I am running uninstalled as the Live option as I need to validate it all works before erasing my current OSX setup
It seems to work but after a few seconds It freezes. I can still SSH in and kill the process but it just freezes again after a few seconds navigating my Library
Here is the log:
`10:09:28 T:140282680547328 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
10:09:28 T:140282680547328 NOTICE: Default DVD Player: dvdplayer
10:09:28 T:140282680547328 NOTICE: Default Video Player: dvdplayer
10:09:28 T:140282680547328 NOTICE: Default Audio Player: paplayer
10:09:28 T:140282680547328 NOTICE: Disabled debug logging due to GUI setting. Level 0.
10:09:28 T:140282680547328 NOTICE: Log level changed to 0
10:09:28 T:140282680547328 NOTICE: Loading media sources from special://masterprofile/sources.xml
10:09:28 T:140282680547328 NOTICE: Running database version Addons15
10:09:28 T:140282680547328 NOTICE: Running database version PlexServerCache4
10:09:28 T:140282680547328 NOTICE: Setup SDL
10:09:28 T:140282680547328 NOTICE: Checking resolution 16
10:09:28 T:140282680547328 NOTICE: Using visual 0x20
10:09:28 T:140282680547328 NOTICE: GL_VENDOR = Intel Open Source Technology Center
10:09:28 T:140282680547328 NOTICE: GL_RENDERER = Mesa DRI Intel® 945GM
10:09:28 T:140282680547328 NOTICE: GL_VERSION = 2.1 Mesa 13.0.5
10:09:28 T:140282680547328 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.20
10:09:28 T:140282680547328 NOTICE: GL_EXTENSIONS = GL_ARB_multisample [TRUNCATED FOR POST]
10:09:29 T:140282680547328 NOTICE: Running database version Addons15
10:09:29 T:140282680547328 NOTICE: Running database version PlexServerCache4
10:09:29 T:140282680547328 NOTICE: Running database version ViewModes4
10:09:29 T:140282680547328 NOTICE: Running database version Textures13
10:09:29 T:140282680547328 NOTICE: Running database version MyMusic32
10:09:29 T:140282680547328 NOTICE: Running database version MyVideos75
10:09:29 T:140282680547328 NOTICE: Running database version TV22
10:09:29 T:140282680547328 NOTICE: Running database version Epg7
10:09:29 T:140282680547328 NOTICE: initializing playlistplayer
10:09:29 T:140282680547328 NOTICE: DONE initializing playlistplayer
10:09:29 T:140282213426944 ERROR: CCurlFile::Open failed with code 401 for https://192-168-1-250.10f18f723da7446689c66786e6d5b806.plex.direct:32400/
10:09:32 T:140282188248832 ERROR: CCurlFile::Open failed with code 0 for https://172-17-0-1.10f18f723da7446689c66786e6d5b806.plex.direct:32400/?X-Plex-Token=SECRETSTUFF
10:09:32 T:140282680547328 ERROR: Control 3 in window 12999 has been asked to focus, but it can’t
10:09:32 T:140282680547328 NOTICE: initialize done
10:09:32 T:140282680547328 NOTICE: Running the application…
10:09:32 T:140282680547328 NOTICE: Webserver: Starting…
10:09:32 T:140282680547328 NOTICE: WebServer: Started the webserver
10:09:32 T:140282030122752 NOTICE: -->Python Interpreter Initialized<–
10:09:32 T:140282680547328 NOTICE: ES: Starting event server
10:09:32 T:140282680547328 NOTICE: starting zeroconf publishing
10:09:32 T:140281900676864 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
10:09:32 T:140281900676864 NOTICE: UDP: Listening on port 9777
10:09:32 T:140282030122752 NOTICE: ## LibreELEC Addon ## 0.8.9
10:09:33 T:140282221819648 WARNING: Read - waited for data but got none`
Any help greatly appreciated!
