empty tv shows in library
Hi all
Im sure this may have been covered but i can’t find the info on the problem im having.
To start of with i have plex media server running on a Windows Home Server 2011 and it was working fine till the server started acting up on me, so i did some looking in to it and found that the drive c:\ had 0.99 gigs free. Now for the Windows Hone server 2011 when setting it up you only get 60 gigs for drive c
So i uninstalled plex from the server and reinstalled it to drive d:\ that has 500 gigs free, also went thru the server and removed all old folders and any thing to do with plex before the reinstall and rebooted the server.
So you know how my drives are drive C:\ and drive D:\ are on a 1 terabit drive and C is for the OS and other software that has to be on it and drive D: is for all other software to be on and run off of, i have drives E: F: G: H: I: drives that are in my data pool under J: that holds my media.
No i set the agents to what they need to be and made sure the user had permission on drive D: to do what its needs to, add my music media first np works fine, added my movies to plex and it loaded with some stuff not getting the right info and covers bu that was easy to fix, then added tv shows and after all was added every thing looked ok, i went thru the music then movies to make sure every thing was ok and it was but then i got to TV Show and i have a problem with them.
Under the dashboard is shows the TV Shows Movies and Music if i click my music if gives me my music list, if i click movies get my movie list, if i click the tv shows i get a blank grayish page with nothing on it other then the black bar across the top, the one with back home button and search, the second bar where you can change to a different library and change you poster size is missing just like the TV shows.
If im on the dashboard i can click Discover and select TV shows and it shows me the Recently Aired TV, Recently Added Television
, Start Watching and Top Rated, i can click them all and plex gives me the info on my tv shows but if i go back to the dashboard and click tv shows on the left it just comes up blank with just the back, home and search on the left and the other links on that bar on the right but that its it no tv shows listed no other buttons to click.
Second pic is what i get from clicking TV Shows on the left side of the dashboard
Thank you for any help on this.
After about 4 days of messing with it nothing seems to work.
I did a fresh install of plex after removing all traces of it from a previce install and did the ‘Optimise Database’ a few time giving about 4 or so hours between try’s. Also removed paths from the TV libraries and still did the same thing.
Checking the media paths wouldn’t work since my J:\ is my storage pool and that’s where media has been located for the past 5 years.
Funny thing is last night after i posted i walked away from the comp and tonight a few mins ago i remote desktopped into my media server to find it saying the system was rebooted due to updates so i loaded up the plex page and found the TV shows now showing in the TV libraries… :\ hmm so i guess this is one that is going to be one of those windows things.
Thanks for your reply trumpy81
