plex running on QNAP
Add a restore Database option to Plex NAS versions
I got the message in server : Severity Level Date Time Users Source IP Application Category Content Error 2020/09/07 05:11:40 System 127.0.0.1 --- --- WARNING: Could not create PlexData share. Further assistance is available in our Support Forums. Cont
QNAP 251+ kann die PlexMediaServer/Library/ nicht finden
QNAP Plex Library Directory
Plex stops working after a few days-Plex doesn’t work anymore
Move an install to another system
No connection to Server after latest 2 updates
Server unavailable on QNAP NAS
Moving Plex Media Server and files to new hard drive in QNAP
How to backup and restore PMS settings/metadata?
Plex Media Server won't launch on my QNAP since last Autumn
QNAP New Install Issue
After changing password i can't access my media by web browser
Security password reset
Server reports "Not authorized: You do not have access to this server" after password reset
QNAP - Plex Server starts then drops out after 30 odd secs
Cannot access QNAP Plex Since resetting password
(Re-)Claiming a QNAP Plex Media Server
Plex not starting after upgrade - QNAP
Backing up plex media server from NAS
Remove PMSLibShare - Extremely Slow Scan performance
Plex no longer working on QNAP TS-451+
Photo library
Media Server Refused to Connect
How to backup the library content for Raid change?
QNAP und Plex Medienserver
After update to Version 1.32.1.6999, cannot archive the Plex Media Server folder on my NAS
What is "Download Database"? Is it a backup
PmsLibShare on QNAP - Invalid digital signature
Plex no longer working/booting after unrelated QNAP NAS outage
Ajouter un agent Plex sur un NAS QNAP?
Backup and restore?
How to delete plex database or the film librarys on plex istance in qnap?
Migrate Plex data form QNAP to another QNAP
Server Error when opening Plex Server on QNAP TS-h973AX
Photo Timeline Gets Corrupted by Plex initiated Scan
Q29: How to bypass iHD driver
This FAQ How-To is of interest to those who:
  1. Have an Intel J4xxx CPU as well as some J5xxx CPUs
  2. Have unwatchable (breaking up) image quality using HW transcoding on J3xxx CPUs as compared to SW transcoding when using very LOW BIT RATE videos.
The issue is a known problem with the Intel HD media driver (iHD_drv_video.so) on those J4xxx CPUs.
The problem has been identified and a solution has been found.
For those of you who are using the PlexData share, this is an easy task.
  1. Install the QNAP “Text Editor” app in App Center
  2. Stop Plex in App Center.
  3. In FileStation, navigate to the PlexData share, click “Plex Media Server” to access your actual configuration files.
  4. Right-click Preferences.xml and “Open with Text Editor”
  5. Go to the end of the second line,
  6. Add the text VaapiDriver="i965" to match this image.
  7. Save the file
  8. Start PMS.
Back to top
Q30: How to reset ownership and reclaim your Plex server on QNAP
  1. Create a shared folder, named “PlexData” (exact capitalization)
  2. Restart Plex
  3. Let it run for 30 seconds then stop it
  4. Install the QNAP “Text Editor” app from App Center if not already installed
  5. Using FileStation, Open PlexData → Plex Media Server (click into it)
  6. Right-click Preferences.xml → Open in Text Editor
  7. Carefully remove the PreferenceName="Value" pairs for
  • PlexOnlineUsername
  • PlexOnlineToken
  • PlexOnlineMail
  • PlexOnlineHome (This might not exist . OK if it doesn’t)
  1. SAVE the file
  2. Start Plex
  3. Open http://ip.addr.of.QNAP:32400/web from your computer
  4. The server will now be in the state for you to CLAIM it again.
Please reach out if you have any difficulties.
Back to top
Q31: HW Transcoding & HDR tone mapping in QTS/QuTS
EDIT: PMS 1.29.2 and above contain native HDR tone mapping support
This FAQ is obsolete and has been redacted.
Back to top
Q33: How to move PMS to a different Data Volume.
On QNAP systems with more than one storage volume (DataVol1, DataVol2, … ),
you can move PMS to any of the volumes you want.
Step 1: Open Control Panel
Step 2: Click the DownArrow next to Open
  1. Click “Migrate to”
  2. QTS will now show you where PMS is installed and a list of new possible location.
  3. Highlight the Volume you want and click “Migrate”
  4. QTS will ask you to confirm what you are about to do
  5. Click “OK” and let QTS move PMS to the new Volume.
  • Depending on how much data you have to move, it can take anywhere from 1 to several minutes.
  1. When migration is complete, QTS will restart PMS.
Back to top
This announcement is due to a major bug introduced by QNAP’s CodexPack vers 4.5.0 and how it disrupts normal PMS operation.
For those who are using the Multimedia library, introduction of CodexPack 4.5.0 breaks all access to your media in PMS.
Your normal media access, which was defined through Multimedia is disrupted by the CodexPack incorrectly and inappropriately injects itself into that path internal to the Multimedia share mechanism.
Your previous path to ‘Movies’, which previously was in /share/CACHEDEV1_DATA/Multimedia gets altered.
After installation of 4.5.0, your path now looks like /share/CACHEDEV1_DATA/.qpkg/CodexPack/mnt/share/CACHEDEV1_DATA/Multimedia which does not work because PMS does not know of that path.
It is understood CodexPack is required to use HD_Station and other QNAP apps.
To remove your PMS installation from this problem and prevent any future involvement with it, it is strongly suggested to access the shares directly.
Example:
  • Previously shares animated, horror, scifi, and comedy as part of Multimedia/Movies
  • PMS was accessing them through /share/Multimedia/Movies.
  • In Libraries -> Edit, for each Library section, add each share directly into the list of folders for PMS: /share/animated, /share/horror , /share/scifi, and /share/comedy
  • Do NOT remove the 'Multimedia` entrie(s) at this time
  • Allow PMS to scan your media and find it again. This happens automatically after Editing a Library section
  • PMS will show a duplicate (2) for each item as it finds it again. This is expected and desired.
  • After scanning is complete, verify all media has been found. Resolve any missing items
  • Return to Libraries -> Edit for each section and remove (x) the Multimedia based folder definitions
  • As PMS scans the section one final time, observe the 2 being removed.
  • The watched status and metadata will be intact for any items not previously lost by the installation of CodexPack 4.5.0
The TL;DR is
Only use /share/ShareName (from the left pane) or /share/PoolName/ShareName (using two-step left/right panes) in Plex. Let Multimedia and CodexPack do what it wants to. Keep PMS free and clear of it.
Addendum:
If QNAP tech supports attempts to assert PMS is corrupt, refute, do not accept, the answer. it is 100% CodexPack failure, not PMS.
Update: 19-Sept-2017
Telephone conversation with QNAP tech support (California, USA) confirms
  1. Use /share/ShareName or /share/PoolName/ShareName (e.g. /share/CACHEDEV1_DATA/ShareName) as they both go to the same place.
  2. If you experience this difficulty with CodexPack and Multimedia, send in a HelpDesk ticket about it.
